Question about LG enV VX9900 Cellular Phone
Dials in my pocket
The phone origionaly comes with a screen lock where you have to push ok before you can dial any numbers... well that happens all the time in my pocket. is there any way to change it from the ok button to like a 4 number combo so it stops dialing in my pocket?
Alright go to the menu then press 9 and 6 two times from the internal keypad it will ask for the unlock code now unless you have read the manual (who does) you dont know that its the last four digits of your phone number(if the phone has service which i assume it does) and press 4 to lock the phone. Now from any menu (interior and exterior) the phone can do nothing but call your ice contacts (who i suggest setting to the people you call the most to avoid having to unlock then relock the phone every time you need to call them) unless you put in the last four digits of your phone number (this code can be changed from the same menu you press 9 6 6 to get to) Glad i could help
Posted on Jan 14, 2009
Number code breakers
hahaha it is called a pocket dial sometimes when the phone is in your pocket ...pressure can cause it to dial a number...happens to lots of people...not to worry
Nov 16, 2013 | Electrical Supplies
How do i reprogram my speeddial numbers on jazz 4400?
Hello.
From NorStar Support:
To Program Personal Speed Dial Numbers: (Numbers 71 - 94 only.
1. Press the Feature button, then * 4
2. Enter the 2 digit code (71 - 94). that you want to assign to that phone number
3. Enter the telephone number, then press the OK softkey
4. Display will show: "Entry xx stored"
If the above doesn't work, try:
  1. Press [Feature] [*] [4]
  2. Enter a two-digit code from 71 to 94.
  3. Specify the external line by pressing a line button, a line pool button, or the intercom button. If you don't specify the external line, the system automatically chooses a line for the call.
  4. Dial the telephone number you want to program (up to 24 digits).
  5. Press [Hold].
  6. Record the code and number you have just programmed.
Hope this helps.
Feb 02, 2011 | NorStar Jazz Plus 4400 Corded Phone
How do i keep samsung smooth from pocket dialing?
Pocket dialing is usually less of an issue with flip phones, but if you are having issues with your SCH-U350 pocket dialing, you can lock the keypad by holding down the zero (0) key for a second or two. A message should come up telling you that the phone has been locked.
Jun 03, 2010 | Samsung Smooth SCH-u350 Cell Phone
It unlocks easy in my pocket and calls people
ENV3 right? two options: option 1:go to settings and tool from the main menu (flipped open and pressed ok) Go to 6: Phone settings. Click security. Type in the last four digits of your cellphone #. Go to 4: Lock phone now. To unlock it: type the last four digits again. If you want to lock it on power up. Go to 3: Phone Lock on that same menu
2nd option: Click over on the keypad surrounding the ok button. Key guard will have a picture of a lock. Click OK on key gaurd. Go to 3: Unlock options. Go to press once or press twice. Then it will unlikely to dial numbers in your pocket. Go to 2: Keygaurd Timer. Set it for 7 seconds. Then, click cancel. Go to 1: Lock Now on the same menu for instance results.
Dec 02, 2009 | LG enV3 VX9200 Cell Phone
When i push the numbers they don't seem to be registering, or going through because we can't dial out but calls can come in
The phone might be getting old. This happens alot on newer phones. I go thru 1 set of phones a year lately.
Oct 21, 2009 | Vtech IA5854 5.8 GHz Cordless Phone
Kaypad lock won't go away.
If you are not able to unlock you mobile with the unlock key press. Try this trick
Just dial the emergency number when the phone keypad is locked.
Dial 911 or 911 it will start dialing. Then you can cancel the call and you will find your keypad unlocked.
Don't forget to give feedback
Aug 30, 2009 | Kyocera Strobe K612B Cellular Phone
Key lock code
If it is asking you to put a code in to unlock it, usually it is all zero's, 1234 or the last 4 of the assigned phone number. If it's just locked to prevent numbers being dialed while in your pocket or something like mine does, you have to look in your manual to see what buttong to push and hold to unlock or sometimes what 2 button combination unlocks it. Good luck!
Jan 02, 2009 | Samsung SGH-D900 Cellular Phone
Envy 2 dials phone numbers accidentally- need to set key guard
On the front keypad, press the ok button until you have the option to select contact list. Scroll down that list until you see keyguard settings. Press ok to enter keyguard settings and then go to option 2 - unlock options. Select two step unlock. This will force the user to press "ok" and then "clr" in order to dial out. This has resolved the problem for me...Good luck.
Dec 03, 2008 | LG enV VX9900 Cellular Phone
Lg envy 2 dialing while in my pocket
you need to go to menu then settings then security then keypad lock it should ask lock now or auto lock wich will lock keypad after about 30 seconds with no activity,after locking keypad when you push a button it should tell you to push somthing like menu star to unlock this should stop your phone from dialing in your pocket
Sep 24, 2008 | Cell Phones
Pocket dialing?
Hi, You can press '-' soft key in the top centre followed by '*' key quickly to lock it. To unlock follow the same.
Mar 29, 2008 | Motorola Mobility SLVR L7 Cellular Phone
LG enV VX9900 Cellular Phone Logo
126 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
