Question about Indesit Washing Machines
Indesit wb101 wont spin drum
Made a clicking noise,so cleaned filter.then cleaned pipes from pump and found 47p.Now machine fills with water and drains,but won't turn drum on any programme.
wagdom
  • 64 Answers
SOURCE: Indesit Washing Machine not proceedding with the cycle programme after filling with water.
Cant understand how the machine will revolve on the 'spin cycle' & yet you can hear the motor on the 'wash cycle' but yet it doesnt revolve!!
Nomally if the water fills, & the tub revolves without the programmer advancing, its because the heater is not working. ie faulty thermostat, heat element, or maybe a wire burned off in the 'heater circuit'. Check if you have 240 volts at both ends of the heat element, with a meter or 240 volt bulb
                         !! BE CAREFUL OF 240VOLTS!!
Posted on Oct 31, 2007
  • 101 Answers
SOURCE: zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Posted on Apr 23, 2008
SOURCE: bosch classixx 1200 express
Not a programme error but carbon brushes on motor.Fixed by local engineer.
Posted on Aug 31, 2008
SOURCE: Washing machine will not drain
I have a maytag washer that when it fills with water it wont drain out..the spin cycle just makes a noise and it wont do anything..any ideas what i can do to fix it thanks
Posted on Nov 24, 2008
SOURCE: Indesit wd125 drum wont turn
check your pump it may not be working
Posted on Dec 18, 2008
I have a indesit iwb71250 that the red door lock light is on constantly but we can open the door and shut although the machine will run it wont fill with water... any ideas
May be the switch is loose try fixing it with ascrew driver or the rubber hose is not fixed properly and the machine pump is taking air or the pump failure
Oct 19, 2014 | Indesit IWB71250 White 60 cm Washer Front...
Indesit washer not draining
Check filter not blocked and pump turning freely
May 09, 2012 | Indesit Washing Machines
My Whirlpool washing machine has failed to rinse and spin due to the 'clean pump' light being on. Any advice on how to clean the pump? Thank you.
Check pump filter. I have had this twice on my indesit washing machine. You have to take the front cover off the bottom and then unscrew the filter to check it. Be careful as it will gush with water if the drum isn't drained.
Check the drain pipe for blockage by disconnecting far end of it and lowering to floor level (in a bowl). If no blockage then water should drain out of the drum by gravity.
Apr 03, 2011 | Whirlpool Washing Machines
Wasing machine fills with water during washing and wont pump out filling the drum...
1. Empty the drum via the filter / trap at the front (there is sometimes a drain pipe near the filter - otherwise be prepared to use lots of towels to soak up the water).
2. Check / clean the filter.
3. Ensure that the drainage pipe is not blocked.
4. Check that the pipe from the pump to the waste water pipe is not kinked / blocked.
5. Check that the pipe from the drum to the pump is not blocked.
6. Does the pump sound like it's trying to work? If not, it could be that the pump is dead. Pumps can often become blocked with fluff / slime from the machine.
Jan 13, 2011 | Bosch Washing Machines
My Indesit WE165 fills up with water
there is a little hose that runs from the back of the pump
up to a pressure switch that contols water level in drum
I had a problem similar to this and found hose had split making
the drum overfill, replaced hose cured problem
Apr 19, 2009 | Indesit W 123 Front Load Washer
WD860 Spitting out water & noisy
The spitting water problem is often caused by the filter assembly in the sump pipe just before the pump getting blocked. This easlily clogs up but is not easy to clean out. Hotpoint do not fit an easy access pump filter to this model but they place the filter into the black rubber pipe that runs from the drum to the pump. When this clogged up the machine empties too slowly and starts to spin when too much water is left in the drum, this forces water up and out of the soap tray. There is a minor design fault as the pressure sensor is attached to the same sump pipe and even when the filter is blocked the suction from pump still drops the pressure on the sensor. So you end up with a drum that has not emptied out enough water but still goes on to spin . The result is niagra falls from the soap tray.
To rectify this you will need to pull the machine out, unplug it, remove the rear lower back panel and dismatle the black sump to pump pipe. Once this is clear you will find the machine runs fine again. Its not an easy jobs and water spills everywear but if you are a keen DIY'r you should be OK. I just cleared mine out and found coins, shirt collar inserts and a large washing instruction label in the sump pipe. Now its clear and the machine has stopped spilling water from the soap dispenser.
As for the noise on spin, check all concrete is firmly fixed to the drum as they work loose
Jan 31, 2009 | Hotpoint Ultima WF860 Front Load Washer
Dec 18, 2008 | Indesit W 123 Front Load Washer
Indesit WG820 no power in spin
For your model I hope you will find the filter, seen similar models. Disconnect the machine from the mains outlet. Below the door, there's a plastic cover full machine width. Just remove it and on the right you'll see the filter. Unscrew the filter counter clockwise, clean it, check the pump blades and inlet for some foreign objects and screw filter back on.
Jun 01, 2008 | Washing Machines
Oct 29, 2007 | Indesit W 123 Front Load Washer
Will not spin
When your water does not drain or spin, check the outlet filter first, then the pipe from below the tub to the filter. Your washer wont spin 'cause the pump/filter is blocked. There is a small door on the front, below which is the place you have to clean out first.
Dec 05, 2006 | Indesit W 123 Front Load Washer
Washing Machines Logo
70 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
