Question about LG WFT1071TP Top Load Washer
Clean LG WF-T652a Top Loader Washing Machine
Our washing machine has filter bags on the top of the tub and have recently stop collecting lint from each wash. How do we clean the washing machine?
  • kandalee Feb 04, 2009
    First one bag stopped, then a couple of weeks later the other stopped.
    The lint is all over the 'clean' washing.
    Everything else is OK with the machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
Posted on Jun 19, 2010
I am getting a lot of lint on clothing is there a cleaning process with my smart drive pride 5.5 fisher & paykel washing machine
clean the lint filter in the machine
put any clothes that are likely to shed lint or are susceptible to collecting lint in a wash bag before putting in the machine
Oct 17, 2017 | Fisher Washing Machines
My washing machine type 580 is not washing clean. Leaving the cloths with lot of lint
you forgot to mention if it is a top loader ( inside the top of the agitator ) or if it is a front loader
Apr 14, 2015 | Washing Machines
I have a LG top loader Fuzzy logic 6.5kg model WF-T655th spin cylce not working, the light is flashing. I have a load in the machine, how do I emppty the water out of it. Have misplace the manual.
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
Jan 16, 2012 | LG Washing Machines
Does this machine have a lint filter? I am getting bits of yuk on my washing after the wash is finished
No lint filter. The tumbling wash action generates very little lint, which washes down the drain.
To get rid of the "yuk":
Open the access panel on the lower left corner on front of the washer.
Use small hose to drain the remaining water from machine.
Remove the pump filter next to the hose, clean it out, and replace it.
Run the washer with a commercial washer cleaner such as Affresh, washer magic, or whirlaway hot tub cleaner, no clothes, hottest longest cycle possible. Use the tub clean cycle if your model has it.
Resume washing, using one tablespoon of HE detergent per cycle. Use only 1 teaspoon of fabric softener if you use that. These machines use much less water than the old top loader ones, and thus you must use much less detergent.
Feb 24, 2011 | LG Washing Machines
I would just like to know where the filter is on a top loading speedqueen washing machine. there must be somewhere that the bits and fluff collect.
there is no filter' it's what they call a self cleaning lint filter, collects lint while washing and then on spin lint goes out with the drain water
Feb 18, 2011 | Washing Machines
Washing machine is not completing spin cycle at high speeds. Only goes slow speed tumble for a few times and then stops.
Below is for Whirlpool/Kenmore, u might find it helpful. Some machines have a small trap door on left front bottom, coin trap.
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
On some models the filter is located ‘inside’ the big hose from the bottom of the tub. This takes more time to clean.
Jun 04, 2010 | Frigidaire ATF6000ES Front Load Washer
The washing machine does not filter out lint. It
I have the same problem. There's a plastic piece top back of tub that says "Clean lint filter after each load", but where is it ?
Mar 14, 2010 | Frigidaire FEX831CS Top Load Stacked...
LG WFT1071TP Top Load Washer Logo
1,304 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
