Question about Canon Pixma iP6210D InkJet Photo Printer
Canon ip6210D error check ink v075
Check ink message for cl51 cartridge?
IB4G2008
  • 3587 Answers
SOURCE: Canon mx700 rejecting remanufactured ink cartridges
big issue with remanufacturing is how integritous is the fit of the cartridge, and also the interface. When these are re cut, so to speak, tolerances can stack up, and one thing about Canon, is they are a stickler for tolerances. You may have an issue with the cartridge fitting in the carriage, but not interfacing with the system. Happens sometimes..
got backup?
Posted on Feb 15, 2008
cropp
  • 377 Answers
SOURCE: canon mp150 pixma printer error e5
dear warenout
try this methode
Methode 1
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting formenu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
that's all
maybe it can fix your problem
thanks
cropp
Posted on Mar 15, 2008
SOURCE: Ink Error "Check Ink, U051, BLK COL"
power off
press hold red button
power on hold button
release red button twice
=beep=
all done !
Posted on Apr 16, 2009
SOURCE: Get error: check ink u059 col
For me, this meant that I put it an ink cartridge that wasn't compatible.
Posted on Jun 16, 2009
SOURCE: RECOGNITION OF GENUINE CANON INK CARTRIDGE
most probably has been damaged.
ink cartrigde is damaged due to followin causes--
1. over heating  of head due to bulk printing
2. mishandling the cartridge.
3. repeated refillings
try this if you want to use this cartrigde again, it may work
1.  clean the golden contact points with isopropyl alcohol of cartrigde as well as the cartridge holder
2. remove cartrigde and install again after some days
possibility of fault in printer is minimal,
Posted on Jul 02, 2009
I changed my ink to new ink ,and the lights are flashing what could be the matter ,i have a error message E5 ,can you give some tips as i have lost my manuel . Amanda
This could indicate that one or both cartridges aren't completely installed or the tape is still over the nozzles. With the printer on, lift the scanner unit and wait for the cartridges to move to the replacement location. Remove the cartridges one at a time, remove the protective tape (if present) and reseat them. Make sure that they click into place. Then close the scanner unit.
You can try installing new Canon cartridges (to check if the error is from bad cartridges). Make sure that you have the cartridges in the correct slot and are using the correct cartridges for the printer (PG40, PG50, CL41, CL51).
The printer may require service if the cartridges are OK.
The manual for the printer is available here: http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp150?selectedName=BrochuresAndManuals .
I hope this helps.
May 05, 2011 | Canon PIXMA MP150 All-In-One InkJet...
I changed my catrige but its showing the error E5
I use refilled cartridges. Okay, the printer says ink low, but it does that all the time. I ignore it. However, yesterday it printed not a problem, today it gives me code 5. Does anyone have a real solution or should I throw the printer away?
Jun 08, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Canon pixma MP150 was working normally and today it says that cannot recognize ink cartridge. what can be solutions?
Fix Canon pixma MP150 was working normally and today it says that cannot recognize ink cartridge
May 20, 2010 | Canon Pixma MP500 All-In-One InkJet...
I got this message on the display (canon pixma mp170): "check ink u051"The cartridge is completely new and original. What can I do? Thank you in advance.
MP170 can only accept PG40, PG50, Cl41 & CL51 only. Please check the cartridge model correctly. if problem still persist, ask for replacement for the faulty cartridge.
May 19, 2010 | Canon PIXMA MP170 All-In-One InkJet...
My canon mp170 has a yellow alarm light on and it says "check ink u051" i already checked the ink and replaced them with new ones..
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Error message U051 on canon MP460
Check the Label on the cartridge if it covers a certain area then you will get an error message. Compare it with a good cartridge the label should nearly touch the lugs at top end. Only applies to refilled Carts.
Oct 04, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Canon Pixma iP6210D InkJet Photo Printer Logo
old marine
old marine
