Question about Locks & Locksmithing
Reset combination abus 160/50
I have 6 of these combo locks and would like to change the combinatiion
The answer can be found at http://www.lockwiki.com/index.php/ABUS_160: "The shackle can only be opened when the correct code is dialed and this is required in order to reset the code. With the correct code dialed in the user pulls out the shackle, turns the key on the right-hand side of the lock 90 degrees clockwise and sets the new code on the dials. The new code is in effect once the key is turned back to the vertical position."
Posted on Nov 23, 2014
2 Suggested Answers
  • 38 Answers
SOURCE: How to reset EasyGo Travel Sentry 3-Dial Combo
well.maybe you should get a new lock because there is nothing to do with it
Posted on Sep 15, 2009
How do I set an abus 1460 combination lock
Your lock is here Linda, but no instructions
https://www.abus.com/eng/Mobile-Security/Bike-Safety-and-Security/Locks/Steel-O-Flex/Steel-O-Flex-Raydo-Pro-1460
there are a number of videos showing how in the main link. This one is good;
https://youtu.be/ZyPmi1o_o1M
This one has the key built in
https://youtu.be/m32HP5E8Ak8
Go to Bing homepage
Jul 21, 2016 | Abus Raydo 1460 Lighted Combo
Have a abus comb lock its locked i put in the four numbers which are correct but it wont open only just bough it shop put in the combination
Take it back to the shop. They will provide the correct combination or reset the combination; or will owen you a new lock or refund (if you did not actually forget the combination). Abus makes good locks.
Mar 14, 2015 | Locks & Locksmithing
Tsa002 change combination
Most combination luggage locks can be reset when they are open. The combination wheels can't be turned unless the lock is being reset. So either the wheels show the correct combination, or you will be able to turn them to a new combination. The lock that is "locked outside the hole" was either not relocked after inspection or it's in reset mode.
Jul 04, 2014 | Locks & Locksmithing
How do you reset the combination to a Ace Solid Brass Combination Padlocks
Open the lock, rotate the shackle180 deg, and push down.enter new combo, and rotate shackle back to normal position.
Mar 27, 2014 | Ace Hardware Ace Solid Brass Combination...
Can not unlock combination lock of 'jeep' suitcase. Initial combo was 0,0,0. How can I reset the combination ?
What you want to do is just keep tension on the shackle, or the part of the lock that would open. With tension on it start at the opposite end and turn the numbers. You will notice that it will get "stuck" on a specific number. That's the last number in the combo. Turn the middle number till it sticks. Then the last. Tadaa! Hopethishelps
Feb 04, 2013 | Locks & Locksmithing
Reset combination lock
The cable lock should come with a small pronged key used to change the combo, if you lost the key you can try getting a replacement from HP.If not you will need to cut the cable and buy a new one.
Nov 18, 2011 | Computers & Internet
I lost the instructions and don't know how to unlock using "original code" and how to create a new code
try all zeros Kryptonite locks come preset to zeros once unlocked there is a small lever inside were it locks together pull it down and set your new combo then push it back up
Oct 17, 2009 | Kryptonite Kryptoflex 1218 Combo Cable...
Resetting the combination
The reset works when the current correct combination is set on the front. If you forgot the combination, you can go to the www.masterlock.com and download a PDF to request a combination from the factory to open it. It requires a notarized form & takes 6+ weeks. In the end, it is probably easier to buy a new one. When resetting the combo, I accidently scrambled it as I flipped it over. And did not know the combo. The reset button would not work. I did some guess work around the setting and got it to release again.
Jan 08, 2008 | Master Lock 5400d: Portable Select Access...
Locks & Locksmithing Logo
1,180 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
