Question about Fender Rumble 100 Bass Guitar Amplifier
Replacing the low-mid pot on a Fender Rumble 100/210 bass amp
The stem of the low-mid pot broke off and I need to pull out the amp and solder on a replacement. There are 4 screws going in from the top of the cabinet, but I don't know if these are the only screws holding it in or where the wiring to the speaker cabinet runs. I can't tell if after removing the screws the amp would slide forward or out the back. Is this a fairly easy do-it-yourself routine, or do the certified Fender repair folks have special tricks or tools for this type of repair?
  • jhun T
    jhun T May 11, 2010
    As an electronic technician the only trick that we do is based on experience...there is no reason why you can not do it. With Fender folks it will be a zippy but not for free.
    If you are not lucky to get a service manual then dissasembling it is a challenge. Try to take careful inspection to which part is holding or needs to be unscrewed before taking out the board.
    Use a video cam to document it.
    With patience, I know you can do it!
  • 11 Answers
To answer your question: YES and NO this is an easy fix.
Yes if you have the tools and knowhow, and NO if you don't know what you are doing.
There are high voltages in an amplifier that can persist even when the power is off (I have a Laney amplifier that will remain at several hundred volts for days after the power is off). There could be enough voltage stored in the capacitors to give a fatal shock.
At a minimum, you need a voltmeter, soldering iron, some 64/40 rosin-core solder, the replacement part.
Such a fix is pretty cheap for a repair shop. This is about as easy a fix a repairman can have, but thats because they know how to get in and do it without getting hurt.
I work on amplifiers and build them, and always take each time I reach into an amplifier that has had upto several hundred volts seriously. I know that I would charge no more than 1/2-3/4 hour shop time for such a fix plus parts (or about 30-ish bucks). I would think a local shop can do this for you at no more than 30-45 dollars per hour shop rate. Any competant repairperson should only take 15 minutes or so after the amp is out of the case: more time is spent getting it in and out and being safe about it with this type of repair.
Hop that helps!
-mike
Posted on Apr 01, 2009
  • Fender Master
  • 5,603 Answers
The amp goes out the back. SOMETIMES you have to remove a cable clamp for the power cord and do keep track of which speaker wire went where. If there are wires to a reverb "tank" mark them to get them back in the same place.
HINT: Place the box on the SIDE while removing the amp.
HINT: The Tolex covering that is wrapped around the case and into the back LOVES to catch on the amp chassis.... and it can be a fight... use a long bladed knife to coax the edges of the chassis past the Tolex AND one often needs to do this when re-assembling.
HINT: On some models there is a wood bar on the back that one must remove to get transformer past. (Peavey amps have this on some)
Posted on Jan 05, 2010
My rumble 30 bass amp makes a lot of bad noise when i plug it in. it started off when i first started playing it and it worked fine, then after a few minutes it started making the noise. i've tried...
How new is the amp?
A single faulty solder can do that...I'd try returning in to the seller.
Have you tried a different amp with the same equipment?
Sounds like a wiring issue.
Hope I've helped
PvT
Sep 25, 2011 | Fender Rumble 30 30watt Bass Guitar Combo...
HI CAN YOU PLEASE TELL ME WHY MY FENDER RUMBLE 100 BASS AMP DISTORTS AT LOW VOLUME? EVEN THOUGH THE SPEAKERS IS NOT BLOWN
A common reason for 'distortion' with all bass amps can be either that the screws holding the speaker unit to the cabinet have worked loose or that there has been a build up of dust particles in the corrugations around the edge of the speaker cone, which rattle especially on the lower notes.
The solution is simple - remove the front grille and check the screws are tight. Use a vacuum cleaner to remove dust from the rim of the speaker cone.
Feb 01, 2011 | Fender Rumble 100 Bass Guitar Amplifier
Hello ! Do You have shematic diagram for bass guitar combo Fender Bass Rumble 100 / 15 ? If You have it, please snd me on my e-mail ? Regards Zlatko
Try this link:http://www.fender.com/support/amplifier_schematics.php If your amp isn't listed contact them and they will send you one.
Oct 21, 2010 | Fender Rumble 100 Bass Guitar Amplifier
Line 6 Spider III 15W- My Bass and Drive knobs arnt working... my mid and treble seems to be fine plus all my channels and effects but just those two knobs...and its buggin the **** out of me.... any...
resolder the three legs of the pots back down to the pcb. usually the treble feeds the bass, then from bass to mid then to ground. so if treble and mid are working its hard to imagine why the bass wouldnt be working. i would try to resolder, as you might have cold solder joints. keep it unplugged, pull off the knobs, open it up, remove the pcb screws and pull/flip out the pcb and resolder all of the pots.
May 25, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
What sound does the low mid suppose to give?
When terms like "low-mid" are used, it generally means frequencies between approx. 125Hz to 315Hz.
Apr 25, 2010 | Fender Rumble Series 100/210 100watt 2x10...
My Fender Blues Deville 212 has a very "ratty" tone on clean...
i am guessing on what the problem is , the post is very vague. i am guessing a channel switching issue. you need to check the "sugar cube" looking power resistors solder welds. they are probably cracked and arent making good contact. if you tap on the amp it will cut in and out, its probably these two resistors. they are usually 470ohm 5 watt cement resistors. what happens is they get real hot, and as they cool down they crack the little solder welds. i usually replace them with new and keep them floating up over the pcb to help them stay cool and off of the board to prevent further solder weld cracking, stock they are real close to the board. then put a little silicon under the resistor to hold it in place and to keep it still on the board. i just fixed a blues deluxe with this issue. while you are in there, cut out the resistor sitting right behind the reverb pot, this will make the reverb awesome. also solder the mid pot center leg to the mid pot leg that comes off of the bass pot leg to get better midrange control. very easy mods. check the master volume pot, is it a B100K? pull it and put an A250k in its place for better volume control. bias pots , etc. check my website yostamplifier.com.
Mar 05, 2010 | Fender Hot Rod Deluxe Guitar Combo...
For 100 watts it doesn't seem that loud to me. Could I maybe add more speakers (2x10s)?
Our human perception of loudness can be way off. You should get a soundmeter and compare. There are some pretty good ones on eBay new for about $140.
Adding speakers may NOT increase the sound much as the power will then be split between the speakers.
Nov 02, 2009 | Fender Rumble 100 Bass Guitar Amplifier
My fender rumble 100 used to cut out, now it's
Suspect the input jacks. Wiggle them and see if you get anything. They get yanked sideways because the musicians don't loop their cord thru a handle and they get yanked sideways.
Also you can try spraying sparingly CRC226 into the switches and pots. You can get it at Home Depot in the electrical department.
Oct 08, 2009 | Fender Rumble Series 100/210 100watt 2x10...
Fender Rumble 100 210 pop noise then hum after strong low e note
I just fixed my bass amp with a similar problem last week: the problem is related to a loose connection on the PCB board (likely).
A bass amp is a rough place for circuitry: the low rumble and power shake a bass amp more than a guitar amp.
In my case, the power transistors needed to be re-soldered and then the grounding bolts and screws needed to be removed and cleaned because the connection was bad. Remember that when two different metals needed for an electric connection are toughing, there is the likelyhood that corrosion WILL happen.
My bass amp did basically the same thing yours did: sounded good at low volumes, but at higher volumes it would act up.
In short, there is nothing you can do (unless you are a repair person): you need to take it to a local music shop and have a tech fix the intermittant contact problem: someone who knows what they are doing should only take an hour at most.
Hope that helps!
-mike
Feb 22, 2009 | Fender Rumble 100 Bass Guitar Amplifier
Replace C21 (10uF/50V) and C38 (2.2uF/50V) and it will work great.
Feb 22, 2009 | Fender Rumble Series 100/210 100watt 2x10...
Fender Rumble 100 Bass Guitar Amplifier Logo
987 people viewed this question
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Are you a Fender Music Expert? Answer questions, earn points and help others
