Question about Kenmore 22422 Top Load Washer
Kenmore Series 70 Stopped heating up
IS it possible to burn the dryer up if the lint catcher is full to the brim? I asked this cause that exactly what my wife did. Is there a overload reset switch somewhere or am I pretty much in the muck?
  • 5,911 Answers
Dryers have a thermal cut-out (TCO) that can trip in an overheat condition. Yes, it is possible to restrict air flow from clogged lint and cause this overheat condition. The TCO acts as a fuse and cannot be reset. If defective, it must be replaced. Here is a link that also explains other causes of dryer heat related failures:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Now...normally if there is heating circuit failure, such as the TCO or heating element, the dryer drum will still rotate. The dryer just does not heat. If this is not your symptom, you may have another cause to your failure. This next link, provides more detailed symptom elaboration:
http://www.fixya.com/support/r385301-thorough_dryer_advice
Pay particular attention to the sections in these links that discuss proper dryer ventilation. Poor air flow is the number one cause of dryer failures and dryer fires.
What is your model number? This will determine how your dryer is configured and where the heating components are located. If you have further questions, please let me know. I hope this helps you.
Posted on Jan 13, 2009
Why isn't My Kenmore Heavy Duty 70 Series Soft Heat Extra Capacity Electric Dryer drying clothes on any one cycle?
One possibility: Air flow! Make sure that the lint trap is cleaned before each cycle. You likely need to thoroughly clean out the vent piping out the back of the machine- a buildup of lint in here can also restrict airflow.
Sep 04, 2012 | Kenmore 659 Electric Dryer
I have a Maytag neptune dryer model # MDE5500AY. I smelled a smokey and electrical smell tonight. What's going on? Lint catcher is clean and I also clean around dryer. House was built in 2004 and dryer is...
the fault is lint build up around the dyer element the element must be cleared of all lint after years of use despite having a catcher lint does get into the dryer in time it will build around the heating element and start to burn this is unsightly but more so very dangerous as it does cause house fires have the element cleaned
best of luck
please rank this advice if you found it helpful
sonic boom electronics australia
Dec 28, 2010 | Maytag Neptune MDE5500AY Electric Dryer
The drum on my kenmore 70 series dryer won't turn and the dryer won't get heat up either. The drum will start to turn if we take the lid off and manually push it but not automatically
The dryer will not heat till the motor starts . If the dryer makes a hum when you activate the start switch' but won't start, then either the motor switch is bad or full of lint. If there is no hum then the start switch may be bad.
Nov 22, 2010 | Kenmore 63942 Dryer
My kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
Oct 05, 2009 | Kenmore 73952 Gas Dryer
Dryer runs fine but no heat
change the fuse in back of the dryer
Jun 23, 2009 | Kenmore 73952 Gas Dryer
Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Apr 06, 2009 | Kenmore 64742 Electric Dryer
Dryer not drying correctly
The coils are getting hot and won't open the gas valve. replace them dudes
291385a.jpgMore HERE
Mar 07, 2009 | Kenmore 73952 Gas Dryer
Long drying times model #11062712100
Try this and let me know what happens.
TIP OF THE DAY
To reduce the suction draft and drying time your drier and save some cash, remove the lint catcher and take it to the sink. Run water into it, if there is excessive pooling of the water (water not running straight through) then fabric softener is fouling the lint screen. Use a small brush and dish detergent to clean it and then shake off all the water and dry the screen. Remember this tip on future driers and you will make the dryer blower motor last much longer.
:?) DRRXR
Feb 07, 2009 | Kenmore 73952 Gas Dryer
The fuse probably blew due to a blockage of some sort. Check your ventpipe. It may be full of lint. The fuse is a small white part held onto the blower housing with 1 screw. It usually can be found under the dust cover on the rear of the dryer.84a81ce.jpg It has 2 small wires hooked to it and it is wired in series with the door switch. When the lint gets built up and dryer over heats and fuse blows. The result is just as if you opened the door.1d45fbe.jpg
Dec 16, 2008 | Whirlpool LER4634J Electric Dryer
Kenmore 70 Series Dryer Won't Heat
won't heat. fuse good,breaker good,heating element test ok. How do I check the thermostate, and timer.
Apr 29, 2008 | Kenmore 63942 Dryer
Kenmore 22422 Top Load Washer Logo
49 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
