Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
My honeywell Chronotherm IV Plus goes into Recovery mode every morning. Don't have the manual. What can I do?
Destinova
  • 46 Answers
SOURCE: honeywell chronotherm IV plus controller
Sorry to hear that, not to be the perveyor of the obvious but for everyone else.. ALLWAYS check and make sure your pins are straight when you do a battery change. OMG they charged you 300 for a thermostat? im very sorry
Posted on May 28, 2008
boanhtgclg
  • 34 Answers
SOURCE: Fan Honeywell Chronotherm IV T8600
sounds like the fan has been programmed to come on during that time. run through your programming settings and make sure the fan is set to auto for all the times.
Posted on Nov 12, 2008
  • 8 Answers
SOURCE: cooling temperature will not below 70
controllers more than likely on a memory lockout... kill the power and take the batteries out of it... leave it for 60 seconds and try again... unfortunately you are probably going to have to replace the controller, sorry
Posted on Jun 16, 2009
  • 587 Answers
SOURCE: how do I program my honeywell chronotherm IV Plus
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Posted on Feb 28, 2010
  • 415 Answers
SOURCE: honeywell chronotherm iv fan keeps running even
Assuming you have the fan switch of your thermostat in AUTO, it sounds like a stuck Fan Relay. If the fan relay is stuck, your fan will continue to run as long as there is line voltage being fed to your unit. This relay could be an independent component or it could be an integral part of your control board. Have an experienced, qualified service technician check it out.
Posted on Mar 19, 2010
Chronotherm 4 plus
change the batteries in the thermostat
Mar 21, 2014 | Honeywell Heating & Cooling
I can't turn my Chronotherm IV plus off! Can anyone help me. It is going to cost a fortune
Depends what model number you have. The older models had problems. So Honeywell upgraded the model several times. When you say, cant turn it off. If that means the heat will not shut off then you have no choice to replace it, also if the heat,cool, off,switch will not work it is not repairable. Go to Home depot or menards and pick up a thermostat. Find somebody with some handy man skills and they can replace it for you.
Nov 28, 2011 | Honeywell Programmable Thermostat Heater
Honeywell Chronotherm iv fan keeps running even when heat and cool turned off. How do I turn it off?
To turn the fan off, press the "fan key" until it says "auto". This will turn the fan off. When the programs scheduled, changes, the fan will go on again. You have to repeat the fan to "auto" each time the schedule changes.
May 12, 2010 | Honeywell Programmable Thermostat Heater
I have a honeywell chronotherm iv plus thermostat and lost the manual. trying to turn it on, but not sure how to program it. any ideas? its getting hot out!
HONEYWELL WEBSITE:
Go to honeywell.com
May 08, 2010 | Honeywell Electronic Programmable...
How do I program my honeywell chronotherm IV Plus thermostat? can I download a manual
Go to honeywell.com
Feb 28, 2010 | Honeywell Electronic Programmable...
My Honeywell chronotherm IV Plus thermostat intermittent problem
The Chrono Therm 3 and 4's were some of the worst products that honeywell has EVER put out. I would suggest switching to the Vision Pro 8000, please consult your local HVAC company for more information regarding the change over.
May 11, 2009 | Honeywell Programmable Thermostat Heater
I have a Honeywell Chronotherm IV Plus a/c unit and I can't get my air condt. to turn on. The room temp. says it's 17 degrees in the house so it won't turn on. I need to know how to reset the room tempt....
Not only are the Chronotherm IV's less than user friendly, they have a terrible failure rate. It sounds like one of the typical failures of the chronotherm IV. I suggest starting with a new thermostat.
Jun 12, 2008 | Honeywell Heating & Cooling
There are no batteries on an 8600-8601-8602 series
Feb 17, 2008 | Heating & Cooling
Honeywell deluxe programmable thermostat 69-1402m
Solution #2 as above worked (thank you very much!) to get to the programming mode, but on mine keeping Function #13 on the default setting of "0" maintained the AIR.  Toggling the Temp button to "1" changed the system to conventional on/off at the programmed times.
Oct 16, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
252 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
