Question about Keurig Platinum B70 Coffee Maker
Keurig dispensing too much water - Keurig Platinum B70 Coffee Maker
2 Suggested Answers
  • 28 Answers
SOURCE: my keurig will not dispense right amt of water
Try brewing a cup without a K-cup in it on the largest cup button (will brew just hot water). This will help clean it out in the event it is clogged. If that doesn't work, completely remove the K-cup holder where the needles are (careful not to get **** ) by pushing up from the bottom and rinse using hot water, preferably with a sink sprayer if you have one. Sometimes the needle can get clogged, especially if you ever use the hot cocoa K-cups, so the manufacturer recommends brewing a "blank" cup of just hot water after each hot cocoa K-cup brewed. Hope that helps...Best of luck!
Posted on Feb 07, 2010
Keurig B150 - continuous water dispensing
Their appears to be a scale build up inside the valve that dispenses the water when demanded. This is an electrical solenoid much like in fridge water dispensers but smaller. The scale is not letting the valve close completely after dispense. On a regular brewer running vinegar thru the machine a couple of cycles will usually dislodge the obstruction in the valve. If you can manually add water to the brewer, you should add the vinegar instead to clean the valve. Otherwise you may have to disassemble locate the valve and soak in descaler, or vinegar.
Jan 11, 2015 | Keurig Coffee Makers & Espresso Machines
Does not dispense enough water. I get about 2 ounces of coffee at a time. How do I adjust the water level?
When was the last time the unit was descaled? A build up of scale will gradually restrict and then stop the water flow.
Feb 02, 2010 | Keurig B100 Coffee Maker
Just bought a secondhand Keurig. It will dispense
Do you have this part to insert the k-cup into? There has to be an exit needle and this part has the exit needle inside of it.
http://iwantsweetdeals.com/Keurig-Breville-Replacement-K-cup-Holder-Assembly-P1208231.aspx
Jan 14, 2010 | Keurig B70 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
744 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
