Question about Acer Aspire 5630 Notebook
Touch pad not workin
My touchpad is not working. I had possibly disabled it by pressing Fxn F7 but when i enable it again the arrow moves around and when I attempt to click it highlights the button and looks like it is going to work but doesn't
  • pmorehead Jan 16, 2009
    In addition to my problem above I can use the buttons below the touchpad to click and the touchpad moves the mouse but the pressing on the touchpad to "click" or "double click" and not using the buttons does not work. Any thing else with this? I tried the restore but couldn't get back far enough to restore back to where I need to.
    what is CMOS and how do i get there
  • Acer Master
  • 4,338 Answers
If Fn+F7 did not work, I would suggest that you plug in a USB mouse and then go to the Control Panel.
From there, you may want to check the Printers and Other Hardware section and then click on the section called Mouse.
If there is an option to enable the touchpad, I would suggest that you check that it is enabled.
If that doesn't work, you may want to try restarting your computer and if that still doesn't work, perhaps you should try doing a System Restore to a time when it did work.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Jan 13, 2009
  • JDTec
    JDTec Jan 16, 2009
    Have you gone into CMOS setup and turn the touchpad on then exit, then enter it again and enable the touchpad?
  • JDTec
    JDTec Jan 16, 2009
    Hit F2 as the unit reboots.
The mouse pad has stopped working on my sons emachines e430 how can i get it start working again???????
At the top of the keyboard there is a touchpad toggle button (enables and disables the touchpad) that may automatically be disabled at boot time.
You will see just above the keyboard three oval silverish buttons the first one on the left is to enable or disable the touchpad.
Here's the official site for the manual showing all the function keys and features:
http://support.gateway.com/us/en/emac/product/default.aspx?tab=1&modelId=1875
Mar 05, 2011 | Acer Computers & Internet
How do I turn off the touch pad on my Acer Aspire 5742 laptop
Thank you for using fixya. My name is Carlo.
There are two ways that you can do to turn off/on the touch pad in your acer aspire.
1. Press FN + F7. It will turn off the touchpad and will turn on once you press the same buttons again.
2. If the buttons do not work. You can do this:
1. Go to control panel>hardware and devices>Devices and Printers>Mouse
2. CLick on the last setting on the right.
3. Click on Disable in the Mouse Properties.
5. Click OK.
Just go to the same area when you want to enable your touchpad again.
I hope this helps.
Carlo
var geo_Partner = '82910b1e-9b92-42fd-b83f-fa09a0787ae7'; var geo_isCG = true;
Mar 01, 2011 | Acer Aspire 5742 Notebook
Hi there my acer Aspire 5732Z touchpad is not functioning properly and when I type text in word the cursor jumps all around
turn off the touch pad by pressing icon_touchpad.pngor press Fn+ F7 then try typing , actuall thing is your hand is touching the touchpad while you are typing
Jul 03, 2010 | Computers & Internet
Acer touchpad not working
Hi thre can you please check the touch pad mode? May be its disable some how. Or try to press FN+ F7 key for enable / disable touch pad. What is happend please let me know. Thanks.
Mar 18, 2010 | Acer Aspire 3680-2682 Notebook
How do I turn the synaptic touch pad off on my acer aspire
This should be an easy fix...after many months of trying to disable touchpads on machines that did not have the one button disable feature either in the control panel or on the touchpad itself I discovered it was one of the function keys.
Press function (FN) and the "F7" key...press again to re-enable. Good luck!
Dec 21, 2009 | Acer Aspire 5100 Notebook
The touch pad has suddenly stopped working on my laptop so that I can not move the cursor around the screen. Have tried turing laptop on and off again.
There is probably some type of touchpad disable button on your laptop. You didn't mention the make or model of the laptop, but HP's for example, have a small button above the touchpad with a blue light. If the light is off, the touchpad is disabled.
Look around on the laptop and there is probably just a button that needs to be pressed to enable the touchpad
Apr 26, 2009 | Dell Computers & Internet
Touch pad dosent work
Hi
I'm not sure please try pressing Fn+F9 (or try Fn+F8 or Fn+F7)
this should enabled/disable the touchpad.You also can enabled/disable it through a pointing device software.
goodluck,takecare.
May 21, 2008 | Acer Computers & Internet
Gateway notebook touchpad
Thank you mewms_14904. The problem was the F key. In my case it was F7 that enables and disables the glide pad of my notebook.By pressing fn key and then F7 solved my case.
Apr 16, 2008 | Gateway MT3705 Notebook
Touch pad
I believe your touchpad is damage, but did you try to use Fn+F7 to enable touchpad.
Just in case your touchpad is disable when you start.
Feb 03, 2008 | Acer Aspire 3050-1733 Notebook
Touch pad on/off utility
Disabling or enabling the TouchPad The TouchPad is enabled by default. To change the enable/ disable the TouchPad setting: 1 Click Start, Control Panel. The Control Panel window appears. 2 Click Printers and Other Hardware. 3 Click Mouse Properties. The Mouse Properties window appears . 4 Click the TouchPAD ON/OFF tab. The TouchPad ON/OFF tab appears. 5 Select Disable or Enable, whichever is appropriate. 6 Click Apply.
7 Click OK. The Mouse Properties window closes. 8 Close the Printers and Other Hardware window . 9 Close the Control Panel window.
Nov 11, 2007 | Toshiba Qosmio G25-AV513 Notebook
Acer Aspire 5630 Notebook Logo
56 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
