Question about Xerox WorkCentre XD120F Laser Printer
Won't copy i pressed the paper size button to use the longer size paper and now it won't do anything. red flashing light with a lightning bolt type of symboland green 2 & E flashing. Xerox workcentre XD120f, Can somebody help me ?
  • cstonebythes Jan 13, 2009
    Thank you, I'm not sure precisley what I'm looking for but I gave it a go.still no go. can you be more clear on what the actuators and the fuser look like. I have cleared the paper path,unit looks clean.
    thanks alot for your help.
    President:
  • 2,072 Answers
You have either dirty or worn out feed tires. Try taking a cleaner like fantastic, formula 409 etc and clean them well.
If you need , google a business called " the parts drop". Give them a call and talk to Britt or Joe. They will have those at a fair price.
I don't work there, but have not found a better Xerox parts dealer anywhere.
Posted on Jan 13, 2009
  • Rick Kasper Jan 13, 2009
    Oh. I am not sure how I read that earlier, I thought it said it jammed and the paper wasnt coming out of the tray.
    An E2 indicates a paper jam somewhere in the machine, I assume you do not see any obvious paper in the machine you most likely then have a stuck or dirty jam sensor. You have to take a careful look through out the paper path, where the paper travels thorugh the machine and look for small black actuators in the paper path. See of one is stuck. In an XD120 it is very possible you have a paper stuck in the fuser that you cant see. That is the hot area behind the right side door. That actuator can slip out of position easily.
  • Rick Kasper Jan 14, 2009
    OK I will go into more detail in the morning.
How do i turn off the flash on the nikon coolpix 4600
Press cursor-up (marked with a lightning bolt) to bring up the flash menu, select the lightning bolt in a circle with a slash through it to turn off the flash, and press the OK button in the middle of the cursor pad.
For full details see the "When Lighting is Poor: Using the Flash" section of the manual (begins on page 24 in my copy). If you need a manual you may download a copy here.
Jan 27, 2013 | Nikon Coolpix 4600 Digital Camera
How do I turn off the flash on my s85?
Press cursor-left (marked with a lightning bolt) to bring up the flash menu, then select the lightning bolt in a circle with a slash through it. Full details are in the "Flash/Left button" section of the manual (beginning on page 26 in my copy). If you need a manual you may download a copy here.
Jan 08, 2013 | Samsung S85 Digital Camera
Whenever I try to print anything or copy anything on the Cannon MF6530 it will print the first page then make a beeping noise and the red light starts flashing and it says change paper size - casette 1 LTR...
try to set the proper size for the paper in the printer.
press [Additional Functions] button (right of the LED display)
navigate to Common Settings
use [<-] and [+>] buttons to navigate to Select Paper Type and press and press OK
Confirm that Cassette 1 i selected (or Cassette 2 if you have optional installed)
and Set the paper type
next navigate to Reg. Paper Size, press OK, confirm again the cassette (1 or 2) and using the arrow buttons, set the paper size (should be LTR if you using LTR)
Sep 20, 2011 | Office Equipment & Supplies
I have a easy share c533 and thought it had capability of the flash NOT going off - apparently i am hitting the red eye button - it looks like a flash zaggy arrow pointing down - what is this where is the...
The lightning bolt is the fill-flash symbol. Red-eye reduction is the eyeball symbol. Flash off is the lightning bolt in a circle with a slash through it. There's also an auto flash mode, represented by a lightning bolt with the letter "A".
Repeatedly press the flash button on the top of the camera to cycle through the flash modes.
Dec 11, 2010 | Cameras
How do you turn the flash on? vivitar x024 camera
Press the Flash/Up button repeatedly to cycle through the different flash modes. Your choices are Auto (lightning bolt and letter "A"), Force Flash (lightning bolt), Red eye reduction (eyeball), and No Flash (lightning bolt in circle with slash through it).
Jul 03, 2010 | Cameras
Actually, what I meant was, how do you get the flash to FLASH for EVERY picture? THanks. Samsung L100
Press the Flash button (left on the cursorpad, marked with a lightning bolt icon). Each press of the Flash button cycles through the various modes. You want the Fill mode, indicated by an unadorned lightning bolt.
In my copy of the manual, it's on page 30.
May 05, 2010 | Samsung L100 Digital Camera
How do i turn off the flash on the cannon power shot a530
Press the Flash button (the top part of the circular "joystick" button, marked with a lightning bolt) to cycle through the options. You can choose from Auto with red-eye reduction, Auto, Flash on with red-eye reduction, Flash on, and Flash off. You want the lightning bolt in a circle with a slash through it.
Mar 29, 2010 | Canon PowerShot A530 Digital Camera
Help me turn on the flash on my vivitar vivicam x024 digital camera.
Mar 13, 2010 | Vivitar ViviCam 3350 Digital Camera
The flash clicks multiple times before taking the photo. i have to hold the button down for a while before it takes the photo. is it because of the lighting in the room or is it another problem?
You may have the red-eye flash function on. Press the button with the lightning bolt and watch the screen...stop when you get to "auto"and a lightning bolt.
Feb 17, 2010 | Cameras
Xerox WorkCentre XD120F Laser Printer Logo
81 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
