Question about Dual Electronics CECT P168 Cellular Phone
Removal of Battery Cover
I just received my P168c and can not remove the battery cover please Help.
Also I am charging the batteries but the adaptor is reading a red light instead of green while charging. Is the battery being charged? Or should the light be green when charging?
Thanks in Advance
xoxo
  • Anonymous Apr 29, 2009
How long does it take to charge the phone
Posted on Aug 08, 2009
  • 31 Answers
Have the newer I9 but same issue at first..but one answer is YES it should be red when charging. Next ques..My back was SO hard to get off i thought i was crazy at first. I had to use a sharp stek knife to CAREFULLY open it for the first 3-4 times but since that it opens and closes with ease but the first times it had to be pried open..but be careful--but eventually it will work just sliding it up and down.
Posted on Jan 13, 2009
2009 fxdc superglide custom battery cover removal
Hi Anonymous, for more information about your question please visit the website below. Good luck and have nice day.
Harley Davidson Maintenance Tips Softail Dyna Battery Seat Install
Mar 23, 2013 | 2001 Harley Davidson FXDL Dyna Low Rider
Hi. Have a scc-100 that needs a new battery. How do i pull it apart? Thanks, Jorgen
There is a hidden screw just above the charge jack that holds the top cover in place. Remove the plastic plug that hides the screw, unscrew the screw, and pry off the cover. My unit would not charge anymore. I think the charging electronics are poorly designed. I extracted the battery and electronics leaving only the motor, then wired the motor directly up to a 5 volt battery pack. It now works great!
Jul 04, 2011 | Remington SCC100R
Replacing battery on Aston Martin Vanquish
Below is the procedure for an Aston Martin Vantage, perhaps the vanquish is similar?
Removal
1. Power the driver's fully forward.
2. Remove rear compartment cover.
3. Loosen and disconnect battery terminals, earth (- ve)
terminal first.
4. Release rear carpet, studs (x2), move carpet aside.
5. Remove screws (x2), battery compartment cover to
support rail.
6. Remove nuts (x2), battery compartment cover to body.
Remove cover.
7. Remove Torx screws (x4), remove battery clamps (x2).
8. Disconnect battery vent tube.
9. With assistance, remove battery.
Installation
1. Clean battery tray and clamps.
2. With assistance, install battery into its compartment.
3. Connect battery vent tube.
4. Position battery clamps (x2), install and torque tighten
Torx screws (x4).
5. Ensure battery vent tube is not distorted by battery.
6. Install battery terminals, tighten terminal nuts to correct
torque.
7. Install battery compartment cover, install and tighten
screws (x2) and nuts (x2).
8. Position rear carpet, secure with studs.
9. Install rear compartment cover.
10. Reposition driver's seat.
Courtesy of pistonheads.com
Please vote if this helps! Thanks, Mike
Jun 12, 2011 | Aston Martin Vanquish Cars & Trucks
I have a blackberry bold 9000 mobile phone , it doesn't ring when the back cover is on , but when i remove the back cover it rings fine , what seems to be the problem and can u suggest a solution , can...
Hi boy_great,
You need to set the settings for the cover and without cover mode of the blackberry ,
Please follow the below steps :-
  1. Find the advanced option in the profiles menu and change the in and out settings for the holster or the cover. I hope this is the problem in your case.
  2. I direct removal of the battery also works sometimes , all you need to do , is
    remove the battery when your phone is switched on and after thirty to forty seconds connect the battery back again and restart the phone.Hope his helps ..:)
May 11, 2011 | Computers & Internet
Harley Davidson Sportster starter removal?
1997 HARLEY DAVIDSON SPORTSTER XLH 1200
STARTER REMOVAL
1. REMOVE LEFT SIDE COVER
2. REMOVE NEG. BATTERY CABLE FROM CRANKCASE TO PREVENT ACCIDENTAL STARTUP
3. REMOVE POSITIVE BATTERY CABLE
4. DRAIN TRANSMISSION FLUID (5/8" SOCKET)
5. REMOVE PRIMARY COVER (IF YOU'RE UNSURE OR IT'S BEEN AWHILE - PLEASE CONTACT - I CAN PROVIDE INFO)
6. REMOVE REAR EXHAUST
7. REMOVE 2 STARTER BOLTS (5/16" ALLEN)
8. REMOVE STARTER
9. REMOVE GASKET
10. SLIDE BOOT BACK AND DISCONNECT THE POSITIVE CABLE FROM BATTERY (12MM)
11. DISCONNECT STARTER SOLENOID POSITIVE LEAD TO STARTER
12. LOOSEN WIRE BAND NUTS 3/8" SOCKET
If anything you're unsure about or been awhile just comment below or reach out. The primary cover has a few quirks to get off - can go further with you if needed. All The Best, Justin Lee
17 South Industries, LLC
Aug 10, 2010 | Maisto Harley Davidson 1997 XLH Sportster...
Cannot remove battery from laptop
You can always refer to manual for such kind of thing.It will bw given with diagram.
If you don't have the manual, download it from the link below
http://www2.panasonic.com/webapp/wcs/stores/servlet/TCCHomePage?langId=-1&storeId=15001
You need to register to their site inorder to downalod the manual.
Jan 03, 2010 | Panasonic Toughbook CF-51 Notebook
Battery Icon with red line through it? Durring a back up, my Storm turned off and when I turned it back on this battery icon is all I get. I have a fully charged new battery in it now and it still shows...
This usually means the bb and battery got a little wet or has other issues. Try these solutions in order. They go from easisest to hardest. NOTE: If you have an insurance policy on the bb probably best just to take it in.
1. Remove the back cover. Remove the battery and the SIM card. Wait 30 seconds. Replace SIM, battery and back cover. Reboot. Plug in the bb and charge fully.
2. If that doesn't work, allow the bb to remain unplugged but ON for about 24 hours to drain the battery. Remove back cover and battery. Allow battery and opened bb to sit in a dry environment for 24 - 36 hours. Relace battery and cover. Reboot. Plug in the bb and charge fully.
3. If that fails retry step 2 but allow battery to FULLY drain then dry out again.
4. Take in.
Jul 18, 2009 | RIM BlackBerry Storm 9530 Smartphone
Hi I have DRC-SR200 camcoder, bought one year ago. Issue is lens cover is not opening. On the LCD display there is a message "lens cover not fully open. Turn off and on". I tried that but no use. Went...
Hi, perform the following steps to get this issue resolvbed... 1. Check whether the lens cover is opened 2. check whether the battery is fully charged. If the battery is not fullly charged, connect the Camcorder to the wall outlet using the sipplied AC adaptor. 3. Then, try resetting the Camcorder by pressing the RESET button using a sharp-pointed object while the Camcorder is turned ON. 4. If the issue still persists, turn OFF the Camcorder; then remove the battery pack and discinnect the Ac adaptor from the Camcorder; slide the POWER switch to the ON position for 1 minute. Then, connect the AC Adaptor tro the wall outlet and cjeck whether it helps.
If the issue still persists, service of the unit may require. contact the manufacturer of the Camcorder to get ut serviced.
Jul 10, 2009 | Sony Handycam HDR-HC1E HDV Digital...
How to remove power on password on hp compaqnx6110?
You can try reseating the RTC battery:
http://h20464.www2.hp.com/index.html
Real-time clock battery removal Before you begin: Remove the battery and keyboard.
  1. Disconnect the RTC battery cable from the system board
  2. Use a small, flat-bladed, non-conductive tool to flip the RTC battery out of the socket on the top cover.
Real-time clock battery replacement
  1. With the positive (+) side facing up, insert and press the RTC battery into the socket on the top cover.
  2. Reconnect the RTC battery cable to the system board.
If this does not fix the issue, you may have to replace System board
Jul 06, 2009 | HP Compaq nx6110 Notebook
Dual Electronics CECT P168 Cellular Phone Logo
214 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
