I have an IBM Motherboard Rev 1.6 with p4 2.4ghz processor. 2 memory slots. i cant find anywhere on the net what the highest stick of ram i can install on this motherboard
  • Thomas F. Schneider May 11, 2010
    NetVista????  number of model (4 degit)
  • Shawn McGuire
    Shawn McGuire May 11, 2010
    Are you able to see anything else on the motherboard like a Part number?
    Problem Solver:
  • 23 Answers
Have you tried IBM website look at the spec for the machine ????
Posted on Jan 13, 2009
For a Chaintech 9BIA motherboard;
Motherboard chipset is an Intel 845,
PC133 (SDR Sdram at 133MegaHertz;
{Single Data Rate. The proper term, not just Sdram.
Double Data Rate Sdram is Sdram.
Double Data Rate 2 Sdram is Sdram.
Double Data Rate 3 Sdram is Sdram.
DDR Sdram, DDR2 Sdram, DDR3 Sdram.
Synchronous Dynamic Random Access Memory )
Low-Density, Unbuffered, Non-ECC, Cas Latency of 3
(Don't get some cr@p off of Ebay.
It's usually high-density, ECC, that was used by old server computers)
WHEW! Unless you just want to run 1GB of ram memory, I would toss that board! (Two 512MB sticks) ->
-> Need two 1GB sticks of SDR Sdram at 133MHz
$400 smakeroos USD!!
Bah! That is just cra-zy!
Maximum TOTAL Amount is 2GigaByte. (2GB)
Maximum Amount for EACH ram memory slot is 1GB.
IF, you only have ONE ram memory module ('Stick'), it goes in Slot 1. (DIMM 1)
That is the ram memory slot closest to the processor socket.
The Processor reads ram memory Slot 1 first.
Nov 26, 2012 | Chaintech 9BIA (CT-9BIA) Motherboard
What's your problem?bit ix38 quad gt motherboard with 2 gig of ddr2 ram i want to add a 1 gig stick of more ram that ive bought how do i do this? thanks windows seven
Top view of motherboard, scroll down. (Thought you might also like to read the reviews, and Comments)
Motherboard User Manual,
1) On the motherboard the Blue ram memory slot that is closest to the copper heatsink, is ram memory Slot 1.
Also known as DIMM 1.
Ram memory ALWAYS has to be in this ram memory slot.
2) The Blue ram memory slots are Slot 1 (DIMM 1), and Slot 3.
(DIMM 3)
The Black ram memory slots are Slot 2 (DIMM 2), and Slot 4.
(DIMM 4)
To run Dual Channel ram memory, means there are two LIKE ram memory modules ('Stick'), and they are installed in the SAME channel.
This would mean to alike ram memory modules, in both Blue ram memory slots, or both Black ram memory slots.
Since the ram memory modules need to be alike, they are generally purchased from the same manufacturer, and are the same kind.
Running ram memory in a dual channel configuration, is supposed to increase ram memory 'speed', up to 30 percent.
This is Baloney!
May look good on paper, but in actual use in the field it's cr@p.
Actual performance increase is more like 1 to 2 percent.
This has been proven by Tom's Hardware, and many, many motherboards, ram memory, Processors, etc.
So you have 2GB of DDR2 Sdram, huh?
Is it just one 'stick' of ram memory, or are you referring to two 1GB sticks?
If the above holds true install them in Slot 1 and Slot 3.
If not, and it is a 2GB stick of ram memory, be sure it is installed in Slot 1 (DIMM 1)
Install the 1GB stick in Slot 2.
It isn't the same as the 2GB stick.
It is 1GB.
Does NOT go in a dual channel configuration.
(Catching all this? There is NO dual channel ram memory!
It is ram memory that is -> ALIKE, and used in a -> dual channel configuration.
Used in two separate ram memory slots, that support the dual channel configuration.
Sold with the advertising scheme of 'Dual Channel', but really just means the two ram memory modules, (Or four), are -> alike.
1) Same Voltage used
2) Same Ram Timings
3) Same Chip Configuration
4) Same size in amount
5) Same frequency rate ('Speed')
With ram memory in a dual channel configuration, the ram memory modules team up on the task.)
For additional questions please post in a Comment.
Oct 31, 2012 | Computers & Internet
What kind of memory can I use in my 6282-75u
IBM 300GL 6282-75u
IBM = Manufacturer
PC300 = Series
PC300 GL = Subseries
6282 = Machine Type
75u = Model
Intel Pentium processor or Intel Pentium with MMX technology, and max frequency rate ('Speed') is 200Megahertz. (200MHz)
Two ram memory slots.
EACH slot can hold a maximum amount of ram memory -> 64MB
TOTAL ram memory amount for motherboard is 128MB (Woo-hoo!)
Ram memory is SDR Sdram. Commonly, but mistakenly, just referred to as Sdram.
Has 168 gold plated contact pins. 84 on each side.
Two Locating Notches on the bottom of the ram memory module.
(Two Side Notches. One on each side)
Non-ECC and 100MHz as shown above. (PC100) [ DIMM ]
I don't know if you can just use a 128MB ram memory module ('Stick'), in ram memory Slot 1, or not.
I would try it. May have to reboot up to 4 times for BIOS to recognize the ram memory. May NOT have to.
Under the bold white heading in the black bar -> Technical manual
,click on the blue -> [+] Click for files.
It is a PDF file, and the HMM for the IBM 300GL-6282-75u Desktop PC.
(Hardware Maintenance Manual)
Cheap buy on PC100 - 128MB - ram memory modules,
You have a D.I.P. switch on the motherboard. SW1
Has 4 dip switches, numbered 1 through 4.
The positioning, (ON or OFF), determines the 'speed' support for the Processor.
Page 26 - PDF file page, Page 14 - Actual manual page )
Aug 24, 2012 | IBM (61H0382) Motherboard
Need a manual for an HP Compaq dc5100 pc
Really? It should be in Slot 1. (DIMM 1)
A Processor reads Slot 1 first.***=HP+Compaq+dc5100+20080404081+%7C+Flickr+-+Photo+Sharing%21&sigr=16pkmjpub&sigi=16irimlt9&sigb=11q4rp0eh&fr=moz35
Scroll down to the larger photos of the motherboard.
Notice how the one Black ram memory slot is closer to the Processor?
That is Slot 1.
Keep the ram memory in the same color of ram memory slots.
IF you have the SAME ram memory modules ('Stick') in the Black slots, you will be running the ram memory in a dual channel configuration.
Same thing for the white ram memory slots.
Most generally the ram memory 'sticks' are bought from the same manufacturer, so as to guarantee they are indeed the same.
Same 'speed' (Frequency rate, actually)
Same voltage used
Same ram timings
Same chip configuration
Having the two LIKE ram memory modules installed in a dual channel configuration, allows them to team up on the task at hand.
Purported to speed up the ram memory functions greatly.
Up to 30 percent.
This has found out to be bullsticks.
The actual increase is more like 1 to 2 percent.
Nothing to write home to Mom about.
(Tom's Hardware used MANY different motherboards, ram memory, processors, and associated hardware, and tested different ram memory.
All came to the same conclusion. 1 to 2 percent increase.
Why do gamers use dual channel configuration?
1 to 2 percent increase. EVERY little bit helps)
I using a dual channel configuration for your motherboard, two LIKE ram memory modules are installed in Slots 1 and 3, (Black)
Have four LIKE ram memory modules? They go in Slots 2 and 4.
Jul 01, 2012 | HP Compaq dc5100 Small Form Factor PC...
I want to be know what is compatible with AOpen s651m motherboard. i'm kind of an ammature, so please help.
AOpen S651M motherboard:
1) Processor Support:
Uses Intel processors that fit in a Socket 478 processor socket,
The Processor has the contact pins (478 of them), and the processor socket has the socket holes. (478)
The Maximum FSB supported for the processor is 533MHz.
(Front Side Bus, 533MegaHertz)
Processors supported;
Start with the Northwood Core models shown in the link above.
The ones that have a Front Side Bus of 533MT/s, and fit in a Socket 478.
The few shown in the next chart, Prescott (90nm), may not work. The voltage requirement.
2) Ram Memory Support:
DDR Sdram that operates at 333MegaHertz, or commonly known as PC2700.
TOTAL Maximum Amount is 2GB.
There are two ram memory slots. The Maximum Amount for EACH ram memory slot is 1GB.
If you only have one ram memory module ('Stick') place it in Slot 1. (DIMM 1)
This is the ram memory slot that is closest to the Processor.
[ The Processor 'sees' ram memory Slot 1 first ]
Graphics Card Support:
The graphics expansion slot on the motherboard is an AGP slot. (Advanced Graphics Port)
It uses the AGP 4X technology.
Above the 3 white PCI slots is the brown AGP slot.
Use AGP 4X/8X graphics cards.
(These types of AGP graphics cards can be used in an AGP 4X slot, or an AGP 8X slot)
Example of a AGP 4X/8X graphics card,
Another one,
,and yet another one,
For additional questions, or to have me clarify anything I have stated above, please post in a Comment.
Sep 24, 2011 | AOpen S651M (918EM10S50) Motherboard
Fiteed new quad core CPU and 4gb of Ram, when started up getting no signal detected on the monitor. Can anyone help?
Let's back up a second.
A) What HP model is it? (P/N. Product Number. Back of desktop computer tower)
B) What model number of Intel quad core is it?
C) What are the manufacturer ID number/letters on the ram memory module/s?
I need to know what Northbridge chip is used on the motherboard, to know if it will support the particular Intel quad core you're trying to use.
This I can hopefully obtain from HP Support, by looking at the specifications for the motherboard.
(This technology does not apply to motherboards that support the Intel Core i3, Core i5, Core i7, and Core i9 processors)
The Northbridge chip is part of the motherboard chipset.
So aptly named, because on a desktop computer motherboard it sits to the 'North', for one.
(Under the Processor)
[ Chip and Chipset are slang terms for I.C.
Integrated Circuit,
The Northbridge chip handles the faster capabilities of the computer.
It handles the Processor, Ram Memory, and High-speed graphics.
AGP and PCI-Express are high-speed graphics technology.
A graphics card plugged into a PCI slot, and Integrated Graphics, is Not high-speed graphics.
The Southbridge chip handles the slower capabilities of the computer.
Motherboard Diagram;
List of Intel Chipsets, and more specifically the one's that can handle Intel quad core processors,
Make sure the Ram Memory you installed is Compatible.
If the motherboard supports 4GB of ram, make sure it is in the correct ram slots if using two sticks of ram, or four sticks.
There HAS to be a ram memory module ('Stick') in Slot 1. (DIMM 1)
EACH ram memory slot has a Maximum Amount.
For example if there are 4 ram slots, and the Maximum Total Amount of ram memory is 4GB, each ram slot may have a maximum of 1GB.
It may, or may not be that you can use Slot 1 and Slot 2, and use two 2GB sticks.
Always go slow when upgrading.
Install the Processor first, boot the computer up, see how it works.
THEN shut the computer down, unplug from power, observe Anti-Static Precautions, and install 2GB of ram memory.
Install the other 2GB.
BIOS has to recognize the changes.
Are you sure your Power Supply is adequate to support the quad core, and the added ram memory?
Post back in a Comment.
Jul 24, 2011 | HP Computers & Internet
About my ram of p4m800-m7 rev 3.1 i have a 512mb ram already installed and i buy a new ram with a 1gb size and i would like to install it but my question is is it okay to put them together? my 512mb ram is...
The black rectangular chips on the side, or sides, of the ram module are DRAM chips. Dynamic Random Access Memory.
('Chip' is slang term to denote IC, or Integrated Circuit)
Each Dram chip is of a specific size, (or can be said as Amount)
There are manufacturers who make the Dram chips, and then the chips are used by the ram memory manufacturer.
Doesn't matter how the Dram chips are arranged. The ram memory manufacturer could put them all of one side, if they designed it that way.
1.Your motherboard will support, (Use), DDR at 333Mhz, or DDR at 400MegaHertz.
(PC2700 and PC3200, respectively)
2.The ram memory module must use 2.5 Volts.
(JEDEC has set the voltage standard for DDR Sdram at 2.5 Volts, so no worries here. Only time to check this, is if you have some High performance ram, that may be set to use a higher voltage)
3.It must be Non-ECC ram, and Unbuffered.
4.Cas Latency should be 2.5 to 3.0 (Ram Timings)
Short solution?
Computer off, and unplugged from power. TOUCH the metal frame of the computer case to relieve your body of Static.
Handle the ram 'sticks' by the body of the stick, and refrain from touching the gold plated contact pins, on the bottom.
If the 512MB stick is in SLOT 1, remove it. Install the 1GB stick in Slot 1. Make SURE it is seated!
(Slot 1, is the ram memory slot that is closest to the Processor. It is the first ram memory slot that the Processor reads)
Leave the computer case open. (Refrain from putting your hands in while the computer is plugged into power)
Plug the computer into power. Wait 30 seconds. Turn the computer on.
Computer boots up? (Starts)
Unplug from power. Install the 512MB stick in Slot 2.
Plug into power, wait 30 seconds. Turn the computer on.
Computer boots up?
You're good to go.
1GB ram memory stick is in Slot 1, and the computer does not boot up?
Incompatible ram memory. Remove it. Reinstall the original 512MB stick in Slot 1.
Nov 26, 2009 | EliteGroup P4M800-M7 Motherboard
Memory problem
First pull cmos cell from motherbord for 10 minutes.
then open processor fan and processor then clean dust from motherbord and all parts then reconnect processor and its fan.
Then refix RAM memory .
then if it beeps so long then most of it is your RAM problem.slot is more time works fine in that case.
Aug 25, 2009 | HP (D7580-60003) Motherboard
I believe the fastest CPU you can install in that motherboard is a Athlon XP 3200+ (2.2GHZ) socket 7 CPU.
That board uses eaither DDR 1 or SD-RAM and is definatly not compatible with DDR2 which uses a different connector on the motherboard (more pins)
Jan 21, 2009 | IBM (09N5424) Motherboard
Computers & Internet Logo
312 people viewed this question
David Payne
David Payne
