Question about Refrigerators
Can jb weld fix a hole in my freezer? I punctured it while cleaning it.
I was cleaning off all the walls that where full of ice. I accidently punctured the coil. I think all the gas escaped. What can I do? I really don't have the money to but a new one right now.
freetek
  • 5568 Answers
SOURCE: hole in freezer of haier refrigerator
The refrigerant used since ~ 10 years is no more dangerous than the one previously used and it is even doubtful that the newer stuff is any better for the ozone layer.
The original coolant could be inhaled without injury as long as one didnt suffocate from a lack of oxygen.
The repair may not be cheap since it will entail the removal and replacement of the damaged coil.
This will require some specialized welding to install.
Using a normal table-top or floor-standing fan to circulate ambient air through the refrigerator with the door(s) open is a safe and fast method for defrosting units that do not automatically defrost.
Just make sure you have some absorbant material in the bottom to avoid water running out of the unit.
Poking the coils with sharp objects can result in the problem you now have or fracture hidden joints that will allow the gas to escape.
Posted on Jul 19, 2008
Tech Jenkins
  • 359 Answers
SOURCE: REPAIR or REPLACE?
OMG ROFL!!!
Well... here's an idea.
Drill a 1/2 inch hole where you punctured the wall of the freezer, make sure you don't hit the coils. Then goto lowes/home depot and get that expansion foam that is used to insulate windows and holes in houses. Grab a razor blade and scalp off the excess after it's dried. Now cover the foam on the inside of the freezer with 2 part epoxy or "shoe goo" or e6000 (these are the toughest glues I have ever used) which is available at a hobby shop. Make sure you do a test with the foam and the glue on cardboard first to make sure the glue won't eat at the foam.
Are you sure you punctured the coil? If you did you can goto an auto part place and ask for a compression fitting (most commonly used to repair brake lines on cars) for what ever tube size the coil is, use a fine ruler is the best. Then you can repair the coil by using a pipe cutter to cut the coil and put it back together with the compression fitting. Now call the appliance service guys and have them come out and recharge the system.
Fixed, total cost... about $50 bucks
Other solution, replace entire fridge, total cost $$$$$
Posted on Sep 04, 2008
Bat1956
  • 585 Answers
SOURCE: Punctured a hole in the freezer compartment
That type of damage is usually fatal to the unit. It is difficult if not impossible to repair in most cases depending on the metal used to make the evaporator, and what kind if equipment the repairman has. You can't fix this yourself, consult a local repairman, explain what happened, and the model of the unit, and ask if repairable what it might cost. Or just buy a new one. And NEVER use sharp objects in an effort to remove frost buildup. Turn it off, put your stuff in a cooler, and use a heat source such as a bucket of hot water in the unit with the door closed
Posted on Jul 18, 2009
2coolrick
  • 560 Answers
SOURCE: G.E. side by side Freezer Coils and back wall full of ice.
If you replaced the "defrost timer", and the circulation fan runs ok before the ice buildup occurs, you will have to melt the ice so the panel will come off. Then, pull the back panel off and inspect to components. First, the defrost element and connections to it. If connections are good, disconnect 1 connector and check the resistance of the element itself with a ohmmeter. It should be 40-150 ohms, depending on the unit. If it is excessive or infinate, replace the element. If it is ok, leave the element disconnected and check the other component (defrost termination switch) which is clamped onto the evaporator coil and has two wires attached to it. It should read 0 to 2 ohms at room temprature, and no more than that as it is a temprature controlled switch. If it has excessive resistance, replace it. These are the only 2 components, aside from the defrost timer, that encompass the entire defrost circuit in most refrigerators.
Posted on Jul 31, 2009
aasc
  • 1606 Answers
SOURCE: need freon recharge. punctures freezer coil in
You punctured the aluminum evaporator . In the many years I've been in refrigeration , I have yet to find any way to patch a hole in the evaporator . I've used epoxy , solder , and all different advertised ways to try to patch aluminum . Nothing worked ( for long anyway ) . My suggestion would be to buy another refrig . You will be wasting time and money trying to " fix " this problem . To repair it yourself , you have to have a license to buy R12 , maybe you can buy R134A without a license , you have to look on the " modell , serial number tak to see which it uses and how much to use . Also , the system has to evacuated ( all air removed from the lines ) . Do you have a vacuum pump ? You have to buy a solder on connector ( or saddle valve which WILL leak eventually unless you get a solder on valve ) which will connect to the larger tubing on the compressor or use the access line already on the compressor but is pinched off . Do you have guages for the refrigerant type you need to use ? Once you have these things , reply back and myself or someone else will help you procede .
Posted on Aug 20, 2009
How do you fix a hole in the gas tank
quick temp. fix would be jb weld for small holes i had a enduro motorcycle that had a broken pit **** at the bottom of tank and jb weld worked for me
May 23, 2012 | 2001 Chevrolet Impala
My Bosch KGU3420GB fridge freezer keeps getting a thick layer of ice in the bottom of the freezer which then 'welds' itself to the bottom freezer draw. Any idea how to fix this?
Sounds like the drain is blocked and defrost water is collecting in the base. Try a full defrost and check the drain hole clears.
Apr 23, 2012 | Refrigerators
The chain has snapped and hit the left side crank case and put a hole in it about the size of a 10p. Do you think I could cover this with something and if so can you reccomend anything as the cost of a new...
If you're sure the piece that got punched out is gone and not inside the engine waiting to ruin your day even further then you could in theory get by with good old jb weld.
Remove the cover and totally degrease the thing inside and out. While it's off look for any bits loose inside the cover. Find yourself a bit of steel mesh (window screen) big enough to cover the hole plus a bit. Put the screen over the hole and use a sharpy to mark it's edges. remove the screen and take a drill with a small bit ( < 1/8"). Pop a few holes in the area of coverage of the screen and around the hole. These holes give the jb weld more grip as it will flow into the holes and harden. The holes need not go thru but if a few do its good.
Take a small file and roughen the surface around the hole so the jb weld will have something to grab onto. degrease the area again.......now smear some jb around the hole from the outside and set your screen into the jb weld....add some more jb over the screen. Use a wet finger to smooth out the jb weld (if you add over this then don't forget to clean and roughen again).
Look inside the cover and smooth out any jb that came thru to the inside. Of course you have roughened inside the case so any jb inside will adhere nicely.
Once the jb has fully set you should be good to go....monitor your repair for any leaking. Also look closely for any cracks radiating away from the hole and make sure your repair covers them as well.
Cheers!
Take care.
Dec 08, 2010 | 2000 kawasaki KMX 125
I accidently punctured a hole in a cooling tube in a small kenmore fridge freezer and lost all the coolant.. i have since repaired the hole but can't seem to find the fitting on the compressor to recharge...
If you punctured the aluminum tubing or the freezer aluminum evaporator , it cannot be repaired . If the puncture is in the copper tubing , only silver solder will fix . On the compressor , you will see a short piece of tubing , capped off . This is where the access fitting was . A good technician will ALWAYS remove the access valve , due to possible refrigerant leak . After removing the end of the tube , silver solder another valve into the tubing . Evacuate the system , recharge with correct amount of refrigerant , crimp the tubing at the access valve and remove the access valve . Re-solder the end of the short tubing , and it's done .
Oct 20, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
I HAVE A HOLE IN THE REFRIG.LINE OF A HAIER MO.HC125FVS
Hi, unfortunate, sorry to hear that, but it could be repaired, you should immediately dried up water/ice around punctured area, prevent water/ moisture entering punctured area (evaporator. lines), it's one of the worst thing, that could happened to any refrigeration system, it will be costly to repaired, if water get into your evaporator lines, compressor oil have to be replaced, evaporator will need to be flush out, repair puncture, change filter drier, it's better to replace compressor, vacuum system for about 2hrs. then recharge. it's better to use welding/ soldering, to repair punctured line, epoxy repair kit can be used to repair punctured (evaporator) lines . you will have to call a mechanic, if very little water entered punctured( evaporator) lines, then flushing of evaporator, (internal cleaning of lines (tube) changing of filter drier, with overnight vacuuming will do the job. take note, job like this, cannot be guaranteed. check cost for repairs, sometimes it's better to purchase a new one, and save yourself some headaches.next time never use sharp instruments in your freezer, it happened to me sometimes, it's what you get your hands on, what's available at the moment, good luck.
Aug 15, 2009 | Haier HC125FVS Wine Cooler Beverage Cooler
Hole in radiator
You can try yourself with JB Weld or take to a Radiator Shop and have it Repaired.
Jan 21, 2009 | 2001 Nissan Altima
Punctured the inside wall of the freezer - gas has escaped
you're all done buddy. sorry to say i have never seen in 21 years of doing ac and ref work anyone that could weld aluminum saturated with oil . an airtight hermetic seal is mandatory, and with a hole punched its new unit time. sorry
Nov 13, 2008 | Freezers
REPAIR or REPLACE?
OMG ROFL!!!
Sep 04, 2008 | Thetford NorcoldĀ® Model DE0061
Refrigerators Logo
218 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
