Question about Sunbeam 2350 Stand Mixer
Motor runs but beaters do not turn.
How do I disassemble the motor unit in order to gain access to the drive gears and repair this mixer?
    Sergeant:
    Champion:
  • 341 Answers
I challenge you to do-it-yourself...you can do it. Just be careful when removing it apart. I advise you to take a video or get some snap shots while you are at it. This way, if some springs snaps out, I assume that you took a picture of it already.
Usually those plastic gears are the problem. Goodluck!
Posted on Jan 13, 2009
How to replace motor in kitchenaid artisan mixer
Sounds like a worm gear problem to me, it's impossible for the motor (armature) to move far enough to not drive the gear. There are driving pins in the system from fuse gear to paddle.
1) in the fuse gear
2) inside gearbox above planetary joining shaft to bevel gear
3) through planetary and shaft
There is also one joining the little gear inside the planetary to the shaft, doubt you'd break that one though.
Jun 30, 2014 | KitchenAid KSM150PS Artisan Series Stand...
The mixer motor runs good but beaters turn slowly and will not turn when the beaters are under load. Is this a clutch, gear or what? Any ideas? Do you think it can be fixed?
I found out by marking the shaft and gears with a magic marker that the main shaft that drives the sun gear was slipping. My cure was to drill a 5/32 hole a 1/4 inch down through shaft and drive a 5/32 roll pin through it and it solved the problem. See my picture.
Nov 21, 2010 | KitchenAid KT2651X Epicurean Stand Mixer
Beaters will not move
You have probably stripped a gear in the gear housing. Here is the breakdown of the gearbox:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212010.pdf
The newer "more improved" mixers use plastic gears and they can't take the beating, no pun intended, and fail.
The good news is that the most likely gear to fail is cheap. Here it is on amazon.com:
http://www.amazon.com/KitchenAid-W10112253-Worm-Gear/dp/B0006HLAVA
http://www.misterfixit.com
Mar 25, 2010 | KitchenAid KSM150PS Artisan Series Stand...
The mixer will not start. Power gets to the unit and the blade does turn manually.
Hi - I assume you mean to say that the motor turns on, runs in all speeds but no power is being transferred to the planetary head and beaters?
If this was preceeded by some intermittent run conditions like occasionally skipping beaters and some louder than normal or different run noise then it's likely that the nylon Worm Gear has lost teeth and is no longer making contact with the motor gear. It is part of an assembly which is directly coupled to the motor. Disassembly is required to get at this part and some mechanical skill to replace it. If the mixer's a few years old and/or gets a lot of use, the gear grease should be replaced too. For the gears and other parts, including the grease - check out http://www.goodmans.net/get_dept_933.htm They seem to have just about every part needed and fair pricing. Appliance Parts Pros is another source of parts and diagrams. Warning - mixer disassembly is a medium complexity task and could ruin your day...
DZII
Jan 02, 2010 | KitchenAid K45SS Classic Stand Mixer
Motor runs, beater stopped rotating. Some gear sounds heard before it stopped. Beater will not turn at any speed setting.
drive gear or shear pin stripped. Common on this model. Return to repair centre. Expect to pay approx $150.00 to repair, sorry.
Sep 14, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Leaks oir or grease at shaft where beater attaches
eaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
If you still feel as though the mixer is in need of service, you may locate Kitchenaid certified repair centers through the following link: http://caservice.kitchenaid.com/
Jul 15, 2009 | KitchenAid K45SS Classic Stand Mixer
The motor runs but the beater doesn't turn, as though the gear drive has failed. How do I take the mixer apart to check the gear drive?
http://www.fixya.com/support/t636606-kitchenaid_ksm90_stand_mixer
Kitchenaid service manuel gives step-by-step instruction on a stand mixer.
Sep 07, 2008 | KitchenAid K45SS Classic Stand Mixer
Regarding the Sunbeam Mixmaster (model 2346): How do I remove the front cover of the mixer so that I may reallign or replace the beater gears?
Pry the beater release button out with a screwdriver. There are two screws underneath it and one under the motor housing between the the beater holes. This will allow you to remove the chrome front cover, but not the motor and drive assembly. Getting to the part that contains the gears requires complete disassembly of the mixer. It is not designed for service, and requires patience and a variety of tools to disassemble.
It has a metal worm gear and plastic drive gears. If the beaters are out of alignment, then one or both of the plastic gears are stripped and the mixer is junk. Repair plus shipping costs equals the price of a new mixer. This is the weak point of these mixers and a fundamental flaw in an otherwise robust and sturdy design. It is definitly not the same mixer *********** bought 30 years ago.
Jul 18, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Motor runs but the beater does not move
you most likely stripped the plastic gear (Worm gear???).  This gear is designed to fail to prevent the motor from burning out under EXTREME loads (i.e. when a metal piece falls into the bowl). The plastic gear is much cheaper than a new motor.  Look around on this site to see how to get at/repair the gear.  I've found many parts on eBay.com and also PartSelect.com.
Dec 16, 2007 | KitchenAid KSM90 Ultra Power Series Stand...
Motor runs, but beater doesn't turn
Ok, do you want to know how to disassemble? i just inherited a kitchenaid mixer from my brother and it had the exact symptoms. First, using a hammer and pin punch, drive out the pin that holds the beater mechanism. Pull off the mechanism and remove the chrome ring that is above it. You will see about 6 screws under there, remove them. Next remove the 2 screws at the opposite end of the bottom of the motor housing. Now carefully and evenly separate the motor housing. The motor will come off completely. Lay the motor aside being careful not to pull the wires too much. you might want to support it with a box or something to rest it on. Ok now you will see a bunch of grease on the gears. Put the grease in a paper cup as you will need it again. Wipe off the gear assembly and examine the teeth on the gear. chances are there is a spot where there is no teeth at all. Replace that part, put the grease bak on the gears and reassemble in the reverse order. I did mine in no time, just pay attention to what you are doing. The chrome ring is a little tricky to get it back on but it will stay if you keep trying. You might have to roll it against a hard surface to bend it inwards to make it fit tighter. Good luck and let me know if this helped you out!
May 20, 2006 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Sunbeam 2350 Stand Mixer Logo
245 people viewed this question
Top Sunbeam Food Mixers Experts
Oloyede Monsuru
Oscar Netto
Oscar Netto
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
