Question about Plumbing
Bath tub faucet removal
Can not figure out how to remove the existing jameco/CBM tub faucet
  • 171 Answers
SOURCE: Moen Bath Tub Faucet
Hi varn4620,
I'm Harvey the Master Plumber.
Your question is: You had to replace the faucet in the tub due to a broken plastic piece in valve stem. Bought a Moen ripped the wall out and put new faucet in. Went good untill we turned the water on and the shower rained on us. Tightened everything you could find to tighten .Every time the water is turned on the shower rains. Can this be fixed or is the faucet broken?
Is this new faudet a single handle? If so I"ve had this experience also. Most of the time it's because the guts were not lined up properly at the factory. You may have to play with it a bit.
Turn off the water and take the handle off and remove the sleave, remove and rotate the guts. Try 90' at a time. Turn water on to try it. Useually one of the other 3 positions will be right. The correct position is there, but it may take time to find it.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 21, 2008
  • 34 Answers
SOURCE: peerless single control bath faucet drips
If it is a ball cartridge then it should just pop out with a flat head. This is of course after you unscrew the metal cover off of it.
Posted on Feb 04, 2009
SOURCE: just installed shower and faucet in bath tub when
Verify the height from the shower valve to the Shower head, the instructions specify the correct distance if it is too short the pressure could be getting up to the shower head.
Perhaps the water pressure it too high at the valve not allowing all the water down the faucet outlet, there are set screws on the sides of the shower valve to adjust the water allowed in the mixing chamber.
Something is restricting the water flow to the faucet, creating enough pressure to send some of the ater supply up to the shower.
I hope some of these ideas help
Posted on Mar 16, 2009
SOURCE: Need Mixet generic for bath-tub faucet flange in ORB color
Gave up on Mixet. Never has worked properly after many plumber visits. Going to tear out the tile and go with another product.
Posted on Sep 19, 2009
  • 127 Answers
SOURCE: Moen - Single lever bath tub faucet - cold water only
moen does not have a ball and washers....sounds like a Delta maybe. Moen uses cartridges. Either way sounds like a balancing spool problem....but you will need to make sure of the right name for the faucet to get the parts.
Posted on Oct 18, 2009
Does anyone have a video on how to install a 3s10h/c value kit in a bath tub faucet?
LOOK UP ON LINE UNDER 3S10H/C VALUE KIT FOR BATH TUB FAUCET. SEE IF THERE IS A MANUAL OR A TROUBLE SHOOTING PAGE.
Oct 11, 2014 | Delta Plumbing
Tip
How to repair a washer-type bath & shower faucet
  • To take apart a bath/shower faucet for repair, first turn off the water. Then take the faucet apart by removing its handle, escutcheon and packing nut. The packing nut may be buried deeply in the wall, requiring a socket wrench for removal.
  • Your bath and shower faucets may have a renewable seat that can be smoothed with a seat-dressing tool or removed and replaced using a seat wrench. For replacing and repacking the washer, follow the same instructions provided for a washer-type faucet. Some faucets may need a complete replacement of the combination stem/seat unit.
on Jan 16, 2010 | Plumbing
Replace tub faucet
pry plastic cap, under cap remove Phillips screw,pull handle and replace
Oct 16, 2013 | Price Pfister Single HDL Bath Faucet...
Water Will Not Turn On
shut off water to tub. remove the faucets one at a time. maybe the faucet washers on the bottom of the stems came off.
Nov 07, 2011 | Home
I would like information on steps to remove bathtub and install pre fab shower
This is a fairly big job but can be done if you have the right tools and a little bit of time....... Depending on the existing tub material (cast iron,fiberglass, tin type ). You will want to remove faucet trim(handles,spout) first. Then the over flow plate on tub,as well as drain in the bottom (this will require a drain removal wrench or pair of needle nose pliers and screw driver, and some strong arms).After this is done remove tub unit , if the unit is a cast iron unit a good sledge hammer will work as you will need to break into halves to remove unless your trying to save tub and provided you can then get the unit out the door in one piece...... Caution, protect body and eyes in this process, flying pieces of cast iron can do some damage to body......cutting tub will take several blades and take quite a while to do......The next step depends on the location of faucet and if you are replacing the tub faucet or going to use the existing faucet.... I would recommend a new faucet because if this is going to be a shower only you may want to raise the faucets so they will be easy to operate without having to bend..Depending on the model pre-fab (two piece,three piece) unit you wish to install you may need to prep the drain to make sure it will fit your new installation. Let me explain... most tubs have the drain located at the right/left end of tub and the showers are located in the center of the unit thus leaving you to relocate the drain. If house is on slab it means a little jack hammering the concrete to provide this, if the floor is a conventional it means re-routing the drain to the center.......once all this is accomplished you are ready to install unit base,connecting drain. Next you need to get the faucet located to the right height or be able to get to the back side of the shower and remove the existing faucets and replace them after you install surround.....turn off water supply before removing faucet..... A sturdy surround will make for a less involved support system around shower area.Be sure to leave enough space between studs for faucet attachment. Sounds like a lot of work and it is but after its done you will have a great bath shower..... hope this was helpful.... sorry this only dealt with the plumbing aspects of the job......
Sep 05, 2011 | Home
The bath shower faucet provides no hot water, we figure we need a new cartridge but cannot figure out how to get the handle off. Moen INS930B. How do we remove the little 'button' that covers up the...
just take a drywall knife and place it btwn the handle and button and pry off...should nt be the turning type as moen doesnt make those..once you have the handle off make sure water supply to house if off..cartridge has cotter pin to remove but will still be hard to pull it out..use a bit of muscle as suction is created but it will come out after removing cotter pin
Nov 21, 2010 | Moen & One Handle Tub & Shower Faucet
Leaky single lever bath tub faucet
Faucet is leaking due to seats bad.
1- Turn water off first and remove handle and remove collar that holds stem and remove it..
2- in valve there are seats that looks like caps they may be in valve body or the end of stem itself.
3- Remove them and the springs and replace them this will take care of the leaking problem.
May 21, 2010 | Delta & Single Handle Shower Faucet
Old faucet doesn't have a replaceable seat..new does
you bought the wrong one you need to get the right one the are the same and not diffrent.
Apr 26, 2010 | Delta & Single Handle Shower Faucet
I have a price fister BATH faucet set installed on an old bathtub> i would like to remove the knob that actuates the stopper mechanism. it is slightly triangular in shape and it does not seem to be a...
You will have to change out the waste and overflow. This is not a hard job, unscrew drain from tub, remove overflow plate and disconnect from p-trap. Go to local home improvement store and buy a new waste and overflow kit, many to choose from. Reinstall .
Oct 03, 2009 | Geberit Bath Waste and Overflow Tub Drain...
Plumbing Logo
52 people viewed this question
Top Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
