Question about Compaq Computers & Internet
My compaq presario sr2019uk tower is making a beeping noise and the screen ain coming on
  • 101 Answers
SOURCE: beeping tower
Hi Mrspink.
One long beep is usually a ram issue, If you are confortable opening the case, you see the ram sticks. They are retained with a white clip on both ends of the stick. Press these down, to release the ram, then firmly press the stick straight down, till the retaining tabs click back into place and lock. If the ram was removed, make sure a stick is in slot #1. The slots should be numbered, on the ends. Good Luck!!
Posted on Jan 05, 2008
pagebor
  • 2785 Answers
SOURCE: when powering up the tower,
try with a new power supply unit
Posted on May 13, 2008
technotech
  • 183 Answers
SOURCE: the on button on the
you can go to this link http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00378480&dlc=en&lc=en&cc=us
it is going to Help you with Diagram.
Posted on Jul 14, 2008
  • 233 Answers
SOURCE: Compaq Presaio S4200NX displays Compaq Splash Screen then a single continuous beep with but nothing else.
Maybe the hard drive is bad?
Posted on Dec 15, 2008
louislevel_2
  • 374 Answers
SOURCE: keeps beeping has black screen
hi there,
this kind of sound on computer related to a hardware problem.unplug your computer if you can open the cover of your computer and try to disconnect the i.d.e cable of your hardisk,floopy and cd room,try to plug in and switch on your pc,
if the screen open,or the star up open ,either hardisk,cd room and floopy is defective.if still black screen is on your screen,you should have spare of video card and memory card,or put your memory card to other pc if your memory card is defective or good,also with your video card,or if you have spare of video card and memory card
put on to your pc have it installed and plug in then switch on if screen appear on your monitor,either video or memory card is defective.try to isolate w/c is defective.but if still black screen appear on your monitor after having replace a good video and memory cardyou have,defective mother board.
well isolate patrs of your pc defectiveness using other pc or using spare of part of pc you can trouble shoot and detect what causes your pc shutdown.if you can't do this call service technician to do this job near your location.have a nice day and don't forget to rate me.thank's
Posted on Apr 26, 2009
Compaq Presario S5100NX Desktop PC 1 LONG BEEP AT START UP I GET THE COMPAQ LOGO BUT NOTHING ELSE. THANKS FOR ANY HELP.
One long beep usually means a memory or RAM error..
Try removing the ram sticks and then simply replacing them back into the slots..
The contacts in the RAM slots are self cleaning to taking the sticks out and putting them straight back is usually enough to correct this issue..
Just make sure you touch part of the metal chassis of the tower BEFORE you touch anything else.
This will discharge any static charge you may have on your body..
Dec 19, 2010 | Compaq Presario S5100NX (E120866) PC...
Compaq presario sr1120nx will not post could this be the motherboard? i pulled out the memory modules and should have received beep codes for missing memory but none. Is this the motherboard?
yes if you have removed both sticks of ram and there is no beep code the n the motherboard is bad if you give me the serial i can give you the part number
May 13, 2010 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
My monitor has kicked into sleep mode and won't "wake up".
Unplug all the Cables from Compaq Presario 5103 CL and leave the Keyboard, mouse and monitor cable pluged in.
Now make sure the power cable of the monitor should be pluged in and the power cable of the tower should be pluged in.
Now to check if the montor is fine just unplug the video cable only which will show no input signal on the screen. If it shows this signal the monitor is fine. Plug back in the video cable.
If the monitor is going to sleep mode it might be possible that the old computer ( Compaq Presario 5103 CL ) is in stand by mode. hit any key on the keyboard and it should come back .
If it is not in the stand by mode then do one thing. Check the same monitor with the new computer. If it is working. Perfect ..!
Do one thing now ..!
Unplug all the cables from your old system and then press the power button for 30 sec and let it go. Now plug the keyboard, mouse and the monitor try again.
If it works Perfect. If not ..!
Then you need to open the tower and check on the processor FAN is it running..? If its not running you will not get the display as the fan is responsible for the display on the screen. Otherwise...!
Check the Tower possibly the Tower is not getting the power.
Try these steps and let me know If it works
May 04, 2010 | Compaq Presario 5000 PC Desktop
My compaq presario acts like it wants to come on and then the screen goes black. Help
Most of the time, when a computer begins to "start", but than shuts its-self off, the processor fan has failed. But, it could be the hard drive, or RAM. If the computer makes some beeping noises when it starts up, those can be the codes you need to help decide what exactly is wrong. Next time you start the computer, listen for the beep codes. If you get more than one short beep, than make a note how many, and how long the beeps were. Than you need to get online, and search out their meaning. Just type in computer beep codes.
Jul 04, 2009 | Compaq Presario Notebook
Compaq Presario 1655
try these 2 things. first remove power (battery, charger) now remove the panel that has the HDD and remove it, now put it back in and make sure it makes contact. now remove the panel that has the RAM/memory and remove and re insert them. power it up. if this does not work, that points to a hard ware failure. if there is any beeping noise made by the laptop, make a note of it (how many beeps, if they are short or long)
Jan 27, 2009 | Compaq Presario 1655 (347550-003) PC...
Compaq presario sr2019uk noisey fan
Most likely un related. Make sure their are not wires coming near the fan to make the noise.
If its a 'grindy' sound it could just be the ball bearings wearing out. But if you just worked in their, maybe something is rubbing near it.
Oct 10, 2007 | Computers & Internet
Computers & Internet Logo
55 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
