Question about Hammering
BOSCH DEMOLITION HAMMER GSH11-E REPAIR MANUAL
The bearing of rotor is wornout need to replace. Can this be replaced or need to replace the whole rotor assembly??
    Champion:
  • 304 Answers
See posted solution.
Posted on Dec 17, 2012
  • 142 Answers
SOURCE: Bosch demolition hammer oozing grease/oil.
Look around there for some O rings we have had this same problem with some of our Bosch hammer drills, and they usually replace a set of seals around the nose of the tool
Posted on Jul 06, 2009
jmgldsmth
  • 1869 Answers
SOURCE: Need manual for Hitachi Demolition Hammer
http://www.hitachipowertools.com/product/files/concrete_masonry/demolition_hammer/H65_OM.pdf
Posted on May 28, 2009
darjr
  • 378 Answers
SOURCE: Makita demolition hammer stopped working - believed electrical pblm
you have to use an ohmmeter to check it, you must check the continuity of motor coil after the switch terminal if in this point you have the reading less than 200 ohms, try checking it before the switch but this time you have to switch it on. If you have the readings continue to check it from the Power Plug. Most cases the problem is only in Power cord .
Posted on Jun 01, 2009
SOURCE: I need a repair manual for a Kango 900 demolition
Hi
It could need more grease around the piston or it could be the teeth on the gears are stripped
Den
Posted on Feb 24, 2010
rowdy45176
  • 2176 Answers
SOURCE: dewalt demolition hammer stopped hammering.
could be a few problems, the striker could be stuck from debris or the ram might be hydraulically locked. they make a rebuild kit for this tool if you are mechanically inclined. I would suggest first going to their site and downloading a parts breakdown and there you will find what is involved and the parts listing. It is "dewaltservicenet.com" and on the left hand side type in your model number and then follow the links to download this. Let me know if you need more assistance.
Posted on Apr 23, 2011
Wat colour cable goes in which side inside a Bosch demolition hammer
That Depends on the model and the year of build or is it really a demolition hammer or a rotary hammer instead of a demolition hammer made much people made that mistake , the tools are different in the differend Countrys where the machines are made for , look for a manual its free for your model
https://www.boschtoolsservice.com/home.aspx?WT.ac=BT_Replacement
Jan 15, 2016 | Bosch Hammering
How do i chack bosch 60 lb jackhammer oil leval
Bosch hammer uses grease available in repair kit. Check ebay or parts house. Remove four hex bolts on the mid section of the hammer and pull off the lower end. Most of the grease goes here. There is a side cover to expose the drive gears if you hear gear noise. Depending on use, only needs grease once a year. Good luck.
Jun 30, 2014 | Makita HM1500B 42 Lb. Demolition Hammer
Bosch demolition hammer wont hammer
MUCH NEWER BOSCH demolitionhammers have a special consumables kit you MUST use anyway its marketing technical made exactly on the calculated operating hours.
Every tools has his own kit and by the heavier models of powertools a very special lubricating oil instead of grease that was used by the older tools that are working with a slower tapping block instead of a very fast battle piece.
Apr 12, 2014 | Bosch Hammering
Bosch demolition hammer bearings are ceased up, how can I remove it properly to replace?
Ok here goes. Purchase or use the bearing cover nut 3613461500 that you have taken from the base of the machine. and drill a 6mm hole in it. remove the armature from the machine and measure how far the end of the armature sticks out of the bearing. then fit the cover nut onto the bearing holder and whilst supporting the cover nut use a puller or press to press the armature off the bearing through the cover nut. Replace the bearing in the holder and press the bearing and holder back onto the armature until the amount of armature shaft showing is to the same distance that measured in the first place. Hope this helps.
Dec 13, 2012 | Bosch 11316evs Elec Vs Sdsmax Demolition...
I have a Bosch 0611 305034 Demolition Hammer and it has quit impacting
1 617 000 036 = a Wear and Tear part set for neccesary.
May 23, 2012 | Bosch Hammering
It won't rotate. It only hammers.
The 11316 Demolition Hammer is made to hammer only, it does not rotate the bit. It is for demolition with pointed bits or flat and scraping chisels. If you want to drill holes in cement you need a rotary hammer drill.
Dec 23, 2010 | Speed Bosch 11316evs Variable Sdsmax...
Bosch 11316EVS doesn't star. Power cable is good What another issue is possible?
most common problems with these units is brush replacement, or even the on/off switch, I work for a home depot tool rental and are constantly replacing the brushes.
Oct 09, 2010 | Bosch 11316evs Elec Vs Sdsmax Demolition...
Solution for Armature winding technique used in demolition machin
Maybe contact people from this factory to become some technical information about your question Possibly more likely than Bosch try it. succes https://www.alibaba.com/product-detail/1614011072-armature-suitable-for-BAK-GSH_60330652111.html
May 05, 2017 | Bosch Sds - Max Demolition Hammer
Jul 05, 2009 | Bosch Hammering
Hammering Logo
179 people viewed this question
Top Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
