Question about Sanyo Televison & Video
Wants to adjust aspect ratio on 2004 mitsubishi projection tv
  • 192 Answers
SOURCE: Hitachi Ultravision LCD Rear Projection
Normallly, if the format button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made. For example: A Motorola Cable box needs to be set up to go to a wide screen when an analog signal is detected. It's difficult to determine the repair without knowing the hook up of the peripherals. Hope this helps.
Posted on Jun 24, 2007
SOURCE: CONVERGENCE IC ADJUSTMENT
My KP-46WT510 picture is out of alignment. There is no conversion of the red, blue and green pictures on the screen. They're off by about an inch of each other.
Some tech told me that it was the power control that was bad. I can see the picture, just very blurred.
Is he right? The tv was not move at all before this started happening.
Posted on Nov 05, 2008
SOURCE: How to adjust aspect ratio on Mitsubishi VS-6043 TV?
I have the same problem and the only thing I could do was to change the name of the input on your tv to pc on the menu screen and it should set it to 1080p reduced this will fit the whole picture and set your screen res on your computer to 1920x1080
hope this helps
Posted on Sep 22, 2009
techman007
  • 1112 Answers
SOURCE: 55 inch mitsubishi rear projection tv red lamp out of adjustment
Have convergence IC's replaced. I believe this unit uses STK-392-570 convergence IC's Only one has gone bad but replace them both, because if one has failed then the other is not far behind, for Blue and Green. One handles Red, One handles BLUE and Grn. There are only two of them in the set, They are the two largest IC's in the entire set.
Posted on Oct 01, 2009
Ecollier2012
  • 3459 Answers
SOURCE: Rear projection - convex distortion / ghosting / expanding screen
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 18, 2010
Replace chip for white dots now have two black bar top and bottom model wd65735
Probably ok. Check the picture ratio or format settings to see if the bars go away when aspect ratio is right setting.
Feb 06, 2015 | Mitsubishi WD65737 65" DLP TV
How do I adjust the picture size on my Mitsibishi tv. It is too wide and might be too tall. I cannot find aspect in the menu.
On your original TV remote look for button that says Picture size, Format or Ratio and press it till you see the normal size.
Sep 21, 2014 | Mitsubishi WD-73733 73" HDTV
I have a 2001 65 inch mitshubishi tv how do i get the pic to fit the screen its to big
There should be an aspect ratio button or picture size button on your remote. If this doesn't help, then change the settings aspect settings on your cable/satelite box.
Mar 21, 2013 | Mitsubishi WS-65809 65" Rear Projection...
How to adjust aspect ratio on sony kdl-v40xbr1
Hello
To take advantage of the wide mode feature on your TV, Set the DVD players' aspect ratio to 16:9. For details, refer the operating instructions supplied with your DVD player. Aspect ratio must be set with DVD player. Not with the TV. OK.
Feb 05, 2012 | Sony BRAVIA KDL-V40XBR1 Television
Picture on screen is too big head of people are cut off it does not show complete picture
Use your cable or satellite tv remote to adjust the aspect ratio. If you have cable there is a button on the remote called hd zoom and it has this symbol: #. On the satellite tv remotes it usually says format or aspect. You might even have to go into the cable box/satellite tv receiver menus to adjust the aspect ratio/picture format. Once you have done so you can fine tune the picture even further with the television remote's wide/format/aspect/zoom button. Also check and make sure your television is on the right input and that your cable box/satellite tv receiver is set at the right resolution for the television 1080p/1080i/720p.
Jul 12, 2011 | RCA HD52W59 HDTV Projection Television
hope this helps
Aug 01, 2009 | Mitsubishi VS-6043 60" Rear Projection...
Aspect ratio - postion problem
Unless you can control the aspect from your front panel controls, there are adjustments that can be made from the back. You might not be able to reach them yourself. If not you may have to call in a repairman to do it for you.
Jul 11, 2009 | Televison & Video
Aspect ratio and tv type
The phillips 9P5544c isnt a HD tv so you will only have 4.3 formatt available
Jun 20, 2009 | Philips 9P5544C 55" Rear Projection...
Picture is wider than the screean
There is a service menu that techs can use to adjust vertical and horizontal widths. If it is not an aspect ratio problem then it is likely that it needs to be adjusted.
Apr 23, 2009 | RCA P46921 46" Rear Projection Television
Televison & Video Logo
18 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
