INSTRUCTIONS FOR PANASONIC RP-WF820T HEADPHONES
RP-WF820T RF STEREO TRANSMITTER
2 Suggested Answers
Grubhead
  • 5056 Answers
SOURCE: need new earpads for my
See my tip on dealing with dodgy cables/plugs on headphones. There's a website that sells them at the bottom of it. Just click my user name to find it.
Posted on Feb 08, 2011
Hello. I have a problem with my headphones Panasonic Rp Djs200. When i connect them to my laptop is not working. I have windows 10 and all the updates. What should i do?
Could be a hardware problem if the driver rollback/ reinstall and troubleshooting facility hasn't worked.
Presumably the headphones work on other appliances and known good speakers or headphones consistently don't work from the headphone socket?
It probably needs to visit the laptop doctor...
Jun 30, 2016 | Panasonic Rp Djs200-W - Headphones
Wireless rf transmitter requires dc3v transformer. Can I use a 9v transmitter instead?
if you want to burn up the headphones and buy new ones,go ahead,
if a car uses regular gas,do you fill it with diesel???
Jun 04, 2015 | Sylvania Quiet TV Wireless Stereo...
HTF600
probably it's broken wire inside.....
it can be also because you are using it with wrong device....
try to connect your earphones to something else.... like stereo, computer, mp3 player.... or cellphone....
if you still have same problem, then it's because of broken wire....
if it's playing on some devices, and don't playing on some others, that means that conectors are either broken, oxided, or not compatible
Jan 13, 2014 | Panasonic RP HTF600 - Headphones ear-cup -...
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
NEED INSTRUCTIONS FOR HOOKING UP WIRELESS HEADPHONES FOR VIZIO TV
From the manual:
1. Plug the stereo audio cable into the headphone jack of your audio
source (e.g., stereo, TV, CD player, DVD, etc.). If your audio source
has two RCA output jacks instead of a headphone jack, use the
supplied Y cable to connect your headphones to the two (red and
white) RCA jacks.
2. Connect the other end of the stereo audio cable to the AUDIO IN
socket at the back of the recharging cradle/transmitter.
3. Connect the AC/DC main power adapter to the DC IN power
supply socket at the back of the recharging cradle/transmitter. Then,
connect the adapter to an electrical outlet.
Important: This power unit is intended to be correctly oriented in a
vertical or floor mount position.
Manual:
http://audiovox2.info/docs/common/AW772/AW772_OM.pdf
Jun 10, 2011 | Acoustic Research AW-772 Headphones
Panassonic PR-HTX& head phones: both sides of the head phone work at the same volume. but with no stereo. all sounds come equally through both sides. I've opened them up and all the wires are...
That particular set of headphones are definitely a stereo set. This means the problem is with 3rd party hardware. If your using a jack adaptor it will need to support stereo. If you are using the headphones with your computer you need to make sure that the sound card and software all support and have stereo enabled. Manufacturer will not make a mistake like wiring in-correctly ;)
Feb 02, 2011 | Panasonic RP-HTX7 Consumer Headphones
Hey I have lost the Ear pad to my panasonic rp-htx7 and need to know where i can replace it! It's only a clip on thing so im hoping it shouldn't be hard
See my tip on replacing dodgy cables plugs on headphones. Just click my name. Link to a site that sells them at the bottom.
Nov 23, 2010 | Panasonic RP-HTX7 Consumer Headphones
RP-WF940T instructions
Try the Panasonic website they have free user manuals to download.
Mar 06, 2010 | Panasonic RP-WF930 Consumer Headphones
565 people viewed this question
 Grubhead
Grubhead
