Question about LG DLE5955 Dryer
Does a lg electric dryer DLE5955W have a reset switch?
jsrock516
  • 5911 Answers
SOURCE: Hi, I hooked up my LG DLE5955W dryer and it powers up fine but I have no heat. The outlet I had for my old dryer was different than the one required for the LG. I went to home depot and got the correc
The following link explains how to properly wire a three or four prong 220VAC appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Read through the link provided, and make sure you have the power cord wired correctly at the terminal block in the back of the dryer. NOTE: If this is a new installation, you are required to be using a four-prong outlet with 4-prong power cord. If you have any questions, please let me know. I hope this helps solve your problem.
Posted on May 03, 2009
localwonder
  • 6784 Answers
SOURCE: LG Electric Dryer DLE2515S - dryer timer is stuck on 6 minutes and continues drying until I manually switch off - sensor dryer does not appear to be working either.
OK, test the dryness sensor for its operational value. if the test confirms sensor function, you will need to replace the main PCB board in this case.
Now, if the sensor test reveals a faulty sensor device, simply replace the sensor. In most cases, this iwll be a fualty PCB main and, replacing it will usually fix this issue.
Posted on Jun 01, 2009
  • 3 Answers
SOURCE: dryer LG DLE5955w
are you missing any socks? if so you need to throughly check the duct chamber in the machine, get it serviced this is a fire hadzard.
Posted on Jun 23, 2009
  • 410 Answers
SOURCE: Dryer runs but no heat
.I am not a repair professional. I am a 78 year old man
who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and found that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer or a front load washer I suggest you go to www.applianceaid.com where they have very good step by step trouble shooting and repair information on washers and dryers as well as other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at www.acmehowto.com You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to www.applianceaid.com where they have very good
trouble shooting and repair nformation on most
washers and dryers. I think you'll find what you need
there. Don't worry about the timer, they hardly ever
go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Posted on Dec 01, 2009
sonicboomele
  • 1557 Answers
SOURCE: Flowsense has four bars all the time even with vent disconnected
buy anti static balls
Posted on Apr 24, 2010
LG electric dryer is not working
Reset your electric breakers and make sure the door switch is working. If not sure on switch after resetting breaker turn dryer on and with open door press the door switch in .caution keeps hands from inside in case it starts to work It also could be a Senser inside of dryer that goes off if vent is plugged with debri
May 27, 2014 | LG DLE2512W Electric Dryer
LG Model DLE5955W will not heat, just had it repaired about 8 months ago. Is this a common problem.
is it a sensor or heatingunit bad.if lint isnt cleaned reg it will burn out faster also.
Oct 29, 2013 | LG DLE5955 Dryer
My two or three year old LG DLE5955W dryer is making a grinding/squeaking noise and from what I have read is most likely the worn rollers. How do you gain access to them and is it something for a do it...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Nov 09, 2010 | LG DLE5955 Dryer
Dryer model DLE5955W is not heating. When drying the "drying" light flashes and the "cooling" light is on steady. I turned off, turned breaker off and back on. No improvement. Checked lint filter, all...
You have one of 2 problems. There is a power problem at the power cord or the high limit switch has tripped. You will need a qualified LG technician to diagnose your situation.
Good luck
Oct 01, 2010 | LG DLE5955 Dryer
My lg dle5955w works but does not dry clothes why
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 26, 2010 | LG DLE5955 Dryer
Dryer LG DLE5955w
Jun 23, 2009 | LG DLE5955 Dryer
May 03, 2009 | LG DLE5955 Dryer
LG DLE5955 Dryer Logo
280 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
