Question about Sabrent Computers & Internet
How do I get windows xp to recognized sabrent 7 port hub with ac power
WhiteFox4
  • 641 Answers
SOURCE: I can't seem to get the Belkin 7-port hub to work
windows 7 is a 64 bit OS, and still fairly new. A lot of drivers for hardware are not supporting 64 bit Operating Systems yet, maybe in the near future but right now a lot are not.
Temporarily or permanently switch to Ubuntu. I think this hub is compatible, and you can still read your Windows files in this Linux distribution.
Posted on Jan 02, 2010
SOURCE: I have a Q-Stor 7 port USB hub, Model QU2RCT7. I
I don't have the original power supply for my QU2RCT7 either, but most hubs use a 5v DC power adapter, typically with a 2A. (2 amp) rating. I'm using such an adapter with my QU2RCT7 and it works fine. Make sure the adapter you select is tip-positive (ie, the "+" terminal is the "tip," or center, of the connector).
Posted on Aug 04, 2010
  • 17 Answers
SOURCE: i bought a 4 port
Right click on my computer or the icon for my computer and select manage then open device manager and see what it says in there then up top select check for hardware changes icon, this should look for and install the hub
Posted on Jan 01, 2011
SOURCE: Belkin F4U017 7 port USB
I just had the same problem and was able to figure our a permanent fix.Judging by the date of you post, I'm guessing you've already remedied this problem one way or another. But just in case you haven't or someone else is having the same problem, I'll go ahead and post what to do. First, make sure you leave the USB hub plugged in right now so that Device Manager lists what it thinks is the Bluetooth device. Go into Control Manager > Hardware & Sound > Device Manager. Right click on Bluetooth device that is showing up in error. From the dropdown box, select Properties. Click the Driver Tab. Click Uninstall. Check "Delete the driver software for this device." Click OK. Unplug your USB hub for a few seconds, then plug it back in. Windows should now recognize it as a "Generic USB hub." You should be good to go. Just remember not to install that update again or try to update the driver for the Generic USB hub. If you do, you'll end up with the same problem. I hope this helps someone out there.
Posted on Jan 10, 2011
  • 747 Answers
SOURCE: Belkin 7 Port Hub has power (red light is on). Has
unplug port and plug port back in and then restart computer.
Posted on Feb 01, 2011
How do i use a Samsung external DVD writer model SE-s084 without using the main USB cable. There are 2 USB plugs and i recently broke the main one. is there anyway i can use it with the other plug?
I don't quite understand what you mean with "the other plug", but if you connect your external DVD writer to any USB port, the computer must recognize it and for Windows there is no need to install driver for optical drives.
Probably if you don't want to be left with no free USB ports, you can purchase a USB hub, preferable if you invest in one with external power source like this one: USB 2 0 HUB Powered 7 Port High Speed free AC Adapter
Hope it helps!
Dec 18, 2014 | Samsung USB 2.0 Slim External DVD Writer...
Kodak RVG 6100 Size 1 sensor not being recognized by system.
I don't have the answer but I have the same problem. Our sensor works on our one remaining XP workstation. However we recently installed new workstations and upgraded to Windows 7. It is recognized by the new Windows 7 workstation, and the workstation installs the driver, but the unit fails to initiate a capture status. Carestream support installed the driver and tested the sensor in all the USB ports and with a powered hub. No luck, their determination is a "bad sensor" but they can't explain why it works on our XP workstation.
Aug 12, 2013 | Kodak Carestream RVG 6100 Digital X-ray...
I have a nexxtech 7 port usb 2.0 hub which prevents boot to windows. Incompatible?
This hub is USB powered through your computer while you are using the first ports available. If you use ALL at once ports you will need to add the appropriate AC/DC external power adapter to supply the needed extra power.
Jul 03, 2013 | Computers & Internet
I can't seem to get the Belkin 7-port hub to work with windows 7. Whenever I plug a flashdrive into it, windows 7 doesn't give recognize the flashdrive.
Dec 30, 2009 | Belkin (F5U237) 7-Port USB Hub
Western Digital Passport 160 GB external HD won't load.
WinXP SP2 blocks the use of the drive because it thinks it draws too much power. But there is a simple procedure to override this (from WD site):
"Problem:
Under Windows XP, an error message of "Power Surge on Hub Port" or "USB device has exceeded the power limits of it's hub port" is displayed when connecting a USB device to a USB port on a computer or Hub.
Cause:
Under some computers, USB devices are only allowed to draw a maximum of 500 milliamps (mA) per connection from the USB port on the computer system or from a USB hub. Under the Windows XP Operating System, with the release of Service Pack 2, if a device attempts to draw more than this (500 milliamps), a USB port balloon message is displayed to indicate this over current condition. When connecting a USB device that draws power from the USB bus, a very brief over current condition is sometimes detected by the OS, and the warning message is displayed.
Resolution:
This message has no affect on the functionality of the USB port. The USB hard drive should still function correctly on the USB port regardless of the error message. To prevent the USB Power Surge Alert message from displaying, please complete the following steps:
Click on Start.
Click on Control Panel.
Double-click on the System Icon.
Click on the Hardware Tab.
Click on the Device Manager button.
Click on the + next to Universal Serial Bus Controllers to expand the selection.
Right-click and select Properties on any listing that displays USB UNIVERSAL HOST CONTROLLER.
Click on the Advanced Tab.
Check the box that says: Don't tell me about USB errors."
This works fine, and the drive works fine afterwards. I suspect it actually draws less power than they say. Maybe it has a brief power draw spike on startup, but it's running power seems less. In any case, it works fine without the Y cable. I do think it is tacky that WD doesn't give the cable for free, since my $7 Sabrent 2.5" Hard drive enclosure came with a y cable.
But most likely the drive will work fine for you. It is a lovely quiet drive, and takes up no space at all.
Feb 01, 2009 | Western Digital Passport 160GB External...
Lacie 250GB Hard Disk is not being recognized by PC (Windows XP)
Some PC's cannot deliver enough power to the USB devices to function properly through the USB port.
Does your Lacie hard disk have a power input connector if so conect a power adapter to it before you put it into your USB port.
Another alternative, get a powered USB hub connect it into your computer then connect the Lacie hard drive to the powered USB hub.
Jan 03, 2009 | LaCie (300728U) 250 GB Hard Drive
Usb cannot recognized
Reinstall your USB drivers:
Navigate to Device manager, find a branch named "USB Controllers" or similar
Right click the one thats the problem (or all of them if you dont know which), select Uninstall
Reboot your machine and windows will autodetect the USBs and reinstall their drivers
Check the BIOS and see if they are enabled...
Disable power management on the USB hub To preserve power, Microsoft1.gif Window XP tries to disable USB when a device is not used. Under certain circumstances this function does not work and may cause USB devices to fail to respond when called. To resolve this issue, disable power management on the USB hub by doing the following:
  1. Click Start , and right-click My Computer .
  2. Click Properties , then click Hardware .
  3. Click Device Manager .
  4. Double-click the Universal Serial Bus Controllers branch to expand it.
  5. Right-click USB Root Hub , and then click Properties .
  6. Click Power Management .
  7. Deselect Allow the computer to turn off this device to save power .
  8. Repeat Steps 5 through 7 for each USB Root Hub.
  9. Click OK , and close Device Manager .
Jan 17, 2008 | ASUS M2N-MX Motherboard
Computers & Internet Logo
18 people viewed this question
Top Sabrent Computers & Internet Experts
Martin Murray
Colin Stickland
Colin Stickland
Steve
Are you a Sabrent Computer and Internet Expert? Answer questions, earn points and help others
