Question about Refrigerators
Whirpool fridge/freezer, wmb39lw have replaced front interface board but the fridge is still beeping
We have a whirpool fridge/freezer and have replaced the front interface board,but the fridge is still beeping!
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
How many beeps and is there a sequence?
Posted on Dec 10, 2012
  • 56 Answers
SOURCE: my whirpool 6th sense american fridge freezer has
Be very careful, when the ice maker malfunctions, many things can be the culprit. The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Posted on Jun 10, 2010
refritech08
  • 149 Answers
SOURCE: compressor not running, front display flashing "CF"
have you tried to see if your getting voltage at compessor?? it sounds like relay/overload is bad have you replaced it?
if not, try that i'm suspecting that's the problem
Posted on Apr 23, 2008
woodchuck789
  • 4059 Answers
SOURCE: Freezer is cold, fridge is warm; replaced main board already
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Posted on Apr 25, 2010
caroldon
  • 17129 Answers
SOURCE: our freezer keeps freezing up
Yes , it seems that the thermostat is not working, please check the lines from the thermostat to the control board as frost in due course can effect the connections.
Also make sure that the Auto defrost section is also working with the timer working to defrost in set time- check the heaters and timer.
Posted on Jan 20, 2011
rickead1
  • 1998 Answers
SOURCE: GE Profile SxS Fridge Mod# PSC23MGPB
first thing to check would be to see if the unit is not going into the defrost cycle if you remove the rear panel on the inside of the freezer and check to see if you have an ice build up around the condensor area. while you also have this panel removed you can also check to assure that the fan located in this same area is working properly. Here is also a link on why this happens click here http://www.applianceoutletservice.com/appliance-care-tips/refrigerator-tips/refrigerator-defrost-system-information.htm if you do have ice build up you should take a hair dryer to defrost the ice that is built up around the condensor. Also if you do have this ice build up in order to find out which piece is causing your defrost malfunction you can performin with a multimeter continuity tests on the defrost thermostat and the defrost heater as well here is also a video on how to test the defrost timer http://www.youtube.com/watch?v=tPpLl2d0094 basicly if you pull off that rear panel and the fan is not working you would just replace the fan . Remove the rear panel first and message me back if you have an ice build up and we can solve your refrigerators warming up situation also if you have any further questions message me back with these as well note some models do not have a defrost timer instead they have a pcb board in which it controls the defrost system differently then the timer if you have the pcb instead of the timer and you feel that it is not either the thermostat or the heater message me back this information as well 87% of the time that this happens it is due to the defrost thermostat they are a very cheaply made piece and do short quite easily. Also please remember when our chat has FULLY CONCLUDED to rank how this opinion has helped in your appliance situation it allows me to help others in similar situations in the future Thanks for using Fixya
Rick
Posted on Mar 22, 2011
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
Electrolux side by side refrigerator model E126SS55GSO touch pad on ice and water dispenser will not respond to touch, error code of CE on freezer and fridge temperature, alarm keeps beeping non stop. ...
You have a communication failure, check the wiring at the freezer door hinge and if it is ok replace the control beneath the unit if it continues replace the user interface as well.
Sep 22, 2013 | Electrolux Refrigerators
Frigidaire FGHS2644KF. Fridge just died. Flash code of 5YCF.
Hello erintu81 - SY CF typically indicates that the refrigerator has detected a communication failure after power up. The wiring between the main control board and user interface board will need to be accurately diagnosis. Depending on the results either or will need replacing. At this point, I strongly recommend connecting a professional to move forward accurately and to properly assist with the repair(s).
Mar 01, 2013 | Frigidaire FGHS2644KF (260 cu ft) Side by...
My frigidaire is displaying SY CF
Hello Angela Clark - Typically error code SY CF indicates that the refrigerator has detected a communication failure after power up. Contact a professional to move forward accurately. The wiring between the main control board and user interface board will need to be check and diagnose. Depending on the diagnoses the main control board may need replacing.
Dec 05, 2012 | Frigidaire FGHB2844L
Whirlpool fridge/freezer LCD replacement
What is the model number listed inside the refrigerator section?
Nov 17, 2012 | Refrigerators
Whirpool wgi fridge freezer, fridge not cooling?
Most frideges get all their cooling from the freezer. There will be a fan and duct in the back of the freezer that pushes cold air down into the fridge. If the duct is blocked with ice or the fan motor has quit. Your freezer will work fine but the fridge will barely cool at all. Check that the fan runs when the compressor is running, ( turn both temp knobs to the highest cooling and leave door open until comp. comes on). If the fan runs your duct is plugged. If not you need a new " Freezer Fan Motor". Most are simple to replace and cost around $100.00.
Jan 01, 2012 | Whirlpool Refrigerators
I have a Whirlpool Refridgerator model WBM39MS. It stopped cooling and I had it repaired. The Repairman replaced the electronic control box. Repairer claims that the compressor is working. It now seems...
Hi Lollipop, partially working fridge? A fridge either works or not, cold air is made in freezer then distributed to fridge via a vent. In your case WBM Series fridge, top mount freezer blows air down a vent (back centre of chiller compartment). A common fault with the WBM Series is both the PCB and Interface Panel (PCB beside compressor back of fridge, Interface is display panel front of fridge).
So if freezer is cold and fridge not, try a fan motor. If compressor doesn't work either comp is faulty or PCB has blown(has a burning smell).. Hope this helps you and maybe many other ppl.
Jan 21, 2010 | Refrigerators
Fridge/freezer beeping
There is a lever switch usually above the door (when door is in open position) on the fridge cabinet. Not on the actual door. The beeping should stop if this lever is pressed. If the door is positioned correctly it would depress this lever when closed. It may be that the door adjustment is slightly out. If the beeping does not stop when depressed, then your printed circuit board (located usually above the door) is faulty and needs to be replaced.
Mar 04, 2009 | Refrigerators
Refrigerators Logo
179 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
