Question about GE WBSR3140D Top Load Washer
Oil leaking from underneath agitator into the tub of the washer
Looks like transmission is leaking, try changing the seal
Posted on Jan 13, 2009
Oil in the bottom of washer
The oil is leaking out of the agitator gearbox. The water is coming from the seal on the agitator. I think the gears are badly worn..
Nov 19, 2013 | GE Washing Machines
Oil/grease leaking into tub. Speed Queen AWM492W top load washer. How to fix?? Thank you.
Check to see if the oil is coming from under the agitator. If it is replace the transmission. If it is not check to see if there is a grease spot inside the was tub.
Dec 29, 2010 | Speed Queen AWS75NW Top Load Washer
Washer leaking oil
If the oil is leaking at the top of the tub, around the agitator, you will need to dig out and repair the brake and drive tube. If it is leaking at the bottom of the washer, about a quart, you will need to replace the gearbox.
Sep 05, 2010 | Kenmore 24032\24036 Top Load Washer
Small puddle of water underneath washer when wash cycle was completed.
That could be 1 of a couple things.
1) During the agitate cycle... some water could've made it out of tub.
2) Possible Tub Crack (or overflow line)
3) Check your inlet lines
I would run it again watching it very carefully to determine if any of these are the problem.
Dec 02, 2009 | Whirlpool LTE5243D Top Load Stacked...
WASHER LEAKS WHEN IN WASHING MODE
The reason for the leak is probably the "boot". It is a rubber seal that seals around the agitator shaft. It costs about 20 dollars to replace. Drain washer dry! you have to open the top of the whole washer (the normal door is in the top.), remove the agitator by pulling straight up. you will see about 8 bolts in the bottom. remove them and pull the "tub" straight up. You should see the boot and how to remove it from there.
Thank You for contacting Fixya.com
Aug 09, 2009 | Kenmore Washing Machines
Kenmore 80 series leaking....plastic tub cracked on the bottom
if you removed the large nut (round with four notches cut in it ) then tub should be free. sometimes these "rust together" on the hub. wd40 and a hammer to knock it free. try rocking the basket to break free. you did remove the tub ring(white plastic part on top), right?
Apr 28, 2009 | Kenmore 22422 Top Load Washer
Oil ring left in tub and on agitator
If its oil your transmission is leaking oil. Time for a new washer.
Mar 21, 2009 | GE WJSR2070B Top Load Washer
A penny fell underneath the agitator & went underneath inside the tub
remove 2 rubber plugs on each side of lid remove the screws underneath lift top up remove the plactic ring around tub top by pulling up on clips along top edge remove the spring on left attached to ring lift ring off remove agitator again lift inner tub up and out ..when reinstalling inner tub be sure it drops completely in so the center gear drops in place
Sep 07, 2008 | Fisher Paykel EcoSmart GWL15
HELP!! Leaks!! Leaks!!!
the inner tub and outer tub has a seal under the agitator. this must be replaced. use a spanner or a large channel lock plier to remove the nut. seal is underneath it.
Sep 04, 2007 | Frigidaire GLWS1233A Top Load Washer
Maytag top load washer leak
underneath the agitator is a graphite seal ring and nut that seals the inner tub and the outer tub. a suitable spanner wrench or a 6 inch channel lock plier will remove this locknut. replace the seal.
Sep 02, 2007 | Washing Machines
GE WBSR3140D Top Load Washer Logo
124 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
