Monitor squeezes images toward bottom of open software windows.
Some programs load with open screen windows squeezing the image height at the bottom of the open screen window. Is this a video driver
problem or video card motherboard compatability issue? Adjusting
monitor geometry does not solve problem.
  • 601 Answers
Un install the video driver and reinstall also check if any update is available for the same.
Let me know.
Posted on Sep 15, 2009
HI my viewsonic monitor is hving problem when i switch on my system it shows me a horizontal line on the screen, except that line i cant see any thing and eveything else is black on the screen..
The entire image is squeezed in that thin line because the vertical deflection unit has failed - the monitor will have to be opened, the vertical circuit identified and replaced - all this must be done by a repairman so take it as fast as you can to one. If you keep it functioning this way for long the screen will be burned.
Apr 24, 2011 | Computers & Internet
How to enlarge a picture that is scanned or copied? When i scan or copy a picture it is too small and I want to enlarge it in order to view it better.
hi
Open an image. Go to the Image Menu and select Image Size. This is where you can change an image’s resolution and print size (width and height). The following Image Size dialog box will appear:
Notethat the width and the height of the image as you view it on yourmonitor is not necessarily representative of the image’s actual widthand height—i.e., the size it would print out at (print size).Average monitor resolution is 72 dpi. If you view a 72 dpi image at100% in Photoshop, chances are that it will appear on your screen inits actual print size. However, this is not true when viewing a 300 dpiimage. A 300 dpi image viewed on-screen at 100% will be enormous. Don’tget tricked into believing that what you see on your monitor is whatyou’ll get when you print or place the image into another application.The best way to determine what your image’s actual print size will beis through the Image Size dialog box.
When the Resample Imagebox is checked, any changes you make to an image’s width or height willnot change the image’s resolution, and as such, any changes you make toan image’s resolution will not affect the image’s width and height.Keep in mind, however, when you increase width and height, orresolution, with the Resample Image box checked, you are adding pixelsto your image. These pixels don’t actually exist so Photoshop mustcreate them. As such, you will succeed only in degrading the quality ofyour image.
If you want to increase an image’swidth and height, or resolution, then uncheck the Resample Image box.Now any changes you make to the image’s width and height will changethe image’s resolution, and vice versa:
  • If you decrease resolution, the width and height will increase.
  • If you increase resolution, the width and height will decrease.
  • If you increase the width or height, the resolution will decrease.
  • If you decrease the width or height, the resolution will increase.
Thebest way to increase the width and height of a scanned image is to scanthe image in at a high resolution (about twice what your finalresolution should be), and with the Resample Image box unchecked, decrease the resolution. Once the image width and height is where you want it, you can then check the Resample Imagebox and type in the resolution you want if the resolution is too high.At this point, as long as you don’t increase resolution, or width andheight, your image quality will not suffer.
Aug 07, 2010 | HP Officejet 5610 All-In-One InkJet...
Screen stretched out horizontally and distorting picture. None of the settings buttons appear to solve this. I can shift the image vertically or horizontally; but not squeeze it horizontally.
There are adjustments in the size of the items on a screen under the screen properties, settings. If you right click on the desktop screen and then properties you can get there. There is at least one size which causes a distortion of images being displayed. This may be your problem.
Feb 28, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Can not see any images on LCD
hi..
Sounds like a loose ribbon cable -- the one that connects the screen to the circuitry inside the camera.
Try squeezing the body of the camera near the bottom 'Samsung' logo, to try to snug-up the connection. Brace the front (under the lens) with your index fingers, and press firmly with your thumbs on the back over the logo just under the screen.You might try squeezing around the other edges of the screen for good measure in case something else came loose.
thank u
rate me
Jul 26, 2009 | Samsung Digimax S730 Digital Camera
Printer will not scan pictures.
Introduction To use the scan features, the HP All-in-One and computer must be connected to each other and turned on. The HP All-in-One software must also be installed and running on the computer prior to scanning. To verify that the HP All-in-One software is running on a Windows computer, look for the HP Digital Imaging Monitor in the system tray at the lower right side of the screen, near the time. NOTE: Closing the HP Windows system tray icon can cause the HP All-in-One to lose some of its scan functionality and result in a No Connection error message. If this happens, correct it by restarting the computer or by starting the HP Image Zone software. Follow the instructions below to scan documents from the all-in-one to an application. Make a Scan Step one: Load paper
  1. Open the paper tray door. Figure 1: Opening the paper tray door c00315283.gif
  2. Pull the paper tray extender toward you, as far as it will go. Flip the paper catch at the end of the paper tray extender to open the extender the rest of the way. WARNING: Legal paper might get caught on the paper tray extender if it is fully extended when you print onto legal paper. To avoid a paper jam when using legal-size paper, do not open the paper tray extender.
  3. Squeeze and hold the tab on the top of the paper-width guide, then slide the paper-width guide to its outermost position. Figure 2: Sliding the paper-width guide to the outermost position c00315284.gif
  4. Tap a stack of paper on a flat surface to align the edges, and then check the paper for the following:
    • Make sure it is free of rips, dust, wrinkles, and curled or bent edges.
    • Make sure all the paper in the stack is the same size and type.
  5. Insert the stack of paper into the paper tray with the short edge forward and the print side down. Slide the stack of paper forward until it stops. NOTE: If using letterhead, insert the top of the page first with the print side down. For more help on loading full-size paper and letterhead, refer to the diagram engraved in the base of the paper tray. Figure 3: Inserting paper into the all-in-one c00315285.gif Squeeze and hold the tab on the top of the paper-width guide, then slide the paper-width guide inward until it stops at the edge of the paper. Figure 4: Sliding the paper-width guide to the edge of the paper c00315286.gif Do not overload the paper tray; make sure the stack of paper fits within the paper tray and is no higher than the top of the paper-width guide.
Step two: Load the original NOTE: Many of the special copying features will not work correctly if the glass and lid backing are not clean.
  1. Lift the lid and place the original face down on the left front corner of the glass, with the sides of the original touching the left and bottom edges. NOTE: For more help on loading an original, refer to the guide engraved under the glass.
  2. Close the lid.
Step three: Scan to an application NOTE: To use this feature, you must have installed the full software package and the HP Digital Imaging Monitor must be running.
  1. Press Scan on the control panel. A preview image of the scan displays in the HP Document Viewer window on the computer, where you can edit it.
  2. Click Done or Finish in the software. The HP All-in-One sends the scan to the HP Image Zone software, which automatically opens and displays the image.
NOTE: To stop scanning, press the Cancel button on the control panel, or in the HP Image Zone software, click Cancel . Have a good day,
Jun 18, 2009 | HP PSC 1410 All-In-One InkJet Printer
Panasonic SDR-H40 video images distorted in Media Player
The camera does not write the 16:9 code properly in the mpeg so Windows media player does not recognize it properly. There is a little utility called index.zip that you can download which has a file sdcopy.exe which copies the file from the camera and properly writes the code. Then any current video editing software will recognize it and display it properly. It is also a handy utility that I prefer over the software that came with the camera.
Nov 22, 2008 | Panasonic PV-GS500 Camcorder
I am trying to scan a pic and my scaner says no scan options
Step one: Verify that the Digital Imaging Monitor is ready The Digital Imaging Monitor must be running in order for the Scan To function to work. The Digital Imaging Monitor icon normally appears in the system tray at the lower-right corner of the computer screen, and the monitor is ready when a check mark appears on the icon after Startup is complete. If the Digital Imaging Monitor is in the system tray, proceed to Step two. If the Digital Imaging Monitor does not appear in the system tray, follow these steps. Windows 98, Me, and XP
  1. Click Start , and then click Run .
  2. In the Open text box, type msconfig .
  3. Click OK .
  4. In the System Configuration Utility window, click the Startup tab.
  5. Search the list for HP Digital Imaging Monitor . If HP Digital Imaging Monitor is not on the list, the driver was not correctly installed or a custom install was used. Proceed to step three to uninstall and reinstall the software.
  6. Select the HP Digital Imaging Monitor check box.
  7. Click Apply , and then click Close .
  8. Click Yes to restart.
Windows Vista
  1. Click Start .
  2. In the Start Search text box, type msconfig and press Enter .
  3. On the User Account Control window, click Continue . The System Configuration Utility window displays.
  4. Click the Startup tab.
Step two: Populate the destination list The destination list must be populated in order for the Scan To function to work. Follow these steps to populate the destination list.
  1. Open the HP Solution Center. Use one of the following methods to open the HP Solution Center.
    • On the Windows desktop, double-click the HP Solution Center icon.
    • On the taskbar, click Start , Programs , or All Programs , click HP , and then click HP Solution Center .
    If more than one HP device is installed, click the tab for the All-in-One product. The HP Solution Center shows only the functions, settings, and support options that are appropriate for the selected HP product.
  2. Click Settings .
  3. Click Scan Settings and Preferences .
  4. Click Scan to... Setup .
  5. Click the Destination List tab. NOTE: Depending on the computer performance, it can take several minutes for the Front Panel Destination List to populate after the printer or computer is turned on.
  6. If the Front Panel Destination List is empty, continue with this procedure. If the Front Panel Destination List contains valid scan destinations, proceed to step three to uninstall and reinstall the software.
  7. Click each program to include on the Scan To list.
  8. Click the Add arrow.
  9. Click OK .
  10. Scan a document using the Scan To button on the front panel.
  11. If the scan fails, try to scan using the HP Solution Center Scan button. If the scan still fails, proceed to Step three to uninstall and reinstall the software.
Step three: Uninstall and reinstall the software
  1. Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
  2. If the software installer does not automatically start, complete the following steps.
    2. In the Open text box, type X:\setup , where X is the letter of the CD-ROM drive.
    3. Click OK .
  3. On the installer screen, click Uninstall . If there is no Uninstall option, the software installation is incomplete.
  4. Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
  5. If the model supports custom install, install HP Imaging Device Functions to scan from the printer. The recommended install will install this feature automatically. It must be manually selected during a custom install.
  6. Follow the onscreen instructions until the printer software is completely installed.
  7. After successful installation, scan a document.
Jul 08, 2008 | Office Equipment & Supplies
60pp9352 convergence ic replaced multi points corrected but image squeezed
one of the resistors must be open, you cant always tell by looking if theyre open you have to remove one leg out of circuit then test them for resistance they can only be 5% out of tolerance, any more than that and they must be replaced.
Mar 27, 2008 | Philips 60PP9352 60" Rear Projection...
Monitor flickers and image is reduced and squeezed
Heat related dry solder issue Horizontal output side.
Apr 02, 2007 | HP Compaq FS7600 17" CRT Monitor
Picture squeezed horizontally
we have right click on desktop <properties<settings <apply ok
Sep 09, 2006 | LG Studioworks 563N 15" CRT Monitor
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
