Question about Maytag Ice2O 24.9 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Black
I have a maytag ice 2O. Just replaced the HV control board, programmed with code 1411. All seemed well, but the icemaker turns the auger without prompting, and will not turn when the dispenser is depr
Board was replaced due to the ice dispenser door opening/closing constantly and blinking display lights.
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Did you put the correct code in? The code should be listed inside the unit.
Posted on Dec 10, 2012
  • Aaron McDonald Dec 10, 2012
    The new board would not accept the cpode on the inside of the fridge (0302), I found the 1411 code from another string on this site. This code was accepted. Maybe another code exists.
  • Richard Roth
    Richard Roth Dec 10, 2012
    I would call Maytag.
  • 3 Answers
SOURCE: lights flashing all cooling appears normal ice maker flap continually opens and shuts no water buttons not operational
As I mentioned before my Maytag was doing the same thing, I called Maytag expecting a big fight but they were really nice about it.
This is a recall problem and even if your warrenty is up Maytag will repair it at NO COST to you.
They shiped me the HV board and sent a repairman who had it fixed in about 10 minutes with a newley designed HV board.
Posted on Mar 30, 2008
SOURCE: Maytag Ice2O
I had the same problem 4/28/08 - Called Maytag they're sending the part and repairman free.
IN THE MEAN TIME.......Maytag suggested to me to: take a phillips head screw driver and remove the hinge cover from the top of the left door. You'll find a white connector with four wires coming from each side. Disconnect the connector in the middle and the flap will stop (and so will the lights).
Posted on Apr 30, 2008
SOURCE: Maytag Ice20 refrigerator
Thanks, Solution #3, for the phone number ((800) 688-9900)! We, too, have the Ice2O refrigerator, and the HV Board started the disco light show last night. Followed instructions above to disable it, which temporarily solved the problem. Was on the phone with Maytag (Whirlpool?) this AM, and their initial response was that they wouldn't cover anything since we are out of warranty. I had to be extremely firm with my expectation that all parts and labor would be covered. Sent the rep back to her supervisor several times until they agreed to cover both. If you find yourself in a similar situation, don't give up until everything is covered. This is a design issue that should NOT be impacted by an expired warranty!
Posted on Apr 15, 2010
SOURCE: lights on panel blinking. ice dispenser keeps opening and closing
there is the HV board on the back under a cover . 2 680uf capacitors @ 35v are likely domed instead of flat on the top and are likely hot. replacing these with an equal value will cure the problem. they are in parallel so 1000 and 470uf will cure it. mine was same model except white. local dealer said no warranty. did not call maytag but he indicated it might help. good luck
Posted on Jun 02, 2010
  • 1891 Answers
SOURCE: What does it mean when all the lights are flashing
you have a big problem . they call it the jazz board . the main control will have to be replaced . this is only correcto to the problem .. mm
Posted on Aug 10, 2010
Frigidaire frs6lf7fm. Ice maker dispenser, the auger won't turn (tested with ttay out). It makes ice and dumps it into the bin no problem. And the water side is fine.
[FIXED] Icemaker auger motor won't turn - ApplianceBlog
www.applianceblog.com/.../18196-FIXED-Icemaker-auger-motor-won-t...
Apr 16, 2010 - 9 posts - ‎2 authors Does the auger motor need to be re-set or something? I wonder if it shut itself down to prevent burnout (because it had been unable to turn the ... FIXED Auger won't turn to dispense ice.
Jun 1, 2014
Ice maker auger will not turn
Mar 17, 2013
FIXED Ice Auger won't turn
Sep 3, 2012
GE Icemaker: Makes Ice, Doesn't Dispense In Door?
Apr 19, 2005
More results from www.applianceblog.com
Oct 01, 2015 | Frigidaire Refrigerators
Maytag MFI2568AES- ice maker making ice but cannot harvest
Sounds like the thermostat inside the ice maker that allows the heater to come on during harvest cycle is bad. You will need to replace the ice maker.
Ice Maker Kit For Maytag Refrigerator Model Number MFI2568AES
Sep 24, 2015 | Maytag MFI2568AES Stainless Steel Bottom...
Icemaker will not dispense ice. the bin is full. when you push the button the micro-switch clicks and the flap opens, but the motor don't turn. is it the motor or the pc board
You are correct. Motor or Board. See if you can turn auger motor by hand It is geared and should be hard to turn but not locked up. You can also remove auger motor assembly. Plug it into 110v it will run, (replace board) or not. (replace auger motor).
Nov 15, 2010 | Whirlpool GS6NBEXR Side by Side...
I replaced my HV Control Board on my maytag
First did you program the board correctly and second make sure all the connections to the board you replaced are in correctly.
Aug 31, 2009 | Maytag MFI2568AE Side by Side French Door...
GE PSS26GRE SS not dispensing ice
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Aug 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
We have a french door botom freezer maytag w/ and electronic water/ice dispenser. Model #mfi2568ae In the middle of the night the ice dispenser started opening and closing by itself and the led display is...
Don't be duped into thinking the display/dispenser board is the culprit. It may come a surprise, but this failure is often misdiagnosed. Because the dispenser is causing such a ruckus or because the display itself is blank or flickering, folks are led to believe that the display control board itself is the part that has failed. Looking at the history of our board evaluations, this little tiny control board rarely fails. And as crazy as it may seem, it is the main control board, aka the high voltage control of the fridge that is causing your refrigerator not to cool and the dispenser to be erratic.... This is the main control board of the refrigerator, located on the back of the unit. I've attached photos of what this main control board looks like. This main control board will need to be repaired to replaced.
http://blog.fixyourboard.com/2016/06/08/ice-dispenser-flapping-display-flashing-on-refrigerator/
Ice Dispenser Flapping and Display Flashing on Refrigerator
Aug 04, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
LFX 25950TT problem
Just had this same problem. We were away at Disney for four days - turned the icemaker off before we left. We have the LG french door double drawer freezer model. Came home, the ER IF code was displayed. Wouldn't dispense water or ice. Took the icebox out, and it was all frozen in the augers. Then I read on the door something to this effect - "if you turn off the icemaker, it will not continue to cool the ice. This will cause the ice to melt and leak out of the unit, and when it refreezes, the dispenser will not produce ice or water."
So, I took the ice box out, emptied it, reinstalled it, and the unit os making ice and dispensing water as I write.
Again, if you turn off the icemake, empty the ice box, or you will get the error message when you start the ice maker again.
Apr 08, 2008 | LG Refrigerators
MFI2568AEB HV Programming code
I have recently gone through same problem . The cose that was installed in the new control card for MFI2568AEW was 1411.
Mar 25, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
FRONT DISPLAY SHOWS (PE0-000)
Usually the owners manual would show the error codes so check there first. As for the compressor running, it "should" be cooling if the compressor is running. But lets go back a little, why was the HV board replaced?
Feb 05, 2007 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag Ice2O 24.9 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Black Logo
245 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
