Question about Dell Latitude C640 Notebook
Want to know some information about ...
When u open the cover of the RAM there is another empty slot, i want to know what's that
No its not for ram, i have the same pc....its for optional built in wireless the cards are like 50 bucks...also there SHOULD be two black wires not connected to anything...those are the antenneas that you would coneect to the option wireless card.. you cant add ram there sorry..
Posted on Jan 15, 2009
    Novelist:
  • 180 Answers
That's your expandable slot that will let you add more RAM if you want to beef up the system. Generally, you'll slide it in at an angle until it seats and then push it down into the laptop to lock it into place. This is by far one of the easiest and cheapest things you can do to speed up your system! Give it a whirl-RAM is cheap.
Please help me out by rating this tip accordingly if you liked it.
Posted on Jan 13, 2009
  • 837 Answers
More RAM can be added
  • 170 Answers
You can add another stick of ram there
HOW TO UPGRADE RAM ON VAIO VPCM121AX LAPTOP
Memory Upgrade for Sony VAIO VPCM121AX Netbook Laptop, the Sony VAIO VPCM121AX Netbook Laptop takes the PC2-6400 DDR2 SDRAM SODIMM 200pin memory Memory Type, and comes installed with 1GB (Removable) of Memory.
You can upgrade your Sony VAIO VPCM121AX Netbook Laptop to up to a maximum of 2GB Memory, the system has 1 Socket to install Memory, already with 1GB (Removable) standard Memory installed.
For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
if you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line
from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
Power off the computer, and unplug it from the power source. Close the computer and turn it over.
Slide off the battery cover and remove the battery.
Locate the memory bay and remove the screws in the cover.
Remove your old RAM board(s) by pushing the metal clips and holding it down and outwards until the RAM board pops up. Then pull it out at a 30-degree angle. (If you only need to add more RAM to your existing RAM and you have enough available empty RAM slots, you will not need to remove the RAM.)
5
Insert the new RAM board into an empty slot at a 30-degree angle until you hear it click. Then push it flat down into the slot.
6
Replace the cover and screw it back in.
Upgrade the Sony VAIO Hard Drive
7
Locate the hard drive bay and remove the screws from the cover. Then slide the cover off.
8
Pull the hard drive out of the bay.
9
Remove the screw securing the hard drive with the magnetic screwdriver.
10
Pull the hard drive out of the bay by the black tab connected to it.
11
Re-insert your new hard drive into the bay and replace the cover.
hope it helps
Jul 15, 2012 | HP Pavilion dv7 Keyboard (483275-001)
Need to know how to install additional ram
There is a little door under the laptop, with a couple screws.
If you open it, you will see the ram modules.
They are easy to remove and replace with additional (if empty slot available) or upgraded ram.
Aug 08, 2011 | ASUS Computers & Internet
I WANT TO KNOW WHAT TYPE OF RAM, HOW MANY PINS ETC.AS WELL AS HOW MANY SPARE SLOTS MY PC HAS SO I CAN UPGRADE IT
Hi quistcris,
You can check the type of RAM on the RAM itself it if says DDR or DDR2 , or SDRAM.
You can also check this by the RAM's design , you can search online to check the different desings of RAM depending on their type.
Now as far as the slots are concerned , you need to open your cabinet and check the slots which are empty just besides the one in which you have your RAM installed.
Hope this helps ..:) Let me know in case there are any queries.
Aug 03, 2011 | Computers & Internet
I need Help Installing additional ram on my compaq presario cq56. I have an addition 2g of ram i would like to install on my laptop and i dont know where to begin please help???
Power down your laptop and remove A/C adapter and battery. Be sure to ground yourself to prevent static electricity transfer. Small panel in the middle of bottom of laptop. Remove screws and laptop RAM is right there. Be sure your RAM matches as far values and doesn't exceed maximum size supported. There should tabs that hold the RAM in. Replace pieces of RAM. Computer should recognize the new hardware and acknowledge it when you power it up. Hope that helps..
Jul 15, 2011 | Compaq Presario CQ56-115DX Laptop
I want to increase ram, what do I get
First, you have to find out the max of ram that you can add to your pc. Then go to the website crucial.com and run a test where it will tell you what memory and how much you can add. If you decide to purchase the memory and after you recieved , open the case and locate the empty slop where the memory is going to be install. It should be the small slots not the white big ones. Then carefully open the case from the memory and then put i on the slot of the pc. Turn the pc on and then see if it recognize it
May 24, 2010 | Systemax Tiger (SYXS-DC-1000) PC Desktop
I can't get my Acer aspire e380 to accept another
How many slots for RAM in the motherboard?
If there are 4 slots, are the slots equally-spaced, or are they located as two pairs of slots, with a gap between the 3rd and 4th slot?
Some computers _REQUIRE_ RAM only in the 1st and 3rd slots, or only in the 2nd and 4th slots.
Some computers "beep" when 3 out of the 4 RAM slots are populated.
Some computers require the size of the RAM in the 1st slot to match the size of the RAM in the 3rd slot,
and the size of the RAM in the 2nd slot to match the size of the RAM in the 4th slot.
Does your computer "beep" when one stick is in the first slot, and the other slots are empty? How much RAM on that stick?
Does your computer "beep" when one stick is in the second slot, and the other slots are empty? How much RAM on that stick?
Does your computer "beep" when one stick is in the third slot, and the other slots are empty? How much RAM on that stick?
Does your computer "beep" when one stick is in the fourth slot, and the other slots are empty? How much RAM on that stick?
Does your computer "beep" when one stick is in the first slot and a matching stick is in the third slot, and the other slots are empty? How much RAM on those sticks?
Jan 23, 2010 | Acer Aspire E380-UD420A (ASE380-UD420A)...
How to install PNY OPTIMA 2GB DDR2 667 MHz memory card in lap top
Turn the computer off.
Remove the battery.
Unplug the AC adapter.
Turn the computer bottom-up.
Look for a few screws that secure a small panel.
Unscrew those screws, and remove the panel.
If you've selected the right panel, you should see your current RAM.
On the LEFT and RIGHT edges, there are small "fingers" that are holding the RAM.
Gently pull those fingers away from the RAM, and it should pop-up slightly, and you should be able to remove the RAM.
Notice that the "notch" in the middle of the RAM is slightly off-centre.
Insert the new RAM into the socket, and gently press down, until those two fingers "click" to grab the new RAM.
Depending on your "old" RAM, you may have:
* one "occupied" RAM slot (1GB), and one "empty" RAM slot;
* two "occupied" RAM slots (512MB/stick).
So, you may have to remove one RAM stick, to expose an "empty" RAM-slot "hidden" under the RAM.
Or, the "empty" RAM-slot may be visible without removing the RAM.
Or, you may have to remove one of the 512MB RAM-sticks, in order to free-up a slot for the "new" RAM.
Replace the cover-panel, and screw it in.
Reconnect the battery.
Reconnect the power-supply.
Start the computer.
Click Start
Point at My Computer
Right-mouse click on My Computer
Choose Properties
It should display your CPU-speed and the "new" amount of installed RAM.
Dec 10, 2009 | PNY Computers & Internet
No power at all when i try to turn it on
If the CPU (Processing unit) is not switching at all, then first thing you can check is your RAM.
Switch of the power supply and unplug the cables. Then open the top cover (or whatever your CPU has) of teh CPU and remove the RAM from its slot and install it again (place it in its slot as it is). Or if you have 2 slots for the RAM and only one RAM installed then try installing (placing) the RAM in the other slot which is empty.
Plug in all the cables and switch the power supply. This method works most of the time.
Gud luck.
May 04, 2009 | Computers & Internet
How to install new ram into the 2840
Unplug the machine. On the right side of the machine you will find a cover. Remove the cover and you will find 1 open slot. The machine can take a total of 224MB (96 is built into the machine) leaving 128 available. The memory type is 100pin, 133MHz, SDRAM DIMM.
Simply click the memory into the blank slot and replace the cover.
Once completed, plug the machine back in and print a configuration page. The memory total should be at 224 once you have installed your 128MB.
Good Luck
Jul 24, 2008 | HP LaserJet 2840 All-In-One Printer
Where to get memory upgrade installed
open the side pannel then you will see the ram installed in slot, just put the ram module into the empty slot and gently push it, the latch in the side of the slot will close with a click sound
May 14, 2008 | Computers & Internet
Dell Latitude C640 Notebook Logo
Alun Cox
