Question about Delta Faucet Delta T4738-SS Lahara Two Handle Roman Tub Trim with Hand Shower - with Lev
My delta roman tub faucet handle won't come off
arealplumber
  • 33 Answers
SOURCE: low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
Posted on Dec 05, 2008
  • 68 Answers
SOURCE: can I replace delta faucet t2710 with Delta SBS 84010BN ?
yes . when buying the faucet dont forget to buy stainless steel suply lines for water line connection.
Posted on Jul 04, 2009
  • 129 Answers
SOURCE: my delta faucet pull down diverter tub spout is
It sounds like it could be manufacture defect. Take it back for a new one.
Posted on Oct 05, 2009
SOURCE: We are trying to remove
Make sure the exact allen key is in the screw. take a small adjustable wrench, close it onto the allen key, and loose with wrench turning the allen key.
good luck
Posted on Oct 12, 2009
  • 60 Answers
SOURCE: I have a two-handle Delta faucet that drips
sounds like you need to replace the valve seats. if you shut the water off and remove the handles you will see the valves. you have to remove them and under that you should see these little black things. they come out but have springs under them so be careful. the black things are the valve seats. i would start by replacing them
Posted on Dec 15, 2009
Delta T2738 Deck Mount on Jacuzzi Tub. Hot Water side leaking.
With the detailed part number you have, I would just walk into stores like Home Depot or any plumbing store and they will give you the exact parts you need. They are not expensive and a lot of them are standard parts and come in kits.
Good luck.
Apr 08, 2013 | Delta T2738 Lahara Deck-Mount Two-Handle...
Delta foundations windemere roman tub faucet leaking out of spout
If you will make contact with George at M-One-Specialites he can track that down for you and help you get that fixed.
He has a very extensive list of repair parts for faucets.
Rod
US Parts Center
Jan 28, 2013 | Delta BT2796-SS Foundations Windemere...
Set screw is stuck. Any suggestions on how to remove it to replace the roman tub faucet?
to replace the roman tub faucet you have to expose the faucet under the deck of the tub. Most of the time builders do not install a door to do repairs. So expose the underside of the deck of the tub, turn off the main water outside then cut the water pipe for the hot and cold water with a tube cutter. At this point take a sawall and place the blade so the side of the blade touches the bottom side of the deck.
and cut all the way though the body of the stem.
Do all three and your done with the hard part. Install your new faucet and enjoy.
Hope I was help to you Rich
Sep 05, 2011 | Moen T999/4999 Chateau Two Handle Roman...
I have a Delta Tub/Spout Pull Down Diverter that has a pretty persistent drip. The HOT and COLD handles are turned off and seem to be as tight as they can be. After doing some research online I believe...
If your Delta RP17453 Pull-Down Diverter Tub Spout stops dripping after 5 minutes, your ok. If it never stops dripping, you need to replace delta faucet cartridge(s) behind the handle(s). This is were the water turns on and off and stops the water flow to the tub spout.
Delta faucets are some of the easiest to repair, and parts are usually available at any hardware store or home center. If you have a two handle faucet, replace both delta seats and springs and stems. If you have a single handle Delta faucet, replace the entire cartridge.
Jan 26, 2011 | Delta Faucet Delta RP17453 Pull-Down...
The roman tub faucet keeps dripping. I push down on the stems and it stops?
the retaining nut,located under handle may not be screwed down all the way.this happened to me on similar / same faucet's.so try this and see,nice and easy
Dec 30, 2009 | Delta Faucet Delta T2710-LHP Classic Roman...
Can I replace delta faucet t2710 with Delta SBS 84010BN ?
May 17, 2009 | Delta Faucet Delta T2710-LHP Classic Roman...
Moen Castleby T6988 Roman Tub Faucet
with screw removed (the missing one), handle should lift straight up. may need to rock the handle while lifting.
Feb 12, 2009 | Moen Castleby Two-Handle Widespread Roman...
Delta faucet is loose ;moves right-left/wobbles. Tightening?
Try tightening the allen set screw behind the spout "you need a special (allen keys) to do this, and one should have came with your faucet". You can also buy or borrow an set of them.
http://www.efaucetscomplete.com/SpecSheets/T2755CBLHP_Install.pdf
Copy and paste this to your address bar for directions.
Jan 30, 2009 | Delta Victorian T2755-NNLHP Bathroom Roman...
Delta Faucet Delta T4738-SS Lahara Two Handle Roman Tub Trim with Hand Shower - with Lev Logo
37 people viewed this question
Top Delta Faucet Home Experts
john h
bobalix
 John
John
Are you a Delta Faucet Home Expert? Answer questions, earn points and help others
