Question about Miele Vacuums
My Miele S4 vaccuum's lid is stuck open at 90 degrees
The lid is stuck at 90 degrees (all the way up) and will not move at all.
My Miele upright hose just clogged. It is clogged near the base of upright vaccuum. How to unclog
Remove the base plate and the brush. If you have a model number, I can find the instruction book and videos. Click COMMENT under my post.
Mar 16, 2018 | Miele Vacuums
Hi This SBD 285-3 floorhead is for a miele s8310
Hi There,
I have to say i do warranty repairs for Miele and own VacuumSpot.com.au and I have actually never heard of this before either. The miele SBD285 is basically a good quality 35mm floor tool have you tried using a different type of tool. Wessell Werk (german manufacturer) make tools for Nilfisk, Electrolux etc make a range of tools and you may find that a different one will work perfectly for you. I am not sure where you ive but highly likely your local vacuum store will sell a version like this one which is truly excellent
http://www.vacuumspot.com.au/deluxe-german-35mm-combination-floor-head-ftw135-2
Sep 17, 2013 | Miele SBD 285-3 Classic Combination...
Where do you put the prefilter on a miele canaster vaccuum
Hi If the power head isn't working it may be clogged. Try taking it apart to see if threads and general dirt has got in at the sides. Also without the power head if the Miele still isn't working then its a possibility that the on switch wiring is either loose or check the plug at the end of the power cord.
Sep 11, 2012 | Miele S514 Solaris Electro Plus Vacuum
Hi, I have a Miele s247i vacuume cleaner- My electric coard does not roll back, How do I open the vacuume lid / housing to fix or replace the spring? do you have instruction manual on how to open the...
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Miele model by clicking the link below.
Miele 247i Manuals
You can purchase a wide variety of high quality Miele replacement parts for your Miele vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Miele
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Feb 16, 2012 | Vacuums
Popped the lid open to change vacuum cleaner bag...now lid won't close. It's stuck at 90 degree angle. Is a button to release it?
Hi bndennis,
Please check the spring on your lid, it may be keeping the door open. Miele vacuum cleaners mainly use a spring concept for keeping lids open - merely pushing it down will lock it at the bottom.
Kind Regards :-)
JEDEMEYER1
* If this solution helped you, please rate it
Jul 23, 2011 | Miele S4210 Antares Bagged Canister Vacuum
Noisy vacuum that wont pick up properly
Your vacuum is still under warranty. Call Miele or the Miele dealer you bought it from. They are obligated to repair your vacuum.
Jun 05, 2010 | Miele S4210 Carina Bagged Canister Vacuum
Dry/Wet vac is blowing instead of vaccuum
Check to see if the plastic ball is stuck . There should be a ball under the motor , make sure it moves freely. Make sure your vacum lines are not plugged . Best of luck Ed.
Jun 18, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Opening Miele S28i Vacuum cleaner
If it is similiar to the white star you may find the instructions here useful: http://www.sannerud.com/house/miele.html
hope so
Jan 10, 2009 | Miele S251i Plus Bagged Canister Vacuum
Miele S326i Vaccuum cleaner hose broke
any miele warranty center can help you with ordering a new part, look on line for close center. Or try main office.
Mar 13, 2008 | Vacuums
Vacuums Logo
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
