Question about Nokia 6133 Cellular Phone
My speaker keeps going out .maybe a short in th wire.
Is it an easy fix, and how can it be done?
Yeah i had the same problem so i just called t-mobile and they gave me a new one
Posted on Jan 20, 2009
Driver side speaker keeps going in and out. Have any idea what this could be?
It could be the wiring going from the radio to the speaker. It would most likely be right at the speaker contact points or just behind the kenwood cd player at the wire harness. If all wiring looks snug tightly then double check for shorts. Wires chafe all the time then intermittently touch other wires or metal on the vehicle. Assuming the speaker itself is in good condition the problem should be easy to fix. Also, make sure all fuses are the correct amps and in the correct slots.
Jun 25, 2015 | 2005 Ford Taurus
Keeps cutting off when you hit the power button,it's like it is blowing a circuit or something,maybe a circuit protecter or a fuse> Thank you
Disconnect all of your Speaker leads and see if it still does that when Powering on, If not then one of your speakers/Wires has a direct short. you can test the speakers/Wires with a multi meter you can tell as they should have 6-16 ohm resistance. If it still does this with no speaker wires connected then you have an internal short and should take it to a repair center or local audio/video tech.
Jan 30, 2014 | Sony STR-DE525
How do i take apart the speaker to fix it?
Generally the speaker can be removed from the box by taking the Grill portion off. Some are attached with Velcro and some with plastic pins on the frame that are pushed into the box. If a speaker is set in place with glue, you can't remove it unless you rip it out completely by hand. Some have screws and these are easy to remove. The speaker wires may be short, so take care not to rip out wires with the speaker attached. When you did the speaker replacement, place the speaker Grill (Front panel) back in place and you are done.
Dec 19, 2013 | RCA Audio Players & Recorders
I have a 2004 suz forenza. The timing belt broke.Is it done or easy fix ?
its not done and its not an easy fix the cylinder head gasket needs to be checked and its kind of expensive to fix
Aug 23, 2012 | 2004 Suzuki Forenza
Shorted Out a JL Audio E4300 Amp
The screw through the speaker wire caused a dead short and turninged it up loud, you may have fried the capacitors on the output side of the amp circuit. It is easy to tell if you open the amp up, but do so with it disconnected and out of the car. The tops of the caps may be split or bulged. It is worth fixing in my opinion.
Feb 12, 2012 | Car Audio & Video
The buttons on my PSP feel stiff and are not working well. What can I do to fix them?
Well you need to take apart the PSP. If it's no longer under warranty you can do this easy. There are 4 screws on the back on the PSP. 3 are easy to find, and the last one is in the battery compartment, under the stick talking about voiding your warranty if you take it off. Remove the stick and unscrew it. The front of the PSP should come off nice and easy. There you can clean and fix anything you need done.
Sep 30, 2011 | Video Game Consoles & Games
My harman kardon avr 100 keeps cutting out every 3 secs. i can hear the music but constently keeps cutting off. its very annoying... any ways to fix this probem?
Check the impedance of the speaker wires going into the amplifier. It sounds like at least one set of speakers is overloading the amp (shorted, or almost shorted)
Jul 24, 2011 | Harman Kardon AVR 100
Speakers made popping sound and now receiver is in protection mode
It sounds like you have some wires that are touching cause the reciever to protect itself. Go over and check all wiring and make sure you have nothing touching. Unplug device while you are doing this and then when done plug back up and see if that fixed issue.
Jan 31, 2011 | Denon AVR-1801 Receiver
I have coolant leaking from the heater core inlet tube; how easy is that to fix myself and is there a temporary fix I can try if I have to have a pro do it?
Get ready to pull the dash out to replace the core, it ain't easy and paying someone who has done it before is the only practical fix. The easy fix is to pull both hoses off and put a short piece of pipe between them to remove the core from the system. Note that your defroster and heater will be no good.
Nov 15, 2010 | 2002 Dodge Stratus
Nokia 6133 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
