Question about Bausch and Lomb Optics
Info on 4000 elite scope and how to adjust
Elite 4000 rifle scope 4x16 zoom with yardage adjustment
fps353535
  • 99 Answers
SOURCE: lost manual for trophy scope 3-9x40 rifle
There is no manual for elevation and windage adjustments. (at least not one that comes with your scope; all your scopes manual will say is whether its FFP or SFP (First Focal Plane or Second Focal Plane, the scale used on your scope for mil dots)(you can get this info by finding a store that sells this scope and asking a sales rep)
To adjust for elevation and windage you have to take into account the daily factors (unless your shooting in the same indoor environmental controlled shooting range each day you SNOB! jk
The formula takes alot of variables into account and is known as Exterior Ballistics
!) Environmental Factors - First thing you account for.
A) Elevation from sea level plays a large part into your environmental adjustments. Your elevation from sea level determines largely the Barometirc Pressure but it also varies slightly with Temp and Humidity (Major Factor)
B) Temperature - The temperature can affect the density of the air. The hotter it is the thinner it is and therefore less resistance and a higher bullet trajectory (Minor Factor)
C) Humidity - This again will affect the densify of the air infront of your bullet (Minor Factor)
D) Barometric Pressure - The other large factor in air density this is the base stat that the others modify
These all combined create a ratio that you apply to standard MOA (windage and elevation adjustments) to obtain the shooting information for that particular environment)
2) Bullet Factors (Listed on the Box you buy) - There are a few bullet factors to take into account.
A) Speed - the bullets feet per second can vary as much or more than 500 feet per second with the
same caliber ammunition.
B) Grain - The Grain of an ammunition is a measure fo its "Sectional Density" or weight to volume
ratio
C) Ballistic Co Efficient - This number is the measure of the bullets ability to maintain its speed
during flight. This also varies from Grain to Grain
These factors are complex and a pain for the best of shooters to determine. adding to that confusion. there are many ways to determine a bullets ballistics coefficient and each one gets a different number. In this case bullet data is best retieved from the manufactuerers box and take their word for it.
3) Lastly you account for shot factors.
A) Range - by referencing your standard elevation MOA adjustments and mutliplying by the ratio for environment the Elevation MOA is achieved.
B) Windage - Windage is done in inches per mile per hour then is multiplied by the Mph of the wind.
In order to be precise the windage is done in inches instead of MOA. it needs to be converted heres and example.
You Ballistics Cheat Sheet for the day says the windage at 900 yards is 5.2 Inches per mph of wind.
you apply the ratio for your environment .90 (all example numbers. this number would represent a shooting environment with an air density lower than standard/ the cheat sheet's known MOA adjustments). the 5.2 inches is multiplied by .9to acheive 4.68?? idk the point is you mulitply that by the wind of 10 mph to achieve a total of 46.8" of wind drift to the target.
now for the conversion to MOA. 1 MOA is eqaul to 1.047" per 100 yards. meaning for every 1 moa you adjust the bullet will move 1.047" per 100 yards (our target is 900 yards; meaning that each MOA for this target is 9*1.047" = 9.423" per MOA adjustment. so take that number and divide our total wind drift by it. ie 46.8 / 9.423 = MOA Windage Change of 4.9665... now you need to know whethere your scope is 1/4 minute clicks or 1/8 minutes (how many spaces between large numbers?) you would adjust to 5 MOA for a 1/4 minutes scope equaling 20 clicks on an 1/8th minute scope it would be 40 clicks.
This is the math of shooting. to learn how go to
WWW.shooterready.com they are an excellent sight to get the math down WITHOUT wasting ammo. Once you have the math you an transfer it to your gun. waste a few rounds checking it out and youll be hitting targets @ 1800 yards in no time
I like to take the simple way after i learned how to do the hard way
There is software tha will do the exterior calcualtions for you.
if your interested i use Sierra Infinity V6 Ballistics Software
GL
Posted on Apr 08, 2009
  • 5 Answers
SOURCE: I have a model D-4 weaver rifle scope with missing adjustment par
Pretty much all rifle scopes have great warranties. Send it into weaver and i'm sure they will fix it plus replace any parts. I'm sure they will charge for missing parts but it would be best for them to look at it and check it out. TP
Posted on Apr 17, 2009
  • 2418 Answers
SOURCE: rifle scope will not track with the adjustments
When you make your adjustment tap on the scope with a small screw driver handle a few times before you fire her. Work slow and tap as you go.
Posted on Jun 28, 2009
gtmerkley
  • 190 Answers
SOURCE: i have a nikon 3x9 rifle scope. im shooting about
It will stop but don't turn to tight or cross hair will break, but You should never have to adjust that much 12 clicks should do it
Posted on Nov 01, 2009
  • 32 Answers
SOURCE: i just bought a rifle with one on it. exactly how
the adjustment on the front eye PC is your zoom.
for your wind edge you have a series of numbers.
some scopes differ some read 5,10,15,etc
some read 1,2,3,4 etc, the # are estimated wind speed,left or right.if the wind isn't blowing set it on 0.
for your elevation you will have a series of #'s
50,75,100,etc.this is your yard edge sight it in at 75 yrd's and if what your shooting at is 100 yards just turn the knob to the correct setting.good luck
Posted on Nov 05, 2009
When i zoom it all the way to 9 it gets blurry.
The rear lens may have to adjusted for focus at this magnification. If you adjust it at this setting it may be better in focus in the lower settings for you.
Jan 08, 2011 | Nikon ® Buckmaster® Rifle Scope - 3-9 x 40...
I have tasco #62TR rifle scope. I has stadia crosshairs and an adjustable top turret with various ranges for elk, deer, and antelope. However I cannot find any paperwork describing these features, and I...
Sight in rifle and put the on top turret with zero facing back.do not let knob"click".Aim at animal and adjust power(3-9etc)until body is bracketed by both crosshairs.Look in little window in eyepiece for type of animal.Click top turret to proper yardage(200,300etc).This allows for bullet drop.I've had one on a .270 for 30 yrs and never used this feature.
Dec 05, 2010 | Tasco 3-9x Variable Riflescope
On the adjustment turrets, after loosening the set screws, how do you get it to go down so the yardage lines up?
after you sight the rifle in at say 100 yd. lift the turret and line up the 100 yard mark on the turret to the mark, then push the turret down onto the scope and set the screw. some times the turret takes a lot of pressure to push back on.
Mar 29, 2010 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
Bausch & Lomb Balvar 6x24 Rifle target scope
Bushnell owns baush&lomb scope I have called them to repair my elite series bausch&lomb and I have been very happy with there customer service.They might be able to help with your problem to.
Mar 01, 2010 | Bausch and Lomb Bausch & Lomb Hunting...
How to fix jammed clicker on air rifle scope
Sorry to tell you but the crosshair adjustment is more than likely broken. Take it to a qualified gunsmith and he can check it out for you.
Hope this helps, Mark the Gunsmith
Please leave feedback, Thanks.
Jan 12, 2010 | Caliber Gamo USA Hunter Elite .177 Air...
Siting in scope 2 ft hi at 25 yds no adjustment
well at 25ft you will run out of drop, its all down to how high the scope is above the barrel when its fitted to the rifle a 30-06 should be set up over 100 yds and shooting out that far it will be shooting low,,your rifle will shoot right out to 1000yds so you will get about 5ft drop out that far,,,and by the way,,,its very very dangers to discharge your rifle into a sand bag closer that 30 yds,, you may well get hit by a bit of the bullet jacket being striped off the bullet and coming back at you so done do it, right! shoot it over 100yds
however if its still shooting hight at say 50yds the only way to drop the point of aim is pack out the front of the scope mount with a strip of 35mm film slip it under the front ring (not the eye end) and sit the scope on it then do up the screws to nip it up this will lift up the front of the scope and it will shoot lower,,also if you were to put a strip under the eye end it razes the point of aim, i do this often for the members of my club on much biger rifles than 30-06's
and they dont drift or move off aim its a cheap fix, or you need a new mount?
Jan 07, 2010 | Centerpoint Technologies CenterPoint...
I just bought a rifle with one on it. exactly how
Oct 30, 2009 | Bausch and Lomb Bausch & Lomb Hunting...
I have a Bushnell Elite 4200 6x24x40 rifle scope 42-6242M
First is to try for a group, do not adjust the scope in any way. Shoot 4 rounds with out adjusting the scope. The gun should settle down and start to group. If you can not get a group in 6 rounds go clean that gun & check your ammo. Start over. If she does not group, its the gun not the scope. Once it starts to group move the cross hairs in the opp direction small clicks and "TAP' the scope after each adjustment. Shoot for a group each time 2 rounds should group. Get a target that has a grid to help get on faster.
Sep 20, 2009 | Bushnell Elite 4200 6-24x40 Riflescope...
New leupold scope
You may need to purchase a base with a built in taper to help zero your scope. Look for "20 MOA scope base" if interested in purchasing. Go Here:
http://www.thehighroad.org/showthread.php?t=230774
for a discussion and info that may help.
Dec 01, 2007 | Optics
Optics Logo
182 people viewed this question
Top Bausch and Lomb Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Piyal Perera
Piyal Perera
Jeffrey
Jeffrey
Are you a Bausch and Lomb Optic Expert? Answer questions, earn points and help others
