Question about Electric Mobility Mobility Electric Power Scooter Wheelchair. Heavy Duty
My rascal 889 scooter slows down and then speeds up by its selve
As I drive along the road at full power sometimes my scooter slows down and will then speed up again The scooter is only three years old and does not come out in the rain the batteries are always fully charged Any suggestions Thanks Kenny
gewiz
  • 1271 Answers
SOURCE: electric mobility Rascal 265 LE scooter won't run
Are you sure the batteries are charged ? Is the Battery charger charging ok ? Are the batteries connected ? take off seat and cover to check battery leads, does the key fit in the lock okay ?
Posted on Jun 13, 2009
  • 23 Answers
SOURCE: electric mobility scooter says charge is full but won't run
This sounds she has tripped her circuit breaker. It works just like the one on your house, when you ask too much of it it suddenly goes 'pop' and seems to be dead.
Looks like you have the same scooter as mine, it should be a little white button on the back of the base. If you follow this link, it will give you a pdf version of the older model pride victory manual, (Mine is a three, they are up to about 10!) See fig. 8 on page 20 and 'Circuit Breaker' on page 21. Also, Page 33 has the troubleshooting info. Hope this helps.
http://www.rentascooter.com/downloads/_manuals/pridemobility/Pride%20Victory%20Owner's%20Manual.pdf
Posted on May 06, 2010
  • 177 Answers
SOURCE: I have a milan mobility scooter,turn the key & it sounds a low
Hi. This sounds difficult. I have had a few scooters move slowly forward or in reverse, but not both. Normally if the speed pot ( wig wag ) is not exactly in the central position, they can do this.
It is possible for a scooter to have your problem, if the speed lever is binding or rubbing on the housing. Normally the lever is returned to the middle by a spring around the speed pot shaft. If this spring is loose or broken, then this could also cause the problem. Sometimes a small spot of oil or grease will help.
To check the speed lever is in the middle, slowly move the lever for forward untill you hear the brake solenoid release. Now release the lever and slowly pull it for reverse untill you hear the brake solenoid release. Make sure that the speed lever moves the same amount for forward as it does for reverse. If not adjust it with the key off.
If you get the machine to drive properly, then change the controller to see if it is OK.
As for the beeping, a lot of machines will go into an error mode if the speed lever is not in the central position when you turn the key on. This is a safety precausion.
Good luck. Neil.
Posted on Jun 07, 2010
Testimonial: "hello,thanks for ur info.i came to be here by paying for it,then ended up answering questions for others,my scooter is still not working.its a long story but i have learned a lot & have lived my life helping others.i recently downloaded info from shoprider,not having my scooter has depressed me like you wouldnt believe,but i will eventually get it sorted,this is my email if you wish to exchange info,i was punched off my scooter last year & suffered concusion.hence i have a problem getting to grip with things at times.the CPS dropped the charges against the young male 150 people there i had it put in local paper for witnesses with no help lol.gotta laugh whats the point moaning colintaylor1957@hotmail.co.uk"
  • 177 Answers
SOURCE: Scooter stops intermittenly
Hi. Does the machine stop suddenly, or does it slowly stop as it normally would? Does this happen on hills or slopes?
A lot of scooters have a self-resetting circuit breaker connected to the battery leads. If the machine draws to much current ( amps ) then the circuit breaker trips out. After a few minutes the circuit breaker will reset and you can continue.
This could mean that the circuit breaker is faulty or that the motor is drawing to much current, or is burnt out.
Some machines have a very light duty circuit breaker, and these can trip out often. I have changed many of these circuit breakers for this reason.
Check all your battery leads are secure and tight.
If it is still a problem, get a serviceman to check the motor current is what it should be.
Good luck. Neil.
  • 31 Answers
SOURCE: The victory 4wheel scooter is slow even though the
One of the batteries out of the two are prob bad. This is common.
Posted on Jun 26, 2010
Rascal Candy Apple. Why did it stop moving while I was driving it?
On the rascal, if your driving along and it suddenly stops, the throttle lever could be bad or the speed control could be bad or both. A battery lead maybe loose. The tiller cable may have slid back causing line interruption.
The flashing 4 indicates current timeout, the scooter may have been going up a steep hill, over heating the motor, turn off and allow motor to cool. then try again. if this happens on flat ground then check the parking brake, it maybe hanging up causing the motor to over work. Other trouble-shooting information for rascal, scooters on my free app.
Scooter Doctor App
Aug 11, 2015 | Health & Beauty
I replaced the throttle pot asmy.on my Rascal 245. no speed. need a manual or schematic
hi, can i ask where you got the throttle assembly from ?
Regards
www.gewizrepairs.co.uk
Oct 12, 2014 | Health & Beauty
Rascal 600t
Yes, sounds like faulty brake.
Aug 09, 2014 | Health & Beauty
How to make rascal 600 scooter fsater 5 mp.
in order to get it to go faster, you could put larger wheels on it, or get an OEM programmer to adjust the speed. They did not want to be sued so they did not make them available. any of the higher speed scooters have hand brakes. There probably is a market to sell ways to speed up Rascals, but I can not except the liability. sorry Scooter Doctor App
Feb 12, 2013 | Electric Mobility Rascal Scooter...
Today i got a rascal329le mobility scooter and i did not get a manual with it and i dont know what the turtle switch is for, its above the speed knob in top right of 'dashboard' could you tell me...
The turtle switch is the low speed range. This is so you creep along at slower speeds inside buildings etc.
You should be bale to get a manual from Rascal. Call the customer service center at 1-800-257-7955
That should be the right number if not contact any local reseller and they should be able to get your in touch with Rascal.
Sep 01, 2011 | Health & Beauty
My Rascal 655 scooter has slowed down to about half the max speed and won't go any faster. Also it doesn't go through the automatic slowdown when making a turn like it did before. It has a full charge and...
Hi. Sounds like you have accidently moved the high/low switch. Sometimes called the indoor/outdoor switch. Some switchs are marked with a turtle and a hare.
Check your manual for the position of the switch.
Good luck. Neil.
Jul 08, 2010 | Pride New Mobility Legend 4 Wheel Scooter
My shoprider cobra loses speed when I am on top speed.
Hi. Does the machine do this more soon after removing the machine off the charger? When a mobility scooter is going down hill, the controller feeds the voltage generated by the motor back into the batteries. When I an testing machines here at the workshop, I have seen cases where 10 to 12 amps is going back into the batteries on a down hill run. If the batteries are fully charged or unable to take much current, the controller slows the scooter right down to limit the higher voltage generated.
It might pay to check the battery leads and connectors as well, and get the batteries tested.
While you are driving along, try moving the speed lever slowly up and down, not in and out as you normally use it. Sometimes a faulty speed pot ( wig wag ) will cause the speed to change.
Good luck. Neil.
Feb 14, 2010 | Shoprider Sprinter Jumbo 3
Mayfair freerider mobility scooter - keeps losing power, especially on slow speed
ok, sounds like the speed pot,
Can you move the throttle lever up and down, try going along at a constant speed (losing power ?) then move the lever up & down ?
does it improve response ? if so replace the speed pot.
Regards
GeWiz.
Oct 18, 2009 | Health & Beauty
Rally PRIDE 3-WHEEL SCOOTER
Sounds like you have a bad throttle pot. You`ll need to check the resistance on it or take it to a dealer.
Dec 29, 2008 | Pride New Mobility Rally 4 Wheel Scooter
Electric Mobility Mobility Electric Power Scooter Wheelchair. Heavy Duty Logo
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
