Question about KitchenAid KUWA244PBL Wine Cooler
Kitchen aid wine cooler kuws24rsbs00 will not cool. Only the fan turns on, all lights are off, compressor not turning on.?
  • 300 Answers
SOURCE: kbrc36fts kitchen aid refrigerator
ompressor won't run or it is "clicking' on and off: This normally could be a bad start relay and over load for the compressor, dirty condenser coils need cleaning, condenser fan motor is not running or the compressor itself. To check the compressor properly you should test it with an amp meter, each compressor is rated in running amps  ( see model/serial tag or the sticker on the compressor )...if the compressor is drawing too much current, this may be why it is shutting off. Check the model tag for proper amp rating. Some relays will be easy to notice the broken with them, they may be burnt. Example oneexample twoexample three. Some of these relays can be removed and give them a little shake, and if they rattle around inside the relay is likely bad. Compressors can also seize and click on and off or one of the electrical windings inside the compressor could have opened up. You can use a test cord to help check the compressor and this also will help with the amp test. If the compressor checks ok and you want to install areplacement start relay. You will need to find out which winding is which. You will need an ohm meter to determine the windings. First check to see if you have windings in the compressor. Then check to see if they are grounded. If the compressor has windings and they are not grounded, you can find which winding is which. Check for grounded windings by reading from each terminal to a good ground on the cabinet. Read from the top terminal to the lower left terminal. Read from the top terminal to the lower right terminal. Read from the lower left terminal to the lower right terminal. Write down the resistance of each reading as you go. The highest reading you get will be the run and start winding of the compressor in series with each other. The other terminal left will be the common terminal. Read from the common terminal to each of the other terminals. The terminal with the lower resistance will be the run winding. The higher resistance the start winding. Using the original style relay is always preferred, but using a general replacement can "get you by" if needed. Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Posted on Mar 07, 2009
jumptrout51
  • 3361 Answers
SOURCE: Kitchen Aid Superba side-by-side not cooling
Replace the compressor start relay.
Posted on Mar 10, 2009
SOURCE: ksrs25ikss01 kitchen aid fridge portion not
1.check if the fan inside the freezer is running
2. if ref runs none stop, defrost timer is out.
3. or it could be the high limit that paired in series with the defrost heater
good luck!
Posted on Jun 27, 2009
mgprice
  • 744 Answers
SOURCE: Problem with Kitchen Aid side by Side
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck!
Posted on Jul 11, 2009
  • 123 Answers
SOURCE: KitchenAide wine cooler not running
hi there....have you checked the thermostat or temperature control.......sound like your problem lies there....
regards Sir Galahad
Posted on Aug 13, 2009
Wine fridge is not getting cold anymore
Its really hard to determine without proper diagnosis, but are you sure it indeed has a compressor? does it run ? Does it have a circulating fan inside? A lot of the wine coolers I've dealt with were "Peltier" coolers. They use electronics to cool usually only to about 10deg below room temp. They require a load ( in this case wine bottles ) to operate properly. They don't have a cold control like a refrigerator.
Jun 30, 2014 | Koolatron KWD28SN 28 Bottle Compressor...
My U-Line mode l15BWC fan and compressor won't work
More than likely it is the temp control (thermostat) it is what controls the on and off
Oct 12, 2012 | U-Line Wine Captain (2015WC) Wine Cooler
Can not get wine cooler to get cool. Red lights keep,blinking. Need structions on how to set it.
If the light is on and no fan or compressor is running then its your thermostat that is bad. That's the only thing that turns on those parts. As you said the unit is new you should contact your dealer either to replace it.
Keep us updated.
Aug 20, 2011 | Cuisinart Private Reserve CWC-900 Wine...
The alarm in our Franklin Chef model FWC100 wine cooler keeps going off even though everything stays cool so we want to know how to turn off the alarm or cut the wire to the alarm. Thanks.
Love this machine. Works great. Have had it for 6 years. Now it has a problem. The lights and fan work, and the temperature settings work. It behaves like either the freon is low (I don't hear the compressor starting), or whatever causes the compressor to start is crippled... Fuse looks good, nothing visibly burned on the motherboard, haven't opened the bottom.
Jul 29, 2011 | Franklin FWC100 Wine Cooler
It just stopt cooling (wgersdorf@yahoo.com)
Turn the temperature dial to the lowest temperature setting. Wait 24 hours for the wine cooler to reach the desired temperature. Also, turn the wine cooler off and inspect the fan. If the fan if it's running or not.
Lastly, check the compressor.
These are the areas that could make your wine cooler stop cooling; the temperatue settings (Thermostat), then Fan and the compressor.
Check these three areas and let me have a feed back.
Bye for now.
Mar 04, 2011 | Haier BC112G Wine Cooler
MCWC52B wine cooler stopped cooling, compressor hot
Turn it off and place a small electric fan by compressor to cool it down.
When you turn it back on, see if you hear a clicking noise. This would indicate starting components need checking.
Nov 08, 2010 | Magic Chef MCWC45A Wine Cooler
Marvel 61wc wine cooler turns on, but doesn't cool
If you can hear the compressor running and there is no cooling happening your unit has either lost it's refrigerant due to a leak or the compressor is completly worn out (or both). If you just hear the condenser fan running (air blowing), then maybe the compressor just has bad electricals (starting relay, overoad, run capactor) or it has developed a bad winding and will need to be replaced.
If you know you have lost refrigerant the repair will be quite costly and you should consider replacement. If you feel it is a failure of the small electrical parts for the compressor, repair would be more cost effective.
You can get further trouble-shooting assistance and order parts direct from the factory at 800-223-3900.
You can look up a local servicer on their web-site at www.lifeluxurymarvel.com
Should you desire to attempt electrical repair yourself, reply to me and I will provide further troubleshooting assistance or you can contact Marvel Customer Service at the number above. Good-Luck, Subdriver
Jan 28, 2010 | Marvel 61WC Wine Cooler
Wine cooler does not get cool - fans do not run the light and temperature display do work
if you hear the compressor tun on but not the fan, replace the fan and you may have to defrost the evaporator coils. if the compressor does not turn on either, it's the thermostat, the defrost timer, or a relay on the main board.
Nov 12, 2009 | Oster 12-Bottle Wine Cellar - Black
U-line 15" wine cooler not cooling, but light is on.
If the light is on and no fan or compressor is running then its your thermostat that is bad. Thats the only thing that turns on those parts.
Nov 25, 2008 | U-Line 15WC Wine Cooler
Wine cooler doesn't cool
you need to turn the temp. setting all the way up,use a rag to hold the fan,now see if the compressor. is running,let me know-mike
Jul 11, 2008 | Danby Silhouette DWC512BL Wine Cooler
KitchenAid KUWA244PBL Wine Cooler Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
