Question about D-Link ShareCenter DNS-343-4TB Network Storage Server - 4 TB 4 x 1 TB - RJ-45
Can i put 4 4tb drives in my dns-343
I have 4 3tb drives in my DNS-343 network storage device can I put 4 4tb drives in the DNS-343 network storage drive
  • 25 Answers
SOURCE: static IP address, primary DNSand Second DNS
hi
the router ipaddress or default gateway will be 192.168.0.1 and you can use any ipaddress from 192.168.0.2 to any... for your devices like computer and primary dns address will be 4.2.2.2 and the second dns will be 4.2.2.3
gud luck
thanx and regards
sukhvinder
Posted on Aug 19, 2009
bob_computer
  • 3153 Answers
SOURCE: Looking for best deal on DNS-323 + 3TB hard drive
My personal choice would be for Western Digital green series drives
7200 RPM drives with as large a CACHE as possible would be the main part of my specs.
Faster speeds are becoming available but they are still quite new technology so just for now you might want to cross them off the list too
Seagate has taken some hits recently with firmware issues so for the moment they would not be on my list either
SATA interface hard drives ar the only ones supported by this unit so other than what I have said the choice is quite large.
Posted on Aug 21, 2009
Testimonial: "This is definitely helpful. Any good place you recommend for me to purchase the whole unit + the hard drives? BHLatif@aol.com"
bob_computer
  • 3153 Answers
SOURCE: what is the primary DNS and secondary DNS?
There are two ways to find the DNS.
One is to call your ISP but with most ISP's this means long telephone calls many times to people who dont understand what you want and need to much informantion just to get a simple answer.
Here is the quickest way !
Connect ONLY the MODEM to a pc by wire and nothing else
Go to the start menu and select RUN
In the box type "cmd"
Now in the black screen that has come up type "ipconfig /all"
Take note of the numbers that are in 4 groups e.g. 192.168.1.1
Also take note of the name in front of those numbers !
Write down any numbers where it says DNS too as they may be useful (you only need the ones with numbers not the ones with letters)
Posted on Sep 23, 2009
  • 181 Answers
SOURCE: Mapping of D-link DNS-323 drive doesn't succeed.
I had the same problem when I was attempting to map the drive using the hostname of the DNS-323. I solved the problem by typing in the IP address instead. Do the following:
1. Login to the DNS-323 as admin
2. Make sure you use static IP's to make sure that the address does not change in the future.
3. Go to the drive mapping page and use IP address instead of hostname in the drive mapping (e.g. \\192.168.1.1\Volume_1)
4. Make sure you use a valid username and password.
5. Check the connection configuration by clicking on the Test button.
You should get a successful outcome, otherwise check all the settings again until you are successful
Posted on Jan 04, 2010
  • 181 Answers
SOURCE: Can not access Dlink DNS313
When you said you tried resetting, did you mean you clicked on the reset button inside the hardware or did you mean you just rebooted?
* If you clicked on the rest buttion, then you need to configure again from scratch. Not sure if your data will still be available though.
* If you just rebooted, then the problem may lie in your LAN configuration. Do the following:
1. Try to ping the device using a PC connected to the same network.
2. If you are using DHCP, your device may just have been assigned a different IP. Try to ping all devices in your network or use a network scanner (e.g. SoftPerfect) to find out the IP address given to it.
3. Once you get the IP address, assign a static IP address to your device that is beyond the DHCP scope. This will ensure that your IP does not change and you will not have a conflict with DHCP assigned IP's.
Can't connect to my dns-323
If you disabled the firewall and the Easy Search utility still can't find it, you could try searching for the answer in the device's user manual:
Link DNS 323 manual
Aug 04, 2012 | D-Link DNS-323 (DNS323) Hard Drive Array
Cannot access documents on dns-313
I'd try two things. Boot in Safe Mode with Networking and disable all firewalls, see if you find the NAS. Your issues sure screams firewall configuration to me.
Apr 21, 2012 | D-Link DNS-323 (DNS323) Hard Drive Array
Easy Search does not pick up the DNS 323
This may be problem with your personal firewall on Windows workstation where you are running the Easy Search utilit. Try disabling the firewall while you run it.
Mar 19, 2010 | D-Link Dns 323 2-Bay Network Storage...
I have a D-Link DNS-323 Hard Drive Array and many times I cannot access it but have no explanation of why it works sometimes and others it does not. The error I get is 'Microsoft Windows Network: The...
What is the firmware version of DNS-323? Many bugs were fixed in recent firmware revisions. You can see your version in the top right corner in the web interface after you log-in. See on the D-Link website if there is a newer firmware available.
When it doesn't work, what you have to do to make it work? Reboot windows? Or reboot the DNS-323? It can also be issue with your firewall or Windows configuration. Which Windows version do you use?
Jan 31, 2010 | D-Link DNS-323 (DNS323) Hard Drive Array
D-Link DNS 323 Bittorrent doesn't start
Make sure that the ports for the application are open in both your modem and router
Dec 29, 2009 | D-Link Dns 323 2-Bay Network Storage...
When I access the DNS-313 via it's Web interface and try to schedule a backup, the TEST URL fails. Do I need IIS & FTP installed on each (XP PRO) PC to be backed up ? Is there a 'user-friendly' way to...
This may happen because it cannot find the hostname of your device. Do the following:
1. Make sure your device is configured to use a Static IP address
2. Type in the IP address (instead of hostname) in the test page
This should fix your problem
Dec 08, 2009 | D-Link DNS-323 (DNS323) Hard Drive Array
Hello, I just bought DNS-323 and trying to start up it. I?m using one hard drive Seagate Barracuda 7200.10 ST3500630AS SATA 3G HDD 500G. I installed it in HDD1 slot and start the system. DNS-323 received...
I read that there are problems in some applications if you use only one disk in the 323. Try to move your disk to the other slot to see if this fixes your problem. Alternatively (if u have the money), you can try buying another hard disk of same brand/model and install it on the other slot.
You can then try setting up your device as a RAID1 or bigger (not recommended) JBOD configuration
Nov 22, 2009 | D-Link DNS-323 (DNS323) Hard Drive Array
Nov 20, 2009 | D-Link Dns 323 2-Bay Network Storage...
I try to connect DLINK dns 323 to WD TV by USB cable but it not work how can i solve this
The USB port on the D-Link DNS 323 NAS is for a printer only. It won't work with your WD TV. Your best bet would be to plug the WD TV into a PC that is connected to your network along with the D-Link DNS 323 NAS and serve your media files that way.
Sep 04, 2009 | D-Link Dns 323 2-Bay Network Storage...
Can`t acsess the DNS-313
Make sure the device is connected to your network then try this:
Jun 22, 2009 | D-Link DNS-323 (DNS323) Hard Drive Array
D-Link ShareCenter DNS-343-4TB Network Storage Server - 4 TB 4 x 1 TB - RJ-45 Logo
170 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
