Tannoy SFX 5.1 SUB WOOFER HAS STOPPED WORKING
3 Suggested Answers
SOURCE: sony subwoofer model# sp-pwm505
I have a JVC sub woofer SP-pwm 505 can I use this with any system my receiver has RCA jacks it looks like this uses a S cable...is there a cable that would convert "S" cable from sub woofer to an RCA output jack in receiver allenfreedman@yahoo.com
Posted on Nov 21, 2008
SOURCE: Hi There,
ho i got a AS that did that im NOT saying it will work with yours but if you open it up and replace the fuses with new ones it should work i reakon you have blown the sound fuses and not the power fuse hope it helps m8 and like i said it might NOT work
Posted on Jun 11, 2009
Does anyone have a schematic for a Tannoy HTS Sub Woofer
Email or phone them direct using details in the manual
The instruction manual is here, but no internal wiring diagram.
http://media.datatail.com/docs/installation/65352_en.pdf
Feb 08, 2016 | Audio Players & Recorders
Which model sub woofer can replace JVC SP-PW100?
The simplest thing would be a like-for-like replacement. Ebay or Craigslist would be good sources if the sub is out of production. There's one listed on Ebay UK for 39 sterilng. Item number 171423774447 - ends 16th Sept 2014
For new replacements the answer depends partly on how you connect and then partly on where you live. I'll deal with connections first...
The JVC has both high-level -speaker cable sockets- and low-level -phono/RCA- connections. Budget subs with both sets are getting rarer in the UK.
If you are connecting from an AV receiver with the low-level phono cable then the Tannoy SFX sub would do quite nicely. It's 99 sterilng at Richersounds.
For a sub with high and low level connections then the Wharfedale Diamond sub is about the cheapest in wide distribution. 170 sterilng at Tesco, 150 sterilng as an open box special at Superfi. Personally though, if I were considering spending 150+ on a sub I'd go the extra mile and plump for the BK Gemini at 215 sterilng direct from the manufacturer. You're getting 300+ sterilng performance because they cut out the middleman.
If you live in the US then there's a bit more choice. Have a look at Bestbuy. The Pioneer SW 8mk2 isn't bad at 159 dollars. There's the Theater Solutions SUB6F at 88 dollars if you just want cheap. Respected speakers brand Polk has the PSW 108 at 199 dollars
Sep 09, 2014 | JVC SP-PW100 Subwoofer
Hi I have just bought a Sony 820av amp and tannoy sfx speakers. I have got all working except my sub. Can anyone advise me on correct cabling for the sub to amp?
Sub woofers are just mono amps. They feed both the right and left output together. So all you need is a stereo to mono cable. The two jacks go in the sub and the single mono into one of the terminals on your amp. The other terminal will allow another sub to be connected I think, though please check your manual for this.
Jan 17, 2013 | Audio Players & Recorders
What could be causing my Powered Sub Woofer to make crackling noises when stereo is on or off?
Model specification would help with this, but it could be dirt (or fur if you have pets) in the circuit. This is to assume that the unit is in a standby mode rather than off or unplugged. If the subwoofer is a powered sub, then the problem is more than likely in the sub. Verify this by unplugging the cable from the main unit and see if it still crackles. I would need a Make/model to diagnose any further.
Oct 28, 2009 | A D S Audio Players & Recorders
Need to recone spker Tannoy super gold sgm10 b
I needed some speakers reconed. It ended up cheaper for me to just purchase new 10 inch woofers for my speakers. I actually purchased Rockford Subs for a car and placed them in my home speakers cabinets. It worked great.
Mar 31, 2009 | Music
Sr7200 LFE (sub woofer) output stopped working
Chances are if The Receiver only has sound in Stereo Direct Mode and all surround modes and Sub out are Inop the DSP (Digital Signal Processing) Card is most likey defective. These boards are not available from marantz (D&M Holdings) and must be Component level repaired which usually is not cheap. If Only the Sub out is not working check setup to be sure sub woofer is set for on. Also If On Screen setup menu does not appear on video monitor Unit may need to be Reset manually which entails discharging a Capaitor on main P.C.B Contact kstahl65@att.net for details
Dec 16, 2007 | Marantz SR-7200 Receiver
349 people viewed this question
 Grubhead
Grubhead
