Question about GE WPGT9360EPL Top Load Washer
I have a GE Profile Harmony washing machine
I replaced the bearing mechanism and now the washing machine hits the top to the machine when it is in the last two minutes of the spin cycle. When I replaced the bearing mechanism the agitator had to have a washer put under it to keep it from hitting the bottom of the tub and not rub. I followed the diagram with every washer and nut precisely.
5 Suggested Answers
  • 641 Answers
SOURCE: Ge Profile Harmony Washer doesn't drain properly.
It sound like you have a blocked pump. Remove the pump from the machine and check where do you have this clogged, inside the pump or in one of the pipes connected to it. Good luck!
Posted on Aug 16, 2007
the dr
  • 447 Answers
SOURCE: ge harmony top load model wpgt9350copl washing machine
This is a very complicated machine utilizing no transmission, rotor/stator type drive motor, and a locking/unlocking clutch mechanism design to either engage or disengage the wash basket. These machines are tricky even for professionals to properly diagnose.
Posted on Jan 19, 2008
Jimster
  • 240 Answers
SOURCE: main seal
This is a pretty tough job to do on your own, but can be done. First step is to remove the front, then the top. Remove the rear cover plate under the console, and swing it out of the way. Unclip the top ring and remove the four suspension dampener straps, remove the top ring. Reach under the agitator, and pull up with force (dont hit yourself in the head or face with it, hurts for sure...) until it pops off (agitators on GE's just snap). Sometimes these can be a real bear to get off, so dont get discouraged. Sometimes you can put a peice of small rope or line under it and jerk it up. After you remove the agitator, you will see the drive bell. Remove the bolt on top of the bell, and once again, try to pull the bell up and off the shaft (once again, a real bear in some occasions, rope trick or puller also will work here). Once you remove the bell, the good part starts. Most of us repair persons have a special spanner tool for that nut your looking at. I believe it is a 1 7/8" nut. This nut is REVERSED THREADED, which means to remove you will spin it clockwise. These spanner nuts can be very, VERY difficult to remove. A lot of WD-40 and time. Most of the time you have to bang them off with that special tool and a hammer, but you may get lucky. If you do get that nut off, you can remove the inner tub. Be sure that the metal drive hub bolted to the bottom of the inner tub is completely tight all the way around. GE units have a very bad habit of those screws backing out and the drum getting loose causing major league noise. Now that you have removed that, you need to remove the outer drum. Remove the wires from the motor, etc. Unhook the 4 suspension rods and plastic clips by pulling the bottoms down (spring loaded) and removing them from the frame. Unhook the tub to pump drain hose, tilt the entire center section top towards the back, and swing the unit out from the bottom. Remove the outer tub by removing the hold down screws. Your seal will be in the bottom. Just pop out and replace. Here are some diagrams that might help you out.
Cabinet and Top:
http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0153200&brandID=0432&modelDesc=WASHER&modelNumber=WWSE6260B3WW&documentID=G0302079&documentTypeID=PLDM&documentClassCode=PV&titleType=CABINET%2C%20COVER%20%26%20FRONT%20PANEL&titleID=00002&
Drum, Agitator, Basket:
http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0153200&brandID=0432&modelDesc=WASHER&modelNumber=WWSE6260B3WW&documentID=G0302079&documentTypeID=PLDM&documentClassCode=PV&titleType=TUB%2C%20BASKET%20%26%20AGITATOR&titleID=00003&
Drive Componants, Suspension Parts:
http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0153200&brandID=0432&modelDesc=WASHER&modelNumber=WWSE6260B3WW&documentID=G0302079&documentTypeID=PLDM&documentClassCode=PV&titleType=SUSPENSION%2C%20PUMP%20%26%20DRIVE%20COMPONENTS&titleID=00004&
Good luck, and let me know how it comes out, or if you need anything further. Good Luck!!!!!!
Posted on Feb 03, 2008
MNTECH
  • 1543 Answers
SOURCE: GE Profile WPRE6100G Top Load Washer. The hub nut loosens
You do not have a "high torque" motor (which would have required motor replacement along with these other parts).
Install a new hub washer WH2X1199, split ring WH2X1195, and hub nut WH2X1193. Inspect the hub on the inner basket for wear. If it is worn, the entire SS inner basket (WH45X10060) will also have to be replaced to prevent continued problems. If possible, tighten hub nut with torque wrench to 110 ft-lbs. I hope you did not purchase from Sears. (Sears sold machines are sold with NO FACTORY WARRANTY of any kind. For those, GE will tell you to call Sears.) If not from Sears, you may be able to get some assistance from GE customer relations if you need the inner basket. Your machine was manufactured in Nov. 06, so most likely was purchased over one year ago.
Note: If you look at the board on the top portion of the motor, you should see a LED light flashing on the right front side. It should flash about 1 second on, 1 second off (unless motor running, then .5 on, .5 off) Other flashes indicate various problems. To reset code if necessary, unplug motor for at least 15 seconds, then plug in, wait 3-5 seconds, then open and close lid 5 times within next 10 seconds.
If this does not rate a Fix-Ya for you, please don't bother rating, as I don't like to see my score drop after giving this much free advise.
Thanks.
Posted on Jan 17, 2009
Macintoast
  • 4 Answers
SOURCE: GE washer won't agitate
I had this same problem with our GE top load washer.  I just needed to pull harder.  (Note: The agitator is held in place by about a dozen L-shaped clips in a ring around the agitator's base that will release more as you pull harder on the agitator.)  Everything from the base below the large fins on up comes out together.  Grab the shaft above the fins and pull slowly and hard. I had to take the entire tub out, lay it on the porch, put my feet inside of it, and pull the agitator assembly out.  I wasn't able to pull it out while it was still in the washer.  BE CAREFUL! DON'T **** IT OUT; that might injure your back; just pull out slowly and as hard as you can without hurting yourself.  I was able to get it out successfully, but I am currently stuck at removing the bell below the agitator.  Good luck!
Posted on Feb 28, 2009
Where is the lid switch located on my GE Harmony washer?
It is usually within the lock mechanism, try putting a small bar or something That look like the bar of door latch thru female mechanism, It should start when activated ( stop It when it´s filling up before There is enough water, you should not get swamp... )
Feb 03, 2015 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Ge profile harmony- needs a new "brain" according to appliance repair man. how difficult is that to replace?
If he means timer its very easy.
Remove console and timer is behind control knob
If this was helpful please rate me.
IMUFO2
Sep 11, 2010 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
How do you remove the washer door
Thanks very much, but my husband found a way to remove the lid on the washing machine. There are 3 screws on each side of the lid that have to be unscrewed in order to remove the lid.
Jan 13, 2010 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
Agitator problem
Check to see if any thing is under the agitator. If not then maybe the bearings going out or other part of machine . Besure the cap is tighten so agatator don't come off. Check for ware on agatator top to the tighting nut.
Jun 02, 2009 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
GE Profile Harmony Clutch probs./Invertert PCB history
Your inverter board is operating 7 degrees over the max temp...
Clear this error be exiting the service mode and run set up ...
if it comes back you will need to replace inverter board....
let me know if you need more help...
Jul 30, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Ge harmony top load model wpgt9350copl washing machine
Jan 19, 2008 | Washing Machines
HELP, GE profile harmony washer wont drain properly
If you remove the tub to pump hose from the pump and try to turn the pump impeller by hand, it should turn freely. If it does not turn freely, then the motor could be seized and you will need to replace the pump.
Oct 15, 2007 | GE WPGT9360EPL Top Load Washer
Aug 16, 2007 | GE WPGT9360EPL Top Load Washer
GE WPGT9360EPL Top Load Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
