Question about Samsung RF265AA Bottom Freezer French Door Refrigerator
Ice maker arm stuck in up position on RSH7UNSW
5 Suggested Answers
tborn6
  • 700 Answers
SOURCE: Samsung Refrigerator Model RS2533SW - Ice Maker Stuck
did that work?
Posted on Feb 04, 2009
  • 864 Answers
SOURCE: Ice maker bin indicator arm is stuck in the bin is full position
You should be able to move it gently to the lower position.  If it doesn't want to move don't force it.  Try shutting the ice maker off in case the arm is frozen in the up position.  After the ice maker defrosts a bit try again to move the arm gently.
Posted on May 29, 2009
daddyo742001
  • 70 Answers
SOURCE: ice maker won't work
Temp needs to be down to 0 or below for ice maker to activate. once that happend arms that push ice out will go around and made switch in end of ice maker that turns on water selenoid valve that adds water. this could also be electronic switch. main thing is its cold enough to activate. If it don't work then Ice maker may be bad or no power getting to it. turn freezer as cold as you can may mean setting refrig side warmer. If it has coil under refrig clean it out. Air around frig should be 68 - 75 degrees if poss.
Posted on Jun 29, 2009
  • 3 Answers
SOURCE: ice maker has ice motor doen't dump the ice
Your ice-maker may need to be "hard-reset". To do this, perform a manual-defrost by emptying out the freezer (and fridge) and shutting all power off to your unit for several hours (at least half a day unless you can be sure the temp in the freezer has fully reached ambient. Next, with freezer empty, restore power, make sure the "ice" setting is set to off, then set the forced power-freeze mode (you can refill the fridge, but leave the freezer empty for now. When the power-freeze completes (at least 2.5 hours) you can refill the freezer, set the "ice" mode to block/crushed (IE something other than off) and then hit the "black reset button" to restart the ice-maker. IF it still will not dump the cubes then the ice sensor/control board may have failed.
Posted on Sep 24, 2010
GE Side-by-side PSSB6KSXCCSS paddle stuck in off position on ice maker. Spring is in correct holes but paddle does not move
Your ice maker will move the arm if working properly. I bet the ice maker is dead and the ice forks are stopped in a position other than the home position
Ice Maker Assembly WR30X10093
APPLIANCE 911
Sep 18, 2016 | GE Refrigerators
The arm in the ice maker is stuck in the "up" position
unplug the unit and check if the icemaker timer is working alright. replace with a new one if it is messed up. thanks .
Mar 12, 2015 | LG LFC25770ST (250 cu ft) Bottom Freezer...
Ice maker subzero 690 stuck won't make ice because i think the plastic flap that rises when the ice bucket fills is stuck and won't come down to turn on the water
There is a screw sticking out from the right side of the freezer wall that has a grey plastic spacer around it that acts as a stopper for the ice level arm. I have seen the ice level arm get stuck on top of this stopper before somehow. you just have to carefully bend the level arm around it and move it below the grey plastic stopper. If it is not stuck above that but the arm still will not come down, then the only other solution is likely a new icemaker, as the arm is geared internally to the icemaker to rise and fall as the ice is made.
Sep 26, 2014 | Sub-Zero 690 Side by Side Refrigerator
Frigidaire refrigerator glhs38egsb0 ice maker freezing up
Hi - Is the wire signal arm in a stuck position or has any ice cubes stuck? If so, try turning it off and remove any ice cubes stuck to the wire signal arm or body of the ice maker and wait approximately 8 hrs. Should these suggestions prove to be ineffective and ice maker continues to freezer up, I recommend contacting a professional to properly diagnose and repair the unit.
Sep 29, 2012 | Refrigerators
I've got the LFX25960ST model. The icemaker
its the ice maker .water or condensation has built up in the ice maker modual and refroze upon turning unit back on.either get a new ice maker or uninstall the ice maker and let it dry for a few days and reinstall.but it could happen again that way.or maybe not.
Jul 24, 2009 | LG LFX25960 Bottom Freezer French Door...
May 29, 2009 | Samsung RF265AA Bottom Freezer French Door...
Icemaker Arm stuck in up position
Hi, Check and see if the finger sweep has ice jamming it so that it can't finish it's rotation. This is a come problem. You might have to remove the ice maker to see what is blocking it. Usually two screws on top and one underneath the ice maker.
Please let me know if i can assist you further.
Vic
May 27, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Ice maker
hi. thanks for the question. is the arm on the ice maker in the up position. it could be stuck in the ice cubes. the arm has to he up to stop the process thanks the appliance doc.
Oct 02, 2008 | LG LRFC25750 Refrigerator French Door
Ice Maker not making ice
replace the icemaker is the best solution , or possibly jst the control module
Jan 14, 2008 | Jenn-Air JCD2389G Side by Side...
Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
52 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
