Question about Kenmore Vacuums
Reset thermal protector on kenmore elegance vacuum
No power
4 Suggested Answers
SOURCE: Kenmore Elegance Vacuum cleaner - power bar not working
The problem almost certainly is that the axle of the brush in your power bar has dirt/fluff in it that is preventing the belt from turning it so that the fuse in the power bar clicks off after 2 or 3 seconds. It is fairly easy to fix. All you will need is a Phillips screwdriver and about 15 minutes. Follow the following steps
1. With the power bar disconnected from the vacuum, turn it upside down and you will see two inset screws at the rear side of the base of the power bar. Unscrew these two screws using your Phillips screwdriver.
2. With the power bar in the same position unlatch the two plastic tabs at the rear of the power par. [It may be useful to flip up the metal bar that you see on the base to use as a handle] On each side of the base you will see an arrow saying insert screwdriver here to release. Insert a screwdriver and lever the plastic of the base slightly apart from the plastic of the side. When you have done this for both sides the base should lift off.
3. Now lift the brush including the two end pieces straight up. It should just slide up. You will need to unhook the drive belt from the brush as you lift it out.
4.Pull of each end piece and clean the dust, lint, hair off the end piece and from inside the end of the brush.
5.Once clean, reinstall the end pieces on the brush. Hook the belt back over the brush to its original position and slide the brush back into the power bar.
6. Reinstall the base by hooking the tabs from the front of the base into the small openings on the power bar.then push the base down until it clicks back into place and the tabs are back in their original position. Reinstall the two screws you removed earlier.
7. The power bar should now work. Good luck.
Posted on Apr 18, 2009
  • 30 Answers
SOURCE: I have no suction power but the brush feature will turn on & spin
the same motor that turns the belt is sucking at the same time. your prob is just behinde the brush there is a pickup hole. tahe a wire coat hanger and shove it through unti you see it were the hose plugs in the back off the vac. ming did the same thing and i see these in the trash all the time. I clean the shoots and sell them on craigs list. if it was the reset you would not have any power at all
Posted on Jun 13, 2009
BissellCSR
  • 276 Answers
SOURCE: Bissell Healthy Home Vacuum No Power - Reset Thermal Protector?
Try to re-install the handle. On occasion if the handle is not installed properly and secured tightly the unit may experience intermittent power.
Posted on Oct 13, 2010
No power when I turn it on. Should I insert new exhaust filter?
A new filter will not solve an electrical problem. It could be a plug, wire, switch, PCB, etc. Electrical problems usually require a qualified technician to diagnose and repair.
May 06, 2016 | Kenmore 25512/ 25513 Progressive Canister...
Model 116.31040902 will not run but for a short period of time then shuts off. will not restart for about 30 mins or more
It is probably time to replace it. There is a thermal protector that is tripping because of a problem with the motor.
Jan 20, 2016 | Kenmore Vacuums
Lately as I'm vacuuming, my vacuum will turn off. I can start it again, and it will shut off again. It seems like a power issue. Happens different places in the home, so it is not the outlet.
Some vacs shut off when the dirt bag is full Check your brush area and see if there is dirt or bits of string like things wrapped around the brush or the brush ends. This will cause the machine to shut down as well if there is pressure holding the brushes. Will it run if you wiggle the plug if so you could have a bad plug as well.
Jul 07, 2015 | Kenmore Vacuums
Why wont the reset button depress on riccar 8955 or turn on after trying
The reset button does not have a significant amount of movement in response to pressing to with a paper clip or ball point pen. If the vacuum does not start upon pressing the button, then either the thermal protection circuit is not why the vacuum stopped in the first place or the reason the thermal protection circuit tripped has not been cleared. Quoting from the manual
"Your Riccar vacuum cleaner comes equipped with a Manual Reset Thermal Fuse Protector. This thermal protector is designed to protect your vacuum cleaner from overheating due to a restriction in airflow (i.e. clogged hose, operating the vacuum without a bag). Should this situation occur, the thermal fuse protector will safely shut off the vacuum cleaner to avoid any potential damage. NOTE: To determine it was the thermal fuse protector that turned off your vacuum
cleaner, please refer to the vacuum cleaner's headlight. If the headlight is on while the motor is off, then the thermal fuse protector did safely shut down the motor. If both the headlight and motor are off, then there is some reason other than the thermal protector (i.e. pulled plug) your vacuum is off.
To reset the thermal fuse:
. Unplug the vacuum cleaner
  1. Check for problem - over-filled bag, clog in hose, clogged filters, etc.
  2. Correct problem
  3. Locate "tripped" fuse - the small white button located on the bottom of the back side of the main body (roughly one inch to the right of the left wheel)
  4. Using a pencil, paper clip or other pointed object, push the reset button in
  5. Plug vacuum cleaner in and resume use"
Mar 08, 2015 | Riccar 8955 Upright Vacuum
I was given a model 6591, plugged it in and it worked but didnt "****" and didnt sound right. I turned it off and removed the hose from the back found a badly plugged hose. Removed the hair...
The User Guide for the bissell Clearview Power Trak
http://canada.bissell.com/images/UserGuides/3590C.pdf
May not be your exact model but should be similar.
The Bissel vacuums include an internal thermal protector to protect it from overheating. When the thermal protector activates, the cleaner will stop running. Should this happen proceed as follows:
1. Turn the cleaner OFF and unplug from electrical outlet.
2. Check the Pre-Motor Filter and Post-Motor Filter for dirt accumulation.
3. Remove any clogs.
4. When the vacuum is unplugged and motor cools for approximately 30 minutes, the thermal protector should automatically resets and cleaning may continue.
5. If the thermal protector continues to activate after following the above steps, your cleaner may need servicing. Call Bissell Customer Service:
http://canada.bissell.com/Contact_Us.aspx
Mar 20, 2011 | Bissell 6591 Power Trak Revolution Bagless...
Motor on our kenmore progressive agitator is not
Look for a reset button on the motor and press it in. If it clicks, then it was tripped. An excessive load on the motor can make the reset trip. Try turning the motor shaft to make sure that it is not bound up. Run the machine empty for a short time to see if it works. Good luck!
Jul 16, 2009 | Kenmore 31913 Progressive Direct Drive...
Mar 29, 2009 | Bissell 5770 Healthy Home Bagless Upright...
My bissell 3595-2 vacuum cleaner started turning off the power automatically. Now I can not get it to turn on. This vacuum cleaner is still in real good condition, as I have hardly used it. Please...
Hello, this is Ava with Think Crucial.
Most Bissell vacuums have Thermal Motor Protection which is a built in safety system that stops the machine if it begins to overheat. This usually happens because the filter needs washing or your machine is blocked. If your machine turns off on its own, unplug it and leave it for at least an hour to cool down. Remember to check the filter and look for blockages before re-starting. When the motor cools for approximately 30 minutes, the thermal protector automatically resets and cleaning may continue. If the cleaner will not turn on or the thermal protector continues to activate, your cleaner may need servicing.note: the thermal protector controls the main vacuum motor only, not the brush motor. If the thermal protector activates, the brush will continue to operate normally; however, there will be no suction.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Sep 03, 2008 | Bissell Vacuums
Vacuums Logo
42 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
