Question about Samsung WF337AA Front Load Washer
Samsung vrt washer error code te
TE error code tried powering machine off runs fix seconds and it stops displaying tE
  • 3 Answers
SOURCE: Samsung VRT washing machine
nF means that washer tried to fill but was unsuccessful. Water supply valves needs to be fully open. Lines may be kinked or screen by the hose hookup at the washer end may be restricting flow. Check to ensure the screens are cleaned by removing hose and pull screens and clean them then try the washer again
Posted on Jan 18, 2008
  • 3 Answers
SOURCE: samsung washing machine error code te?
The problem could be the thermistor, but before you replace it, check the wiring. Many people with this error code have found one or more broken wires. If you call for service, be sure the technician checks the wires.
Posted on Dec 28, 2009
SOURCE: Considering the purchase of Samsung WF338 / DV338 Washer & Dryer
Don't buy any Samsung products. They're definitely not worth the money. We bought the front load 2009 washer and dryer about 14 months ago. Have always had problems with the dryer -- auto dry is a joke. The washer will not allow you to change the water temp. It's supposed to automatically correct the water temp; what a joke. AND the power went off today while the washer was filling with water, with clothes in the tub. No way to open the door, and we have to wait almost a week for a service call!!! IF YOU BUY SAMSUNG PRODUCTS, YOU WILL BE WASTING YOUR MONEY!!!
Posted on Aug 01, 2010
  • 3 Answers
SOURCE: Samsung P801DWNXRC Frontload washer displays E6 error code
I had the same problem. I ended up paying $300 ($100 part $200 labour) for an authorized technician to replace the control board and that fixed the problem.
Posted on Sep 22, 2010
richroth
  • 9472 Answers
SOURCE: I have a samsung washing
WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
Posted on Dec 11, 2010
Kenmore/MD 4.6 cu. Ft. Front-Load Washer, Blue Silver made by Samsung has a fault code tE. How can I reset the machine?
According to Samsung, tE indicates a temperature sensor issue. The corrective action is to turn off power at the source, wait 30 seconds and start a new program. When that fails, call for service.
Nov 18, 2016 | Kenmore Washing Machines
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
Samsung NE595N0PBSR range is giving error code "tE"
unplug for 10 minutes then plug back in, or try holding down various buttons for 3 seconds or longer
Apr 06, 2013 | Samsung NE595N0PBSR 30" Electric Induction...
TE error code problem How to fix the thermistor
The TE error code indicates a heating error, usually caused by a faulty thermistor. First, attempt to clear the error by unplugging the power cord, waiting for 10 seconds, restore the power, and restart the wash cycle. If the same problem happens again, close water tap, unplug the washer because the unit may require service.
Check in the next link the Service Manual for LG WM2277 Service Manual that could help you.
Hope this helps (remember to rate and comment this free answer).
Sep 27, 2011 | LG WM-2277HW Front Load Washer
Displays 'tE'
Hi
'tE' is a Thermistor Error.
Here is what the manual says:
This error occurs when the Thermistor circuit is abnormal or a voltage of O.2v or below or, 4.5v and over is detected. This error can be cleared by POWER switch OFF.
Unplug the machine from the wall for a few seconds and restart.
Ash
Sep 18, 2011 | Samsung Washing Machines
LE in display
Hello,http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf page 18 of this service manual elaborates on the LE error code and what to check.. Hope this helps you..
Thanks
May 30, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
How I fix an error code on a LG wm2669hna washer that says TE error
May 17, 2010 | LG WM-2277HW Front Load Washer
Samsung front loading washer temperature sensor problem
It may not be your temperature sensor or thermistor. If you have a tE error code on your Samsung washing machine, first check the wiring. My Samsung washer had three visits by the repair tech. and new parts ordered again and again. I looked on a British web site and two people said that it turned out to be wiring broken in several places. Sure enough, I found a broken wire. Technician didn't look for that. Hope it's as easy for you.
Feb 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Samsung WF337AA Front Load Washer Logo
57 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
