Question about Dell Inspiron 2200 PC Notebook
I have a dell inspiron 2200 laptop and my cd dvd driver doesn't work and is missing from the 'my computer' and device manager areas... please help!!!
  • Dan rogers
    Dan rogers May 11, 2010
    have you recently installed windows?
    Master:
  • 413 Answers
Click on this link and download the appropriate driver for your machine. You may have to go back and put in your serial no. for the correct driver. But scroll down until you see the cd/rw drivers and download and install the one that applies to your machine. This should solve your problem
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=INSPIRON%202200&os=WW1&osl=en&catid=&impid=
Posted on Jan 16, 2009
Dell inspiron 2600 disk drive doesn't recognize disk in the drive
if the dvd drive not recognised in windows explorer
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
Sep 30, 2011 | Dell Inspiron 2600 Notebook
MY , CD/DVD LAPTOP DRIVER DOESN'T WORK. IT CAN
goto run and type "compmgmt.msc"(without quotes) and select disc management if the dvd drive is showing below the hard disks means your dvd drive is working fine only thing you have to do is to right click on the CD-Rom 0 and change drive letter and paths to it
.if the CD ROM option is not seen in disk management then you have to go to the device manager option under computer management and expand cd/dvd -rom drives and you will find your dvd drive model if not that means that your dvd drive has got hardware problem
Aug 06, 2011 | Dell Computers & Internet
My dvd rom on my Dell Inspiron 2200 is not working properly
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Dec 14, 2010 | Dell Inspiron 2200 CD-RW/DVD Drive Combo -...
Won't recognize CD, it makes a lot of noise, like if is running but nothing happens. (Dell inspiron 1420 laptop)
U need to reinstall the driver for you cd/dvd rom drive u can do this by "Start right click computer select properties click hardware tab ,device manager then dvd/cd rom drive uninstall driver then click action tab check for hardware change i should be gone after this step go to the dell web site and download the correct driver for your cd/dvd from the web site here is the link http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen this should fix the problem hope this helps
Oct 11, 2009 | Dell Inspiron 1420 Laptop
Dell Inspiron 2200 cant connect to internet
go to support.dell.com and download the modem driver to an external media (cd, thumb drive, etc.).
then right click 'my computer' and go to properties then device manager. you should be able to go to the modem and update the driver from a specific location and then point it to the external media you have downloaded the driver to.
Jul 11, 2009 | Dell Inspiron 2200 Notebook
Inspiron b120 driver missing for ethernet controller
on some one else's computer go to link below and save to cd or usb drive
copy file to your hard drive
double click on it it will start the install
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INSPIRON%20B120&os=WW1&osl=en&catid=&impid=
Jun 09, 2009 | Dell Inspiron B120 Notebook
Cd/dvd driver
Does the drive it self come up.
Lightly push on the side of the drive tray.
Works for me.
To re-install the drive.
1. Turn off the laptop.
2. Press the power button quickly then relese as this tells the laptop to detect the drives.
Mar 26, 2009 | Dell Inspiron 2200 CD-RW/DVD Drive Combo -...
Dell CD/DVD shows up in 'My Computer' but doesn't recognize CD's
the cd player could be bad it doesn't seem to be reading anything. or your windows needs reloading because you have other programs overwriting each other and windows.too much on the drive defrag it
Dec 27, 2008 | Dell Inspiron 2200 Notebook
Cd/dvd rom not working
go into device manager and see if your drive is listed or has an exclamation point beside it.if you dont know how to open device manger go to start menu and click help and search device manager.if there is an exclamation point ! click it and it will tell you the problem.you may need to download a new driver or reinstall the old driver. the only other possibility is the drive is dead :(
Nov 14, 2008 | Dell Inspiron 1501 Notebook
Cd rom problems
I just replaced the CD drive in my 2200, the eye went out. You can check to see if it's the drive or drivers by uninstalling the drivers from the device manager, then reboot. It will find the drive and reinstall the drivers. If this doesn't fix it, then the drive is bad. The drivers for optical drives are very simlpe, some times they will glitch and need to be reinstalled, but most of the time it's the drive that has gone out.
Jul 01, 2008 | Dell Inspiron 2200 Notebook
Dell Inspiron 2200 PC Notebook Logo
66 people viewed this question
Alun Cox
