Question about Emerson Televison & Video
Trunes off by self
It turnes off as soon as you try and turn it on. The light flashes 3 times and gose back to standby.
    Problem Solver:
  • 12 Answers
Try to replace the horizontal output transistor
Posted on Jan 13, 2009
I have a 70'' monitor that turns its self back onto standby as soon as i turn it how do i fix the problem do i change the power supply board .the standby light keeps flashing red
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
May 27, 2015 | Televison & Video
No picture
can you please mention your tv model
Jun 12, 2008 | Sony FD Trinitron KV-32HV600 32" TV
Sony LCD turns off 34 flash turn on 30sec repeats ...
The self-diagnostic function of the projection television will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue, some of which you may be able to resolve without the need for service.
  • If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
  • If the STANDBY light flashes four times in sequence, the television may be overheating. To resolve this issue, ensure that the back of the television is well ventilated.
NOTE: If the television will not turn on immediately after being turned off, wait for the fan to finish its cycle, then attempt to turn it on again. This is part of the cooling process of some projection televisions and is normal operation.
If the flash sequence is not listed above, or the light continues to flash after troubleshooting the indicated issue, follow the steps below to perform a power reset on the television:
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
lno2()
Dec 14, 2007 | Sony Grand WEGA KF60XBR800 60" Rear...
Green light on tv trunes tv off. then green light gose off @ ON
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filtercover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cablebetween FMT and Engine disconnected
Jun 17, 2012 | Televison & Video
My standby/timer light is flashing and will not turn on.
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jun 02, 2011 | Sony KV-27S66 27" TV
Can not turn TV on. The standby light shines but nothing else lights up. No picture tube light.
the set having self diagonize function the system detect the error and gose to standby mode but number of blinking shows the error code and blinking code can be download form the net
Sep 02, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Playstation 3 goes on standby and red light flashes as soon as i turn it on
turn it on cover it in lots of towels leave it for 30-45 minutes it should work it worked with me good luck
May 14, 2010 | Sony Playstation 3 (PS3) Console
40'' Sony Bravia goes into standby with the light blinking 9 times
I finally managed to solve this problem by unplugging everything - scarts - HDD cables - power etc and left it for an hour. When I turned it back on again the problem had sorted itself out.
Sep 30, 2009 | Sony Televison & Video
Televison & Video Logo
29 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
