Does as erbauer R11W38 have a reset button? its jammed
It was cutting wood and hit a bit of metal, now won't work
SOURCE: automatic document feeder won't work
Follow these steps to perform a partial reset of the product:
>Disconnect the power cord from the back of the product.
>Press and hold # and 3 .
>While holding the # and 3 buttons down, reconnect the power cord to the back of the product.
>Try the job again
If the problem persists please visit the link below:
Automatic Document Feeder (ADF) Does Not Pick Up Paper
and follow the troubleshooting steps.
Posted on Jul 28, 2011
  • 3 Answers
SOURCE: The 'boost' button on my
Good Morning drlesleyanne. The issue you describe will down to the PCB inside the push button controller. If this does not send the correct signal to the processor box it can cause the unit to 'fail safe' and this is why the unit needs a power reboot. The remedy to this is to replace the push button control itself and once installed should allow the shower to work correctly again. All our digital products have five year guarantees, so you can always call our Customer Service line on 01959 560010 and they will replace this for free.
Kind Regards,
The Aqualisa Team
Posted on Aug 02, 2011
Testimonial: "Very helpful reply thankyou"
  • 7993 Answers
SOURCE: My Grundig S350 won't turn
Its Deluxe Version the S350 DL can use two types of batteries: D-size or AA. Inside the battery compartment there is a switch to select the size in use. If you use the AA sie batteries, they will not hold in their locations unless you lower a flap and secure them.
Have you tried to power the radio with the adaptor?
Posted on Aug 28, 2011
TechyDrood
  • 2072 Answers
SOURCE: Brand new archos arnova 10 tablet. It is stuck on
To hard reset a tablet, hold the power button down until it shuts off then press it to turn back on. Should take about 5 - 10 seconds for the device to power off.
Posted on Oct 16, 2011
  • 15 Answers
SOURCE: I noticed that most changing tables are made out of wood, why is that? What's wrong with metal?
Of course, nothing is wrong with metal, but I think thatwooden furniture gives an impression of softer look, that matches the feelingsparents have towards a new baby. If your search the internet for "Metal ChangingTables" you will find many types.
Posted on May 29, 2012
Qualcast manuals
Unplug it and look inside the shredding blades, especially around the spot usually near the center, where there is a pressure button. When paper hits it, it starts shredding. Chances are some pieces of paper have jammed just over it stopping paper from hitting it and switching it on. I have had to use long tweezers to work the jammed bits out... Once clear it will work again. Also using shredder oil every 50 sheets through will help it cut easier , and jam less frequently. Do not put too many sheets through together in a bunch. No staples...
Aug 25, 2014 | Office Equipment & Supplies
Cars player
Try this hold button 5 sec longer. If not DVD may be jammed in player. Some players have a release pin hole near the DVD draw. You will need a long wood/plastic pin to trigger it. Do not use metal pins. (shock)...
May 29, 2013 | Disney DTD1363-CAR 13" TV/DVD
My screen won't work.
Hit the reset button on the back, lower right. If you can get the "settings" icon open and hit "calibrate" that will fix it too. I would still calibrate the screen after you hit the reset button to help prevent this from happening again.
Jan 09, 2013 | Visual Land V-Touch Digital Media Player
Power doest not come on
Assuming ,that the outlet that you plugged your cd player in is working properlly.Try taking the cover to the cd player off. There should be a fuse, somewhere on the circuit board. Check to see if the fuse is blown.If it is replace the fuse, with the same type fuse. There should be writing on the metal part of the fuse,which will tell you the voltage,an amperage of the fuse. If it is blown, take the fuse to a Radio Shack store, they'll be able to match up the fuse for you. There might be more than one fuse, on the circuit board. Also,are you plugging the cd player into a G.F.I. outlet? The outlet could be tripped. If it is, hit the reset button.This should reset power to the outlet. There might be other outlet's that are wired into the G.F.I. If the G.F.I. is tripped then those outlet's won't work until you hit the reset button.
Jun 02, 2012 | Audio Players & Recorders
My bit in my drill is stuck into a large tree stump... that had been cut close to the ground. How can I get the bit unstuck? My dewalt drill is unable to drill in & drill out.
If it's a twist bit try putting a vice-grip pliers on the end and turn it so the fluting pushes the bit out. If it won't move or if it's a spade bit you'll have to split the wood around the bit. You may or may not be able to do this with the offending part of the stump in the ground. Using a wedge, drive it into the stump near but not next to the bit so you don't damage the bit. Don't drive the wedge flush into the stump or you may get the bit out and then have the wedge stuck. Worst case, carefully use a chainsaw to cut out the stump so you can split the wood around the bit.
Feb 01, 2012 | American Tool 6 each: Irwin Metal Drilling...
I put too much paper in and it jammed. I cannot pull the paper out and it won't go in reverse. How can I take it apart to clear the jam?
1) unplug shredder
now there are two screws on the back and two underneath the edge on the front (you need to open the door to access them) remove all four screws and lift cover off towards the back( it helps to back the machine up to a table to support the top so its not hanging by the wiring)
if you still cannot access the jammed item,
remove the metal guards there are screws on the side as well as on the top (i think 4 total) just don't take out the screw with the spring on it that's something else you don't want to play with right now. I will mention that when you take off the guards you will likely discover that there is a lot of shredded paper still jammed up in the blades, a shop vac works pretty well hear, but so will a brush (might as well clean that out as long as you have the cover off.)
avoid using direct force when trying to remove jams, you can break things that way, you may want to try and cut the jammed material free and removing the last bits with a pair of needle nose plyers.
May 19, 2011 | Fellowes 220 Powershred Strip-Cut Shredder...
I have a efco 165 chainsaw and for no reason i will be cutting good clean wood and it will just go dull. there's no cut marks inside like it hit metal. it has been doing it since it was new.
It seems like they supplied the machine with an inferior standard chain, replace the chain with a good brand and see if that solves the problem. (Chain saws are not too fond of cutting dry wood, they do far better in wet, green wood).
Apr 04, 2011 | Garden
jasbo
jasbo
