Question about VinoTemp Refrigerators
Vinotemp vt 52 not cooling, fans working and digital display ok
Compresser does not start
SOURCE: Vinotemp VT-60 Condenser won't shut off, unit running way too cold
It might be a sensor or control board problem. Any appliance repair place should be able to help you out with this. Or you can try contacting the manufacturer directly for help or if you need to purchase replacement parts. Otherwise, my cheapest suggestion would be to hook the cooler up to a timer, so you can turn the unit on and off maybe every 20 minutes or so. That should help keep it from causing more harm and then you can monitor the temperature with a thermometer. Hope that helps!
Posted on Sep 04, 2008
projdoc
  • 2237 Answers
SOURCE: This VinoTemp vt 60 just quit working. No
if the evaporator coils are warm, you have a leak and no refrigerant.
Posted on Aug 26, 2009
  • 14 Answers
SOURCE: Vinotemp VT-16TEDS has light on but doesn't cool
You may need to change the cooling system on the unit if the unit is free of dust and still does not cool.
Posted on Sep 21, 2009
57 varieties
  • 1653 Answers
SOURCE: Vinotemp (VT-60), cools, but doesn't turn off
It will either be the thermal resistor or the controller of which the electronic thermostat is a part and yes it can be repaired. It is a reasonably common and cheap fault to repair. If you go to the following link you can get the service manual FOC
http://www.vinotemp.com/Resources/Documents/VT60.pdf
and you can contact a repair company via Vinotemp at the following link
http://www.vinotemp.com/Service-Support/Repair-Companies.aspx
Posted on Nov 05, 2009
SOURCE: My Vinotemp VT-12TEDS has no front panel lights or
I also have the same problem and am looking for a solution short of buying a $35 replacement board with $10 shipping for a fridge that costs $60 new.
Posted on Nov 07, 2009
What's your problem?GE Model # GDL20KCSABS clicking sound Clicking sound
The clicking noise would generally be the overload on the compresser. Which means the compresser is locked up and unable to pump and needs to be replaced. Sorry You can install a 3in1 hard start which may free the compresser rotor and give you a little more time out of it but will need to be replaced eventually Good luck
Sep 08, 2012 | GE Refrigerators
Frigidare freezer says off
I would be looking at the temp control first off. If you are getting power through the control then I would look at the compresser. Put your hand on the compresser and if it is very hot and not vibrating your compresser is on the way out. You can install a hard start and get a little more life out of the compressor but imt will need to be replaced at some point. Good luck
Sep 08, 2012 | Refrigerators
2005 ford focus zx4 ac compresser making noise when ac is turned on
Yes, it could be the ac clutch or the compressor itself.
Jul 08, 2012 | 2005 Ford Focus
Compresser not working
Changing a compresser is not something that an untrained person can do, because of the coolant (which is controlled in most states). The part number of the compressor is: MK183CL2U/E07
BUT before you order that $160 item, I personally would check the start relay and start capacitor to make sure it isn't one of those, instead of the compressor.
Jan 07, 2012 | Samsung RS2630SH Side by Side Refrigerator
My Bostitich air compresser wont start to refill
I would suspect that your pressure switch is defective and should be replaced
Dec 04, 2009 | Air Tools & Compressors
Craftsman Air compresser trys to start, but just flutters.
if this model has a starter capacitor on the motor it is probably at fault
Nov 11, 2009 | Air Tools & Compressors
Fridge not cooling contents
YOU DIDN'T STATE WHAT MAKE YOUR UNIT IS, HOWEVER IT SOUNDS LIKE IT IS THE OVERLOAD COMPONET THAT MOUNTS ON THE COMPRERSSOR TO START IT. TRY THAT FIRST IT IS THE MOST COMMON.
Dec 02, 2008 | Refrigerators
Not cooling
The clicking you are hearing is your overload on your start system sounds like your compresser start ststem is out..or your compresser is locked up the only way to tell is to ohm out the compresser idf you dont have a meter you can install a start kit like a Supco Pro41 or a RCO410 or a factory replacement and see if it starts up the compresser.. Have you cleaned the condenser at all ??? although this will not fix the compresser it can be a cause of overheating..The part Number you need is a 2188831 for the factory replacemenet ($22.56)the supco parts part number SU RCO410 ($15.00) the Pro41 is part #
SU PRO41 ($17.97) you can get them at your local parts house they are all easy to change or if you dont have a parts house close you can oder it on the web at www.apdepot.com Hope this fixes ya
Feb 17, 2008 | Whirlpool ED0GTQXMQ Side by Side...
Whirlpool ED22COXHW02 side ny side not freezing or cooling
What you are hearing the is the overload snapping open you have one of 2 problems your start system(relay/overload) for the compresser is out and will need to be replaced or your compresser is shot you will need to replace the start kit first most of the time it starts up the compresser just fine but if not the compresser will have to be replaced
Jan 25, 2008 | Whirlpool ED2NTGXL Side by Side...
Refrigerators Logo
37 people viewed this question
Top VinoTemp Refrigerators Experts
Ilia Bichin
richie46
Are you a VinoTemp Refrigerator Expert? Answer questions, earn points and help others
