Question about Samsung TXJ2554 TV
No picture when TV is turned on, sound is OK
When the TV is turned on there is nothing on the screen. Sounds comes on OK after the normal 'warmup" time. This used to be an intermittent problem...if you waited 10 minutes the picture would come on all of a sudden. Some other tech references have suggested a bad flyback. Another user seems to have posted a similar problem for the same model. thx Samsung TXJ2554 If I turn the set off, I have wait for three days to get the picture back. Sound is always OK
    Problem Solver:
  • 12 Answers
Try to look at its circuit board and look for cold solder or loose solders usually solders with crack,they might be the problem,i dont think its the flyback coz you have audio.try also look at its picture tube at the back tru the crt if the filament is ok or it may also have loose connections
Posted on Jan 13, 2009
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ... > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
May 8, 2014 - Uploaded by
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
No picture, no menu, black screen, no raster, sound ok
From your detailed description, it sounds that the main chroma processor IC has damaged. Raster means nothing, but the lighted screen that appears, when a TV is switched ON. For some brands, there will be a blue screen; when there is no signal input, and some others will have a bright white screen with some snow.
I advice you to contact any service technician, to get this TV repaired. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 07, 2014 | Televison & Video
Black screen only on new LCD
Sounds like the video board when bad. I would say the TV went defective. Use the 90 day warranty to exchange for a new one.
Always use warranty at this point because the newer TV coming out in these days have very lame warranty.
Rate me, please
Feb 02, 2009 | Televison & Video
My samsung TV won't show any picture/sound.
When the TV is on, need to check the back light is on(go back side & look into through)
If the back light is on -- need to exchange the Main Board
no back light -- exchange the Power Board --- 95%
exchange the LCD panel --- 5%(inverter)
Jan 31, 2009 | Televison & Video
No picture yet i can hear sound green effect before it happend
First thing would be to make sure that you're only using the yellow, red, and white cables, but seeing as how you said you had picture before, I'm guessing that's not the problem. The 360 uses an automatic recognition for the hardware to make sure that it is set to the right input. So, in essence, it won't be that the settings were changed. I would say go pick up a new cable and see if that's the problem, it sounds like it is. If the cable doesn't solve it then I would say it's time to call Microsoft. For the guest with nothing working, call up Microsoft, I really don't know what else the problem could be except for hardware.
Oct 04, 2008 | Microsoft Xbox 360 Console
SHARP 37HV6U No picture until long warmup
Alas, it sounds like something could be quite wrong, or it could be as simple as needing a reset. Unplug the unit, wait a minute then replug it and see what happens.
Aug 28, 2008 | LG 42LC2D 42 in. LCD HDTV
Turning on TV after power outage
Not sure what you mean by "older", but I assume it's a CRT display. It takes some time for a picture tube to come up from a completely cold start. It has to get all of those electrons hot enough to start flying around, and also build up a high voltage on the screen. You don't notice it in normal operation because the power button doesn't really turn everything off, but just puts the set in standby mode. Unplugging, though, lets everything cool off completely.
If you're talking real antiques, with tube-type amplifiers, then the warmup time could be even longer. I remember as a kid watching the blank screen for a couple of minutes before a picture appeared.
What you describe sounds like normal behavior for a CRT television. Not sure what's up with that flickering red light, though.
Jun 26, 2008 | Televison & Video
No picture, but power light is on
Mar 13, 2008 | RCA 27F530T 27" TV
Lets try something ,turn the set on and put you forearm in the face of the picture tube if your hair stand to static it means you have high voltage and your set is missing possible the screen or filaments volts,if the hair in your arm does not stand your set is missing the high voltage and the problem is related to the flyback but it does not mean is bad ,it could have a loose conection in one of the legs or in the near area,next time it happens tap on the side of the set to see if it reacts if it does you know you have a loose conection.If you are familiar with tv service this will be a good place to start but if you are not too familiar be safe and call for assistance from a servicer.Let Us know if you need more information and how it goes.
Oct 13, 2006 | Samsung TXJ2554 TV
Samsung TXJ2554 TV Logo
375 people viewed this question
Jerry Greenberg
Jerry Greenberg
