Question about Elkay Water Cooler ADA Wall Hung 8 Gallons Per Hour
How to dismantel a elkay model ezfs8 water cooler
3 Suggested Answers
muralme
  • 20 Answers
SOURCE: elkay water cooler does not turn on
You need to first check the circuit breaker for that wall outlet, and see if you short circuited it from water going behind the wall. if that is the case you need to reset it at the circuit box and then run a bead of clear silicone on the back of the water cooler to prevent water from dripping down the back .
Posted on Jul 17, 2009
  • 127 Answers
SOURCE: water pressure is low on the elkay fountain
if you mean the amount of water that comes out of the bubbler head....you can adjust that by accessing the push button cartridge and turning it to adjust how far it is pushed.
Posted on Oct 18, 2009
My Elkay water fountain is clogged up, water does not drain properly, how do I unclog
To unclog the elkay water fountain just look out for push button catridge and and turning it to adjust how far it is pushed or you can even try with chemical drain cleaners like draino or liquid plumber or CLR(Calcium,Lime and Rust Remover) & if still the problem hire plumbing repair services.
All Plumbing Repairs
Apr 29, 2015 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
Elkay drinking fountain M#erpb28c continuously runs, having problems getting mounting nut back onto bubbler, seems basin should come off for access, however needind a reapir manual or access instructions...
The Elkay fountains are turned on by a solenoid powered valve. There is a rubber grommet in that valve assembly that gets holes in it and then water gets behind it, causing the valve to stick on. To test that it is a solenoid problem, turn the water on and then unplug the power to the fountain--if the water continues to run you have a solenoid problem. You'll need to replace the solenoid and I've detailed how to do it with all the steps and lots of pictures on my blog: http://johnfixesstuff.blogspot.com/2014/10/how-to-fix-elkay-model-ezfs81b-replace-solenoid-35981c.html John Fixes Stuff How To Fix an Elkay Model EZFS8 1B Drinking Fountain...
Feb 22, 2011 | Vacuums
I have power and water to the fountain, but fail to get the water to pump to the fountain head
The water pressure get the water to the spout it is not pumped there. You have a valve in the off position some where. http://www.elkayusa.com/cps/rde/xbcr/elkay/12-23D_EZ_EZS_EZSD_EZD.pdf this link shows an electric solenoid valve and also a manual valve.
Feb 18, 2011 | Elkay EZS8-L Single-Level Wall Mount Water...
HOW DO YOU GET THE EKLAY WATER FOUNTAIN APART TO REPLACE SOLENOID SWITCH
I have written up the entire process with all the steps and lots of pictures on my blog at: http://johnfixesstuff.blogspot.com/2014/10/how-to-fix-elkay-model-ezfs81b-replace-solenoid-35981c.html
Sep 16, 2010 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
How can adjust the volume of water coming from the drinking spout on my Elkay water fountain?
On our Elkay drinking fountain there is a set screw underneath that you can turn to adjust the flow rate. I have detailed how to adjust the flow along with how to replace the solenoid on my blog at: http://johnfixesstuff.blogspot.com/2014/10/how-to-fix-elkay-model-ezfs81b-replace-solenoid-35981c.html John Fixes Stuff How To Fix an Elkay Model EZFS8 1B Drinking Fountain...
Mar 19, 2010 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
Water pressure is low on the elkay fountain
Oct 18, 2009 | Elkay EZS8-L Single-Level Wall Mount Water...
Elkay water cooler does not turn on
May 30, 2009 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
Need temp control for water cooler has BOTH HOT/COLD
Company called Ranco makes replacement contols. Contact your local Appliance Parts Dealer.
Apr 22, 2009 | Refrigerators
Elkay Water Cooler ADA Wall Hung 8 Gallons Per Hour Logo
456 people viewed this question
Top Elkay Plumbing Experts
jdthefixer
rdjagger
Are you an Elkay Plumbing Expert? Answer questions, earn points and help others
