Question about Precor EFX 546i Elliptical Version 4
I get the message error 05 stuck key on my precor efx 546
  • Precor Master
  • 914 Answers
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Posted on Aug 20, 2014
2 Suggested Answers
SOURCE: looking for repair manuals and error codes for
Could you please advice about ERROR 29 fo C956i/C966i treadmill.
Posted on Mar 04, 2010
Can I adjust the stride length?
Precor EFX 546 Version 1 Elliptical Trainer (Refurbished)
www.amazon.com > ... > Elliptical Trainers
Amazon.com, Inc.
Rating: 4.3 - ‎9 reviews
Working out on an elliptical can burn as many calories as working out on a treadmill. ...allowing you to go forward and backward, as well as adjust stride length to target ...The Precor EFX 546 allows you to stride smoothly while holding the ...
EFX® 546i Elliptical Fitness Crosstrainer™ ' Precor
www.precor.com/en-us/.../efx-546i-elliptical-fitness-crosstrainer-33
With the unique Precor CrossRamp® technology, users can alter the path of the EFX®546i between 13 and 40 degrees in both forward and reverse stride motions, cross ...Excellent stability and freedom of movement for users of all sizes.
FAQ - Precor
Dec 28, 2015 | Precor 546 Elliptical
My precor efx 546 makes noise like a squeaking in left pedal it seems I tried to tighten pedal but I the whole bolt and screw turn together and the other pedal makes no noise
This squeak is normally caused by a bad bearing in the wheel. In order to provide you with the correct wheel, I will need your serial number. The following link will take you to our Precor EFX 546 page.
Repair Parts for Precor EFX 546 Ellipticals SPORTSMITH net
May 29, 2014 | Exercise & Fitness
Precor EFX 546 05 stuck key
Corrective Action
Precor Error Code 05
Jul 02, 2013 | Precor EFX 546i Elliptical Version 4
How to repair a 546 efx precor
Assuming the buttons are working, the numbers change on the display, and the incline works, it may be the lower circuit board or the generator. If it is a very old unit, it may be the electromagnet or the data cable that connects the two circuit boards.
May 08, 2013 | Precor Efx 546 Elliptical Version 2...
Efx stuck key
Corrective Action
Mar 30, 2013 | Precor EFX 546i Elliptical Version 4
"stuck key" message on efx 546i, will not engage, already replaced batttery
Corrective Action
Feb 17, 2013 | Precor EFX 546i Elliptical Version 4
Error 44 precor eliptical 546
Precor Error 44, Un-commanded Lift Motion Probable Cause 1. Intermittent or bad connection in the lift position sensor(potentiometer).
2. Lift position sensor (potentiometer) is bad.
3. Lower PCA is bad.
Corrective Action
  1. Bad or intermittent connection of the lift position sensor (potentiometer) is the most common cause of the error 44. Inspect all wiring and connections related to the lift position sensor (potentiometer). Repair or replace wiring connections as necessary.
  2. Monitor the lift position number displayed while operating the lift in diagnostics mode. If the reading makes large changes or is erratic, the lift position sensor (potentiometer) is likely bad. Replace the lift position sensor (potentiometer) or lift motor if the lift position sensor (potentiometer) is internal to the lift motor.
  3. If the lift moves without any command entered either manually or through a program, replace the lower PCA.
Precor Error Code 44
Nov 22, 2012 | Precor EFX 546i Elliptical Version 4
Getting stuck key msg for my EFX 576i. I've unplugged the keyboard and plugged it back in but no help
Corrective Action
Jan 12, 2011 | Precor EFX 546i Elliptical Version 4
My Precor EFX 546 Elliptical machine has a "key depressed" error message.
Corrective Action
Aug 17, 2010 | Precor EFX 546i Elliptical Version 4
Error 45 on Precor EFX 546 Elliptical
Precor Error 45, Lift Moving in Wrong Direction Probable Cause 1. Lift motor hysteresis.
2. Lower PCA is bad.
Corrective Action 1. The error would usually occur when the lift was already in motion (usually downward) when a lift command in the opposite direction (upward) was made. Some lift motors used in production exhibited a very long turnaround time and the lift motor would still be moving in the original commanded direction while the control system was trying to move the lift in the opposite commanded direction. If the error continues to re-occur, replace the lift motor.
2. It is a rare condition, however if the lift moves in the opposite direction commanded, replace the lower PCA.
Precor Error Code 45
Jul 19, 2009 | Precor EFX 546i Elliptical Version 4
Precor EFX 546i Elliptical Version 4 Logo
393 people viewed this question
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
