Question about Music
Can i use a behringer mixer with Fruity Loops studio?
I have tried everything. The software will not read the mixer. I really need some help
5 Suggested Answers
  • 1137 Answers
SOURCE: My casio 496 cannot connect to fruity loops
Unfortunately your model of Casio only has midi in and not midi out. You will be able to use it as an external sound module but not to input notes into Fruity Loops. In other words midi out of your computer to midi in of the Casio with the proper settings will play your Fruity Loops sequences through the Casio.
Posted on Jun 23, 2009
  • 5603 Answers
SOURCE: casio ctk 700 Fl studio 8 connectivity
Fruity Loops version 4 requires Windows up to version XP.
If you happen to have Vista on your PC, you should probably retrofit to XP as there are MANY compatibility problems with Vista and a lot of the special purpose software.
First thing is to COMPARE the PC requirements against what Fruity Loops says it requires.
Posted on Oct 07, 2009
  • 1137 Answers
SOURCE: fruity loops old version with casio keyboard
You haven't said whether or not you are using a demo ,version of FL. If you purchased they have Lifetime Free Updates here:http://flstudio.image-line.com/documents/lifetimefreeupdates.html If you didn't purchase, try downloading the newest demo version here:http://flstudio.image-line.com/documents/download.html Some features of demo programs become disabled after a certain time period. I don't know if midi device recognition is one of them for this program. Try hooking your keyboard up first, making sure that you have the correct drivers for the keyboard, your USB adapter etc. Then start FL and see if the program lists your keyboard in the midi device list.
Posted on Mar 04, 2010
  • 57 Answers
SOURCE: i have a tower computer kind of older . when i
Assuming you are running windows XP you need to
1. right click the speaker in the lower right corner and select adjust audio properties.
2. Select the audio tab
3. Pull the drop down menu under sound recording and make sure it is selected to your audio driver device. Most are either soundmax, creative(for soundblaster and audigy standalone cards), realtek, or ASUS.
4. Next repeat step one but select open volume control
5. Go to options and then properties
6. Select the circle for recording and make sure your mic input is checked.
7. Close that window and recording mixers will pop up. Select the input you need by checking the box in the lower left corner of the mixer channel. Adjust the level and then use your recording program or sound recorder under Program files>accesories>communication>sound recorder.
Posted on Mar 08, 2011
Help behringer xenyx 1002fx !!
If you registered your mixer there will be a three year warranty so get it back to your local Behringer service depot. If not check the output from the PSU, if that's OK then I'm afraid it is very unlikey to be economical to repair. Sell it as spares and repairs on eBay.
May 25, 2014 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Is there a free option to fruity loops?
The only real factor that comes near to Fruity Loops for Mac that is free is Auadicity. If something a little more advanced is wanted by you check out Adobe Audition or Professional Tools.
Audacity is free, open source software for editing and saving sounds.
Dec 31, 2012 | Music
How do you connect behringer sx2442fx eurodesk sttudio mixer on acomputer in studio
WIthout a quality audio interface the answer is you don't... You need to procure an audio interface for the computer. The internal audio systems of computers are too noisy to get decent results. The manual for the mixer will show the typical studio connection with a suggested audio interface.
Aug 06, 2011 | Behringer Sx2442fx Eurodesk 24channel...
I have a tower computer kind of older . when i plug in the microphone to the back i.e. microphone port, nothing happens to signal it reads the microphone and when i try to use the microphone for fruity...
Mar 08, 2011 | Philips Phillips...
Where (on-line) can we find download for advanced manual for Behringer PMP 4000 16 channel powered mixer? What we found on-line was the exact manual that came with the mixer.
There really ISN'T and "advanced" manual... Everything you need to know is in the user manual that comes with it... Service manual with schematics will not give you much you can use unless you are into electronics detail.
PLEASE read my tip about Behringer PMP mixers on here regarding a hazard if you use Speakon to 1/4 inch cables or adapters. Essentially, the sleeve, NOT the tip is the HOT lead for a speaker on channel A. Ground it inadvertently and goodbye channel A amp.
Be VERY careful of speaker leads with this amp as it is easy to pop a channel IF a speaker comes loose or shorts. Loop cables through the handlesto avoid cables being yanked out or breaking plugs.
Feb 09, 2011 | Behringer PMP4000/B212XL Mains & Monitors...
I have theUB802 model and I'm getting buzzing feed back from speakers. Any suggestions
Check for ground loops. Please read my tip on here in regard to speaker polarity hazard on the A channel output.
Ground loops are common if you don't have everything powered by a singel receptacle. Also if you are using DI's make sure the Ground Lift is set to LIFT.
Start troubleshooting by disconnecting ALL inputs and one at a time re-connecting to find offending input.
Sep 23, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Fruity loops old version with casio keyboard
Mar 03, 2010 | Casio Ctk 496 Electronic Keyboard with 61...
Casio ctk 700 Fl studio 8 connectivity
Oct 06, 2009 | Casio Music
Mixer doesnt send sound to my computer
If you are using recording software you will have to look for Preferences and make sure that the software is detecting your soundcard. You also have to make sure that your PlayControl settings match the input on your soundcard to the ones your mixer are plugged into. You also have to match the RecordingControl which is under Options and then Properties. That is all under Sounds and Audio Devices in your Control Panel under the Volume tab then Advanced. If you have latency problems which makes the sound delayed from the input on your mixer to what you hear from your computer try downloading Asio4all although your mixer should have come with a disk with the proper drivers. If it didn't Behringer has a great support section at their site that has downloads for everything.
Aug 07, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Jun 18, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
Music Logo
32 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
