No signal from set up box - Televison & Video
  • 1,238 Answers
Try to reset all connectors
Posted on Dec 10, 2012
On my e-motion tv when I switch it on and go onto did it says no signal....help please
Why does my TV say no signal? If your HDTV or Standard TV displays a "No Signal" error message, it may be due to one of the following issues:
  1. Determine how many TV's are affected.
    • If it is one TV, continue to step two.
    • If multiple or all TV's are affected, continue to step five.
  2. Ensure that your HDTV is on the same source/input as your MTS Ultimate TV service.
    1. Press the TV button on your MTS Ultimate TV remote control.
    2. Press the TV/Video button.
    3. Wait 10 seconds.
    4. Repeat steps b and c continually to cycle through all the available source/inputs on your TV until the correct source/input is selected. (ie. HDMI 1, HDMI 2, Component 1, Component 2, etc.) On standard TV's (non HDTV), you may have only 2 choices, TV or Video.
  3. If the source is correct from step two:
    1. Unplug the HDMI cable from your MTS Ultimate TV Set-top Box.
    2. Wait 30 seconds.
    3. Plug the HDMI cable back in.
    4. Wait for the signal to initialize.
    5. Make sure all cables connected on the set-top box and your TV are secure.
  4. If the problem persists:
    1. Unplug the power cable from the back of the MTS set-top box.
    2. Wait 60 seconds.
    3. Plug the MTS set-top box back in.
  5. If you are still experiencing a problem:
    1. Make sure ALL Ethernet and/or Coax cables are securely in place.
    2. Unplug the power from the MTS box labeled 2Wire or Pace as well as the affected set-top boxes.
    3. Wait 60 seconds.
    4. Plug the power back into the MTS box labeled 2Wire or Pace.
    5. Wait for the broadband light to turn a solid green colour.
    6. Plug the power back into the affected set-top boxes.
    7. Wait for the signal to initialize.
Good Luck
Feb 24, 2015 | Televison & Video
How to tune channels on a 14 inch RCA tv?
You need a good set top box, either Hi definition or standard Pal, to make any CRT Television work. These days, non digital TV do work well but they no longer accept analog signals, but when connected to a set top box that receives digital signals, the box converts the digitals signals to analo and sends then to the RCA inputs of your TV and not via an antenna connected to the set top box and the TV.
Sep 01, 2014 | Televison & Video
Why won't my nec tv tune to set top box ?
Unless your set top box has a digital RF out you have to use a SCART lead
Aug 09, 2014 | NEC NLT-22HD3 22 in. LCD TV
My box keeps saying no signal
If its a cable or satellite box first remove power from it and the set it is connected to for a while and then power back up as this will allow the box and or the set to try to reboot.
not sure what kind of box you have but replace it if you can or test it on another set.
Dec 06, 2012 | Televison & Video
Cant record,stating weak signal.
May be the box or a poor connection or cable---check those first and if possible try the box on another set.
Nov 06, 2012 | Toshiba Televison & Video
No hd signal on my lg32lc5dc tv
Answer a few questions to try to resolve this issue:
What is signal source for HD you are using? (cable box, sat box, receiver in line, antenna).
Where on the set are you connected? (HDMI, HD component input on rear or?)
Does if not a box used the set have a built in HD tuner?
May 21, 2012 | LG Televison & Video
I need the maual for this rca tv L37wd22yx6 tv just keeps saying unusable signal and i need the maual
What is the signal source for the TV? Make sure that you are on the correct input. Use the Input button on the remote. If you do not have the original remote, you need one that matches that function. (Often a Source or Input button is not available on the low end remotes.) Check that you have the signal set to Antenna or Cable if you are using the coaxial connection and the source is TV. (Menu > Setup > Channel Setup > Signal Type)
If your source is a computer, use the VGA port not the HDMI port. Computers send a different type of video signal than video set top boxes. The L37WD22 can't interpret the PC signal on the HDMI input.
For a set top box on the HDMI port, the unusable signal message indicates a communication issue. Try pressing the Info button on the remote. If you see an additional message of Acquiring Channel, then the set top box isn't responding to the remote. Check that the device is on and set up correctly to communicate with the TV. (For example, if your set top box offers progressive scan, try turning of that feature with the control for the box.)
The L37WD22 was built by TTE for the RCA label. The manual is available on the TTE support page.
The direct link to the User's Manual in English is http://support.ttetech.com/RCATV/Assets/pdfs/L37WD22_16788070_IB_e-07.pdf .
I hope this helps.
Aug 29, 2011 | RCA Televison & Video
Recorder has stopped decoding SD digital TV but analogue TV is OK
Dry joint - faulty capacitor on the PC board of the decoder. Found by wiggling the components and resoldering
Feb 07, 2010 | Panasonic Televison & Video
My analogue tv doesn't do anything when connected to the new set top box. The scart is connected and the aerial also. Are there some anologue tv's that can't receive the digital signal? I already have 1...
Have you checked that your aerial is connected into the set top box & not into the TV? The aerial signal has to go into the set top box & then the box will be connected via your Scart cable into the TV. On the TV you will need to select the Scart input ie. AV1. This should give you the set top box incoming signal, you might then have to tune in the box by following the on screen instructions. Hope this help.
Nov 02, 2009 | Televison & Video
Converter box
You'll need to keep your TV on channel 3 or 4 depending on what channel you set the converter box. All your channel changing will be done through the converter using its remote control after that. If you change channels on the TV itself and go off channel 3 or 4, the TV will not get a signal and will show you that "no signal" message.
Nov 24, 2008 | Sanyo AVM-3259S TV
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
