Question about Dell 922 All-In-One InkJet Printer
My printer icon on taskbar has a yellow triangle and wont print a
My printer icon on task bar has a yeoolow triangle and wont print says printer cant communicate w/ computer
  • Anonymous Jan 15, 2009
    My printer
  • browntk Jan 15, 2009
    My printer has a yellow ! in the system tray and the printer won't print. I have reloaded the driver and still the printer does not print
    Problem Solver:
  • 16 Answers
If you haven't already done so, might I suggest you uninstal the printer and re-instal as per the instalation manual.
This normally resolves these issues. Also make sure this printer is set as your default printer.
Hope this helps
G
Posted on Jan 13, 2009
  • lintrathen Jan 28, 2009
    To Guest....
    Did you go into the control panel of the computer and click on the printer button to see if your printer is set to "default printer"?
    G
How to add printer to taskbar
Hover your mouse pointer over the printer icon, hold down the click button and drag the icon to the task bar. The release the click button.
Apr 26, 2016 | Office Equipment & Supplies
Taskbar and home icons are missing from msi u180 netbook, how do I restore
Try hitting ctrl and esc. You may have inadvertently hidden your task bar.
Apr 03, 2013 | MSI Computers & Internet
Task bar at bottom with font size on it has gone
The task bar is an important part of the Windows experience. Not only does it contain a variety of information including what time it is and how much battery life is left it's the way most Windows users open programs and documents. As such, the task bar disappearing is a stressful thing, but fixing this problem on your own is possible.
Auto-Hide Sometimes you may think your task bar has disappeared, but it's really just been set to "auto-hide." Move your mouse to the bottom of the screen and see if it pops up automatically. Then check all four sides of the screen. If the task bar was simply auto-hiding, disable this feature by right-clicking the task bar, clicking "Properties" and unchecking "Auto-hide the Taskbar." b> Reboot b> If your task bar disappears, and auto-hide isn't the culprit, the first thing you should do is reboot your computer this fixes the problems in most instances. Only one problem: because your task bar disappeared you can't access the "Start" menu in order to shut down the computer. Instead press "Alt," "Ctrl," and "Delete" at the same time and press "Restart" in the window that pops up after doing so. Your computer should restart, and in most cases your task bar should come back when it restarts. b> More Options b> If rebooting doesn't fix cause the task bar to reappear, your computer might have a problem starting explorer.exe, the program that displays the task bar and desktop icons in Windows. Press "Ctrl," "Shift," and "Esc" at the same time to bring up the System Manager. Then click "File," followed by "New Task (Run)" and type "explorer.exe" in the dialogue box that pops up. You now have your task bar and desktop icons back. Reboot to see if they stick around after rebooting. If not, repeat the process in the above paragraph. When you have you task bar back click "Start," then "Programs," then "Accessories," then "System Tools" and then "System Restore." Restore the computer to a time when everything was working fine by clicking that date on the calendar. Reboot to see if this fixes the problem. If none of this brought back your task bar permanently it may be time to run a repair install. Change My Task Bar b> In Windows operating systems, the taskbar shows your currently active windows and programs, shortcuts to your favorite programs, the time, your volume control, active programs and the "Start" button. You may want to change the taskbar so it has a different look or to customize it to suit your needs when using your computer. Windows XP users have fewer options than Windows Vista or Windows 7 users, but all operating system owners can make changes to the taskbar.
Right-click in your taskbar. Left-click on "Lock the taskbar" if it is currently checked. Otherwise, click back onto the taskbar. Click on any empty area of the taskbar. Drag the taskbar to the position (bottom, top, left or right side of the screen) you desire, and release it. Re the taskbar by moving your cursor to where the taskbar ends. Your cursor will change to a two-way arrow. Left-click and drag the taskbar until it reaches the you want. Move your cursor over the series of separator bumps between the Start button and the Quick Launch menu, and the Quick Launch menu and the active programs section of the taskbar, to alter the of the Quick Launch menu and the active programs area. Right-click the taskbar, and left-click on "Lock the taskbar" once you've completed the changes you wish to make. b> Change Taskbar Options b> Right-click on the taskbar, and left-click on "Properties." Modify the taskbar settings so that it appears the way you like. You can decide whether to show the Quick Launch menu (a series of icons for your most commonly used programs), to show thumbnails for your active programs in Windows 7 and Windows Vista and to group similar active programs, and to automatically hide the taskbar or to always have it on top of other windows. Click on the "Notification" tab in Windows 7 or Vista to modify the way the notification area to the far right appears. Stay on the taskbar tab in Windows XP. Hide inactive icons, and decide which information to show, including the clock or the volume, power and network icons in Windows 7 and Vista. Click on the "Customize" button to specify which programs or notifications should always show, never show or grow inactive with disuse. Click on the "Toolbars" tab in Windows 7 or Vista to specify which toolbars you wish to see in the taskbar. Your options will vary according to the programs you have installed on your computer but may include the Quick Launch, address bar and links toolbars. Click the "Apply" button, then "OK" once you have made the changes you desire. Hope this helps.
Jan 16, 2013 | Computers & Internet
My ink cartridges say full but wont print. how can i rehydrate them
->Make sure the printer is connected to your computer.
->Run a print head alignment and cleaning. Misaligned or dirty print heads affect printing quality. Click on the Start menu icon in the computer task bar. Select Control Panel, then click Printers and Faxes. Click on your printer icon and then select "Printer," "Preferences" and "Maintenance." Select "Run print head alignment" and execute the alignment. Select "Clean print heads" to perform this operation.
->Open the access panel door and look at the roller devices to see if a page has been jammed in between them. If so, pull on one end of the page to remove the jam. Try to print your page.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/printer-support/
Nov 19, 2012 | Lexmark X1150 All-In-One InkJet Printer
WHEN I WONT TO PRENT MY PRENTER TOLD ME THAER IS NO SOFTWER MY PRODUCT : oPTRA t 610 WHEN I WONT PRENT I TURN OFF & ON oR OBEN THAE DOOR
Default Printer Issue
The wrong printer is set as the default. See the image below for an illustration.
What to do
Open the Printers or Printer and Faxes folder and locate the correct printer icon. To do this:
    1. -In Windows XP, click Start > Settings > Printer and Faxes (or Start > Control Panel > Printers and Faxes).
      -In Windows Vista, click Start > Control Panel > Hardware and Sound > Printers.
    2. Right-click on the printer icon, and click Set as Default Printer. A check mark displayed above the printer icon now identifies it as your default printer.
    3. Try printing again.
Topic 3: Printer is "Offline"
The printer is set to Offline and the printer icon appears washed-out. See the image below for an illustration.
What to do
  2. Right-click on the printer icon, and select Use Printer Online.
Topic 4: Printer is not Ready
The printer is in an "Intervention Requested" state (e.g. paper jam, paper out) but no Windows print error notification message is displayed.
Explanation
The print job cleared the print queue. This means the print queue icon has disappeared from the notification area ('systray') of the task bar. The printer is holding the job, however, until the the printer is returned to a ready state.
What to do
Check the printer LCD, or operator panel menu, to verify that the printer is in a ready state. If not, return it to the required status.
Topic 5: Printer is Paused
The printer or print queue is paused and the print queue icon remains in the notification area ('systray') of the task bar.
Explanation
This is typically an end user error. Dragging the mouse cursor over the print queue icon in the notification area will reveal (1,2,3) document(s) pending for (User name).
What to do
    1. Double-click on the print queue icon to open the print queue. (This may also appear as a small printer icon in the lower-right notification area of the task bar.)
    2. Click on Printer in the upper left-hand corner of the menu bar.
    3. Is there a check mark next to Pause Printing?
      -If yes, click on Pause Printing to turn off this Windows feature.
      -If no, confirm that there is a check mark next to Set As Default Printer and make sure Use Printer Offline is not selected.
Topic 10: Windows Print Spooler Issue
A problem with the Windows print spooler is preventing successful printing.
What to try
Stop and start the Windows print spooler. To do this:
  • -In Windows XP, click Start > Control Panel > Administrative Tools > Services, click on Print Spooler, click on Stop the service, and then click on Start the service.
  • -In Windows Vista, click Start, type services.msc in the Start Search box, and then click services.msc in the Programs list. Right-click on Print Spooler, and then click Stop. Finally, right-click on Print Spooler again, and then click Start.
Remove the first print job from the print queue. To do this:
  2. Click on the first job listed so that it is highlighted.
  3. Click on Document in the top menu bar.
  4. Click on Cancel.
  5. Click Yes when you see: "Are you sure you want to cancel the selected jobs?"
Click here for illustration.
Topic 11: Other Issues
Other possible causes of a print job not printing include:
  • -USB connection problem if locally connected only.
  • -Firewall issues preventing communication.
  • -Workplace virtual private networks (VPNs) preventing communication. VPN tunneling may be required to ensure successful communication. Enabling this feature may require network administrator approval and assistance.
  • -Document formatting.
  • -Driver settings.
  • -Application-specific issues relating to the application's Printer Setup.
Topic 12: Last Resort
If you have tried all of the above suggestions to no avail, try the following:
  1. Reboot your computer and try printing again.
  2. Turn the printer off and on, and then try to print again.
  3. Install a different printer driver, e.g. PCL, PostScript, HBP, or XPS driver.
Dec 14, 2010 | Lexmark Optra T610 Laser Printer
My HP C4480 Printer has a print job whic says ''Deleting - Printing'' and it wont budge. Can you give any suggestions?
right click the taskbar and select Task Manager while the printer window which says 'Deleting Printing is open'. In the Task Manager select Applications tab and right click the task that corresponds to the printer window, then select 'Go to process' and press the 'End Process'' button.
Jun 20, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
My printer wont print since i cancelled a print
on your computer in the task bar click the printer icon and erase the file you wanted to print once it erased it should work
Jan 24, 2010 | Lexmark Z2300 InkJet Printer
I just put in a yellow cartridge. Previously the printer was working just fine. Now it is showing an error code: 10.92.00 So I put the old yellow cartridge back in. The same error code now appears? He
Hi ron0911170:
This is your problem.
10.92.YY CARTRIDGES
NOT ENGAGED
alternates with
Open and close
front door.
The cartridges are not engaged,
poor primary transfer bias contacts,
defective high-voltage supply, or
control signal errors.
YY Description:
00 - Black print cartridge
01 - Cyan print cartridge
02 - Magenta print cartridge
03 - Yellow print cartridge
1. Open and close the front door to fully
engage the cartridges.
2. Reseat the print cartridges.
3. Check the printer primary transfer bias
contacts to the transfer unit. Clean if
dirty. If the contracts cannot be
cleaned or they are damaged, replace
the transfer unit.
4. Replace the high-voltage power supply
PCB.
5. Replace the DC controller PCB.
Hope this helps
May 24, 2009 | HP LaserJet 3600n Printer
I've lost my toolbar on my acer aspire one netbook
Press and hold Windows Logo Key + Press the "E" key
Type Control Panel
From here you can address your Display and Taskbar issues.
For the task bar:
Click on Taskbar and Start Menu Properties
Uncheck Lock the taskbar, Auto-Hide the task bar, and then click apply and ok
For the desktop icons:
Click Display
Click the Desktop Tab
Click the "Customize Desktop" Button
There you can place a check next to the icons you wish to show.
Let us know if you have any issues after changing these settings.
Apr 16, 2009 | Acer Aspire One Netbook 8.9" Notebook
Lan Card Icon not showing in Taskbar
I think you need to reset the setting for showing on task bar, as in de-select the option, click ok, and then go back and select to show in task bar.
If this does not work, you system tray on the taskbar may be hiding some icons.
Mar 04, 2009 | Dell Inspiron 1100 Notebook
Dell 922 All-In-One InkJet Printer Logo
525 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
