Question about Garden
Husky Tile Saw Parts Model THD950LN
The break on my tile saw seems to have piled up. Motor stops with a clunck and losens off the blade. Where can I get parts or a parts manual
  • 313 Answers
SOURCE: tile saw stopped working
check the motor might have a reset botton or check the capacitor
Posted on Jun 05, 2008
  • 29 Answers
SOURCE: Tile Saw
i know blades on tile saws don't have to be super tight, i'm not familar with that kind of saw, i put a wrench on the nut and hold on to the blade with my hand and hit the wrench with a rubber mallet, and of course have the unit unplugged
Posted on Mar 26, 2009
  • 55 Answers
SOURCE: mY SWITCH WENT OUT ON MY TILE SAW WHERE CAN i GET
You can get the part from husky website at:
http://www.huskysupport.com/products/product.aspx?ID=4
From there scroll down till you see part number
6102018
switch Knob for $5.38
Hope this is what you are looking for
Posted on Dec 02, 2009
SOURCE: husky wet tile saw repair service
I need to order a part for my Husky wet tile saw. can someone give me an email address. web serches are a bust.
Posted on Dec 17, 2009
  • 25 Answers
SOURCE: tile saw thd9501 Husky I need a parts
Grinder/motor assembly is sold as a complete unit only. The cost is over $129.00. My opinion, scrap it, but one at Harbor Freight (get the lifetime warranty (just a few dollars more), any problems, they replace the unit wiht a new complete saw. The quality is no worse than the Husky you own now.
Posted on Feb 11, 2010
Looking for the blade guard arm.
Search Results
    7" Job Site Tile Saw with Laser - RIDGID Professional Tools
    https://www.ridgid.com/us/en/7-inch-wet-tile-saw-with-laser
    Ridgid7" Job Site Tile Saw with Laser. ... Heavy Duty Arm - prevents flexing while keeping the blade aligned; Guard Baffle - reduces air turbulence to help keep water ...
    [PDF]7" BRIDGE TILE SAW
    manuals.harborfreight.com/manuals/97000-97999/97360.pdf
    7" BRIDGE. TILE SAW. WITH STAND. Owner's Manual & Safety Instructions. Save This Manual .... that has an outlet that looks like the one illustrated above ... Use saw-blade guard and spreader for every .... arms and shoulders. To reduce the.
    [PDF]10" INDUSTRIAL TILE/BRICK SAW Owner's Manual ...
    manuals.harborfreight.com/manuals/69000-69999/69275.pdf
    parts. Nonslip footwear is recommended. Wear protective hair covering to contain long hair. 11. ALWAYS USE ... an outlet that looks like the one illustrated above in Figure A:... For Your Own Safety Read Instruction Manual Before Operating Saw. 1. Wear eye ..... Connect the clear water Hose from under the arm of the Motor ...
    SKIL 7" Wet Tile Saw 3540
Dec 16, 2015 | Blade Saws
Cutting porcelain tile with wet saw and it breaks at the end of the cut?
Porcelain tile has to be cut painstakingly slow, especially the last inch or two to prevent the splitting problem you are having. When you are cutting tile, the sawblade rides up just a little as the tile is being fed into it. You'll notice it if you stop pushing the tile through and watch the head drop down just a bit. When you are getting to the last part of the cut, reduce the pressure you are using to push the tile into the blade so the blade can wear away the tile with little pressure and vibration as possible.
Dec 30, 2012 | Mk Diamond MK 370 TILE SAW
Huskey tile saw thd950l motor how much would it cost motor #c5d41884?
Take a look on amazon for sure. Amazon com Husky tile saw. If cant find just a motor, for sure there is someone to answer that question (someone who sells husky saws...). I hope this was helpful. cheers
Apr 12, 2011 | Husky Wet Tile/Stone Saw with with Laser...
Need parts for husky tile saw THD750l need bolt fence
Hi, Take a look at amazon for replacement parts: Amazon com Husky tile saw. Hope this was helpful. cheers
Sep 30, 2010 | Husky Wet Tile/Stone Saw with with Laser...
MY SWITCH WENT OUT ON MY TILE SAW WHERE CAN i GET
6102018
Nov 30, 2009 | Wet International Husky 7" Wet Tile Saw...
The wet saw husky thd 950l wore out yhe bearing and make
I am a contractor who has used this saw for about four years. I just ordered the new motor for $79. The Husky has been a great saw. Don't waste your money buying some junk for Harbor Freight.
Oct 14, 2009 | Wet International Husky 7" Wet Tile Saw...
Husky wet tile saw repair service
Aug 24, 2009 | Husky Wet Tile/Stone Saw with with Laser...
Cant get the old blade off
should be a blade lock button, if not i clip vise grips on mine let the table keep the blade from turning put wrench on nut and tap wrench with hammer see if ya can loosen nut good luck billy
Mar 18, 2009 | Husky Wet Tile/Stone Saw with with Laser...
Crooked cuts
The bearings in your saw need to be replaced. I would contact a DeWalt store to obtain the parts or have them do the repair. You have an excellent saw there, well worth repairing. good luck.
Jan 04, 2009 | Dewalt Heavy - Duty 10" Wet Tile Saw -...
Tile Saws question
Since tiles are so thick, brittle, and made of ceramic, a special saw must be used. An ordinary circular saw for wood or metal would either break the tile or get so hot that it would seize up and stop cutting. However, ceramic tile is not cut well with sharp blades. The wet tile saw was invented to address all these unique properties of ceramic. It doesn't overheat, uses a relatively dull blade with no serrations, and can be transported to a job site and set up on top of an existing table or sawhorses.
Aug 27, 2008 | Dewalt DW8306 36-Grit. 4-1/2" Blue...
Garden Logo
518 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
